Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 48
  1. #11
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,606
    Dont give up that easy
    Have a look at this similar problem with solution http://www.cadtutor.net/forum/showth...windowing-lisp
    What I was saying is your asking 2 questions needs 2 different answers.
    Also pretty sure handles are unique so no 2 would be alike so can not find object in 2nd dwg.
    Also its about time this is a free forum so we still have to work and play. I would have done it for you but I am busy, I do repsonses in my lunch time not company time.
  2. #12
    Junior Member
    AutoCAD 2010
    Mar 2013
    23
    Hi BigAl,
    Thanks again for your comment.
    What i would probably do with text that currently sits outside the polygons is move them inside. That will make things a lot quicker than trying to write two pieces of code!
    I appreciate that the forum is free and i don't expect people to give-up hours of their free time to right a code for someone that is a newbie to the forum.
    I am greatful for your input, it has helped. I will persist a bit longer with finding an online manual to help me wite this code.
    Thanks
  3. #13
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,606
    I have made a start this pulls co-ords from pline very simple method and then allows ssget to find text it needs some debugging but a start next will be to create a loop for all plines selected.
    Code:
    (defun getcoords (ent)
      (vlax-safearray->list
        (vlax-variant-value
          (vlax-get-property
        (vlax-ename->vla-object ent)
        "Coordinates"
    (defun co-ords2xy ()
    ; convert now to a list of xy as co-ords are x y x y x y if 3d x y z x y z
    (setq numb (/ (length co-ords) 2))
    (setq I 0)
    (repeat numb
    (setq xy (list (nth i co-ords)(nth (+ I 1) co-ords) ))
    (setq co-ordsxy (cons xy co-ordsxy))
    ; program starts here
    (setq co-ords (getcoords (car (entsel "\nplease pick pline"))))
    (co-ords2xy)
    (setq ss (ssget "WP" co-ordsxy (list (cons 0 "*text")))) ; selection set of text within polygon
  4. #14
    Junior Member
    AutoCAD 2010
    Mar 2013
    23
    Hi BigAl,
    I am working my way through this tutorial http://www.afralisp.net/autolisp/tut...ics-part-1.php
  5. #15
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,606
    Fixed a mistake in code
  6. #16
    Junior Member
    AutoCAD 2010
    Mar 2013
    23
    I have tried your code on the dwg file i attached at the start of this thread. It doesn't seem to pick up any of the polygons.
    On a positive note though i am working my way through the online tutorial and so i am starting to pick up and understand the odd bits of text
  7. #17
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,606
    I will check it and if I have time add the missing do all plines.
  8. #18
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,606
    an upgrade still work in progress a bit busy right now
    Code:
        (vlax-variant-value
          (vlax-get-property
        "Coordinates"
    (defun co-ords2xy (/ xy)
    (setq I 0)
    (repeat numb
    (setq I (+ I 2))
    (setq plist (ssget (list (cons 0 "lwpolyline"))))
    (setq numb (sslength plist))
    (setq J 0)
    (repeat numb
    (setq co-ords (getcoords (ssname plist J)))
    (co-ords2xy)
    (princ (sslength ss)) ; this is howmany texts etc
    (setq co-ordsxy nil)
    (setq J (+ J 1))
    (setq ss nil)
    ) ; end repeat
  9. #19
    Junior Member
    AutoCAD 2010
    Mar 2013
    23
    I am over the moon that you are helping me with this Big Al.
    I have run the lisp and it is now picking up multiple polygons :-)
    Thank you
  10. #20
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,606
    What are you trying to achieve in terms of output a simple TXT file or excel or a CSV
    pline1 xy xy xy xy
    text1 abcde
    text2 addd
    pline2 xy xy xy xy
    text3 jjjj
    pline4 and so on ?
  1. Extracting xyz coordinates from 3d polylines
    By 1ridgey in forum AutoCAD Beginners' Area
    Last Post: 13th Apr 2012, 02:08 am
  2. How to do this handle????
    By stevep80 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 3rd Jan 2012, 08:08 pm
  3. extracting cursor coordinates
    By rusty in forum AutoCAD Drawing Management & Output
    Last Post: 29th Jun 2006, 10:30 am
Tags for this Thread
