ColinHolloway Posted March 13, 2013 Share Posted March 13, 2013 Hi All, Using LISP I can set the Tool Palettes File Locations using vla-put-ToolPalettePath but I cannot find a way (without putting the value directly into the Registry) to set the Authoring Palatte File Locations. Is there a way to do this without accessing the registry directly (using vl-registry-write)? Thanks in advance, Colin Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 13, 2013 Share Posted March 13, 2013 A lot of the config stuff is about knowing variable name did you try Authortoolpalettepath ? as a guess its hard to find sometimes Try this ;(vlax-dump-object (vla-get-files (vla-get-preferences (vlax-get-Acad-object))) T) Quote Link to comment Share on other sites More sharing options...
ColinHolloway Posted March 13, 2013 Author Share Posted March 13, 2013 Hi BIGAL, That path variable isn't listed in the object dump. I guess I'll have to explore the registry option. Thanks, Colin A lot of the config stuff is about knowing variable name did you try Authortoolpalettepath ? as a guess its hard to find sometimes Try this ;(vlax-dump-object (vla-get-files (vla-get-preferences (vlax-get-Acad-object))) T) Quote Link to comment Share on other sites More sharing options...
