I am drawing a polyline with VB.Net using a modification of fixo's routine (his first post in this thread http://www.cadtutor.net/forum/showthread.php?78728-3d-points-amp-2d-polylines ). It suits my needs nicely except I can only see an elastic line from the last point clicked to where my next point will be. Is there a way of leaving a line from all the previous points?
The only thing I can think of doing is setting a "mark", drawing lines as I go along and then undo back to the mark. However, I haven't looked at coding that yet.
Have you other ideas?
Edited by dbroada
"vb.net" added
  • Replies 24
  • dbroada
    8
  • Tyke
    5
  • BlackBox
    5
  • ReMark
    4
Does it have to be a line that you leave? You just need a visual reminder of where you were previously right? And does this reminder have to be permanent?
I probably should have mentioned that this is being done in VB.Net. I want a visual clue left to show where the polyline will be until the polyline is drawn. Once the polyline shape has been determined the marker should be erased.
I know this is going to show my age but could -BLIPMODE somehow be used?
I have considered that (we must be the same age) and immediately forgot about it. Age again I think. I was going to keep that up my sleeve hoping something "nicer" comes along but now I test it in 2013, its not there.
I almost agreed with you Dave until I remembered another trick. Try using .BLIPMODE instead. See the ?
Us "senior" forum members have to stick together. You're entirely welcomed Dave. Good luck.
BUMP!
While BLIPMODE will give me a clue, does anyone know if there a programatic way of laying down a line or pline which is then erased when I add the final pline?
Sean, yes that first one would be very nice - but I'm too new to VB.Net to translate it today. :( I'll look again when I have more time and see if I can get it to work. In the meantime, blipmode here I come.
  • 3 months later...
Dave, did you ever get time to do this in VB? It would appear to be just what I need too.
B
... but I'm too new to VB.Net to translate it today. :(
... So new, in fact, that you could easily start learning C#, methinks. :beer:
Another option (as you are using .NET [aka CLR]), is to compile the C# code into an assembly, which you load into your VB.NET projects as reference(s)... This gives you the ability to reference any Type (Class), Property, Method, or Event you'd need from the source, without converting, nor learning C# (which I do highly recommend).
In any event, my friend(s)... Here's the C# code Sean was kind enough to link previously, converted from C# to VB.NET using DeveloperFusion (so you may need to fix some errors, etc.)... You can remove the length of some of those calls by removing the Namespace qualification (with an additional Imports statement, etc.) as well, if you like....
Class "MyNewAreaCmd":
Imports System.Collections.Generic
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.GraphicsInterface
Imports Autodesk.AutoCAD.DatabaseServices
Namespace AreaCommand
Public Class MyNewAreaCmd
	Private _dwg As Document
	Private _editor As Editor
	Private _area As Double = 0.0
	Private _perimeter As Double = 0.0
	Private _pline As Autodesk.AutoCAD.DatabaseServices.Polyline = Nothing
	Private _points As List
	Private _pickDone As Boolean
	Private _color As Integer = 1
	Public Sub New(dwg As Document)
		_dwg = dwg
		_editor = _dwg.Editor
	End Sub
	Public ReadOnly Property Area() As Double
		Get
			Return _area
		End Get
	End Property
	Public ReadOnly Property Perimeter() As Double
		Get
			Return _perimeter
		End Get
	End Property
	Public Function GetArea() As Boolean
		_pline = Nothing
		'Pick first point
		Dim pt1 As Point3d
		If Not GetFirstPoint(pt1) Then
			Return False
		End If
		'Pick second point
		Dim pt2 As Point3d
		If Not GetSecondPoint(pt1, pt2) Then
			Return False
		End If
		_pickDone = False
		_points = New List()
		_points.Add(New Point2d(pt1.X, pt1.Y))
		_points.Add(New Point2d(pt2.X, pt2.Y))
		Try
			'Enable custom Overrule
			MyPolylineOverrule.Instance.StartOverrule(_points, _color)
			'Handling mouse cursor moving during picking
			_editor.PointMonitor += New PointMonitorEventHandler(AddressOf _editor_PointMonitor)
			While True
				If Not PickNextPoint() Then
					Exit While
				End If
			End While
			If _pline IsNot Nothing AndAlso _pickDone Then
				Calculate()
			End If
		Catch
			Throw
		Finally
			ClearTransientGraphics()
			'Remove PointMonitor handler
			_editor.PointMonitor -= New PointMonitorEventHandler(AddressOf _editor_PointMonitor)
			'Disbale custom Overrule
			MyPolylineOverrule.Instance.EndOverrule()
		End Try
		Return _pickDone
	End Function
	#Region "private methods"
	Private Sub Calculate()
		Dim p As New Autodesk.AutoCAD.DatabaseServices.Polyline(_points.Count)
		For i As Integer = 0 To _points.Count - 1
			p.AddVertexAt(i, _points(i), 0.0, 0.0, 0.0)
		Next
		p.Closed = True
		_area = p.Area
		_perimeter = p.Length
		p.Dispose()
	End Sub
	Private Function GetFirstPoint(ByRef pt As Point3d) As Boolean
		pt = New Point3d()
		While True
			Dim opt As New PromptPointOptions(vbLf & "Pick first corner: ")
			opt.Keywords.Add("Background")
			opt.AppendKeywordsToMessage = True
			Dim res As PromptPointResult = _editor.GetPoint(opt)
			If res.Status = PromptStatus.OK Then
				pt = res.Value
				Return True
			ElseIf res.Status = PromptStatus.Keyword Then
				Dim intOpt As New PromptIntegerOptions(vbLf & "Enter color number (1 to 7): ")
				intOpt.AllowNegative = False
				intOpt.AllowZero = False
				intOpt.AllowArbitraryInput = False
				intOpt.UseDefaultValue = True
				intOpt.DefaultValue = 1
				Dim intRes As PromptIntegerResult = _editor.GetInteger(intOpt)
				If intRes.Status = PromptStatus.OK Then
					_color = intRes.Value
				End If
			Else
				Return False
			End If
		End While
	End Function
	Private Function GetSecondPoint(basePt As Point3d, ByRef pt As Point3d) As Boolean
		pt = New Point3d()
		Dim opt As New PromptPointOptions(vbLf & "Pick next corner: ")
		opt.UseBasePoint = True
		opt.BasePoint = basePt
			pt = res.Value
			Return True
		Else
			Return False
		End If
	End Function
	Private Function PickNextPoint() As Boolean
		If _points.Count > 2 Then
			opt.Keywords.Add("Undo")
			opt.Keywords.Add("Total")
			opt.Keywords.[Default] = "Total"
			opt.AllowArbitraryInput = False
		End If
			_points.Add(New Point2d(res.Value.X, res.Value.Y))
			Return True
			If res.StringResult = "Undo" Then
					_points.RemoveAt(_points.Count - 1)
				End If
				Return True
			Else
				_pickDone = True
				Return False
			End If
		Else
			_pickDone = False
			Return False
		End If
	End Function
	Private Sub ClearTransientGraphics()
		If _pline IsNot Nothing Then
			TransientManager.CurrentTransientManager.EraseTransients(TransientDrawingMode.DirectTopmost, 128, New IntegerCollection())
			_pline.Dispose()
			_pline = Nothing
		End If
	End Sub
	Private Sub _editor_PointMonitor(sender As Object, e As PointMonitorEventArgs)
		'Get mouse cursor location
		Dim pt As New Point2d(e.Context.RawPoint.X, e.Context.RawPoint.Y)
		_pline = New Autodesk.AutoCAD.DatabaseServices.Polyline(_points.Count + 1)
			_pline.AddVertexAt(i, _points(i), 0.0, 0.0, 0.0)
		Next
		_pline.AddVertexAt(_points.Count, pt, 0.0, 0.0, 0.0)
		_pline.Closed = True
		TransientManager.CurrentTransientManager.AddTransient(_pline, TransientDrawingMode.DirectTopmost, 128, New IntegerCollection())
	End Sub
	#End Region
End Class
End Namespace
Class "MyPolylineOverrule":
Imports Autodesk.AutoCAD.Runtime
Public Class MyPolylineOverrule
	Inherits DrawableOverrule
	Private Shared _instance As MyPolylineOverrule = Nothing
	Private _existingOverrulling As Boolean
	Private _points As List = Nothing
	Public Shared ReadOnly Property Instance() As MyPolylineOverrule
		Get
			If _instance Is Nothing Then
				_instance = New MyPolylineOverrule()
			End If
			Return _instance
		End Get
	End Property
	Public Property Color() As Integer
		Get
			Return _color
		End Get
		Set
			_color = value
		End Set
	End Property
	Public Sub StartOverrule(points As List)
		_points = points
		_existingOverrulling = Overruling
		'Add the custom overrule
		AddOverrule(RXObject.GetClass(GetType(Autodesk.AutoCAD.DatabaseServices.Polyline)), Me, False)
		'Use custom filter, implemented in IsApplicable() method
		SetCustomFilter()
		'Make sure Overrule is enabled
		Overruling = True
	End Sub
	Public Sub StartOverrule(points As List, color As Integer)
		_color = color
		_points = points
		SetCustomFilter()
		Overruling = True
	End Sub
	Public Sub EndOverrule()
		'Remove this custom Overrule
		RemoveOverrule(RXObject.GetClass(GetType(Autodesk.AutoCAD.DatabaseServices.Polyline)), Me)
		'restore to previous Overrule status (enabled or disabled)
		Overruling = _existingOverrulling
	End Sub
	Public Overrides Function WorldDraw(drawable As Drawable, wd As WorldDraw) As Boolean
		Dim pts As New Point3dCollection()
			pts.Add(New Point3d(_points(i).X, _points(i).Y, 0.0))
		Next
		wd.SubEntityTraits.FillType = FillType.FillAlways
		wd.SubEntityTraits.Color = Convert.ToInt16(_color)
		wd.Geometry.Polygon(pts)
		Return MyBase.WorldDraw(drawable, wd)
	End Function
	Public Overrides Function IsApplicable(overruledSubject As Autodesk.AutoCAD.Runtime.RXObject) As Boolean
		Dim pl As Autodesk.AutoCAD.DatabaseServices.Polyline = TryCast(overruledSubject, Autodesk.AutoCAD.DatabaseServices.Polyline)
		If pl IsNot Nothing Then
			'Only apply this overrule to the polyline
			'that has not been added to working database
			'e.g. created for the Transient Graphics
			If pl.Database Is Nothing Then
				Return True
			Else
				Return False
			End If
		Else
			Return False
		End If
	End Function
End Class
End Namespace
Command class "MyCommands":
<Assembly: CommandClass(GetType(AreaCommand.MyCommands))>
Public Class MyCommands
	<CommandMethod("MyNewArea")> _
	Public Shared Sub GetNewArea()
		Dim dwg As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
		Dim ed As Editor = dwg.Editor
		Dim cmd As New MyNewAreaCmd(dwg)
		If cmd.GetArea() Then
			ed.WriteMessage(vbLf & "Area = {0}", cmd.Area)
			ed.WriteMessage(vbLf & "Perimeter = {0}", cmd.Perimeter)
		Else
			ed.WriteMessage(vbLf & "*Cancelled*")
		End If
	End Sub
End Class
End Namespace
Thanks for that RM, but unlike Dave I'm an old dog who finds it difficult to change his ways. I'll stick with VB.
Since I posted I found the following in the Civil 3D Help. I haven't tested it yet but it looks promising, I just need to modify the code to allow more than five Points to be selected. Perhaps I can test it tomorrow.
Calculate a Defined AreaArea (.NET)
If the area you want to calculate is based on user specified points, you might consider creating an in memory object such as a lightweight polyline, and then query of the area of the object before discarding it. The following steps explain how you might accomplish this:
1. Use the GetPoint method in a loop to obtain the pointsfrom the user.
2. Create a lightweight polyline from thepoints provided by the user. Create a new Polyline object. Specify the numberof vertices and the points they should be at.
3. Use the Area property to obtain the area of the newly created polyline.
4. Dispose of the polyline using its Dispose method.
Calculate the area defined by points entered from the user
This example prompts the user to enter five points. A polyline is then created out of the points entered. The polyline is closed, and the area of the polyline is displayed in a message box. Since the polyline is not added to a block, it needs to be disposed before the command ends.
VB.NET
[color=black][font=Courier New]Imports Autodesk.AutoCAD.ApplicationServices[/font][/color]
[color=black][font=Courier New]Imports Autodesk.AutoCAD.DatabaseServices[/font][/color]
[color=black][font=Courier New]Imports Autodesk.AutoCAD.Geometry[/font][/color]
[color=black][font=Courier New]Imports Autodesk.AutoCAD.EditorInput[/font][/color]
[color=black][font=Courier New]Imports Autodesk.AutoCAD.Runtime[/font][/color]
[color=black][font=Courier New]<CommandMethod("CalculateDefinedArea")> _[/font][/color]
[color=black][font=Courier New]Public Sub CalculateDefinedArea()[/font][/color]
[color=black][font=Courier New]  '' Prompt the user for 5points[/font][/color]
[color=black][font=Courier New]Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument[/font][/color]
[color=black][font=Courier New]DimpPtRes As PromptPointResult[/font][/color]
[color=black][font=Courier New]  Dim colPt AsPoint2dCollection = New Point2dCollection[/font][/color]
[color=black][font=Courier New]  Dim pPtOpts AsPromptPointOptions = New PromptPointOptions("")[/font][/color]
[color=black][font=Courier New]  '' Prompt for the firstpoint[/font][/color]
[color=black][font=Courier New]  pPtOpts.Message = vbLf& "Specify first point: "[/font][/color]
[color=black][font=Courier New]  pPtRes =acDoc.Editor.GetPoint(pPtOpts)[/font][/color]
[color=black][font=Courier New]  colPt.Add(NewPoint2d(pPtRes.Value.X, pPtRes.Value.Y))[/font][/color]
[color=black][font=Courier New]  '' Exit if the userpresses ESC or cancels the command[/font][/color]
[color=black][font=Courier New]  If pPtRes.Status =PromptStatus.Cancel Then Exit Sub[/font][/color]
[color=black][font=Courier New]  Dim nCounter As Integer =1[/font][/color]
[color=black][font=Courier New]  While (nCounter <= 4)[/font][/color]
[color=black][font=Courier New]      '' Prompt for the nextpoints[/font][/color]
[color=black][font=Courier New]      Select Case nCounter[/font][/color]
[color=black][font=Courier New]          Case 1[/font][/color]
[color=black][font=Courier New]              pPtOpts.Message= vbLf & "Specify second point: "[/font][/color]
[color=black][font=Courier New]          Case 2[/font][/color]
[color=black][font=Courier New]              pPtOpts.Message= vbLf & "Specify third point: "[/font][/color]
[color=black][font=Courier New]          Case 3[/font][/color]
[color=black][font=Courier New]              pPtOpts.Message= vbLf & "Specify fourth point: "[/font][/color]
[color=black][font=Courier New]Case 4[/font][/color]
[color=black][font=Courier New]              pPtOpts.Message= vbLf & "Specify fifth point: "[/font][/color]
[color=black][font=Courier New]      End Select[/font][/color]
[color=black][font=Courier New]      '' Use the previouspoint as the base point[/font][/color]
[color=black][font=Courier New]      pPtOpts.UseBasePoint =True[/font][/color]
[color=black][font=Courier New]      pPtOpts.BasePoint =pPtRes.Value[/font][/color]
[color=black][font=Courier New]      '' Increment thecounter[/font][/color]
[color=black][font=Courier New]      nCounter = nCounter +1[/font][/color]
[color=black][font=Courier New]  End While[/font][/color]
[color=black][font=Courier New]  '' Create a polyline with5 points[/font][/color]
[color=black][font=Courier New]  Using acPoly As Polyline =New Polyline()[/font][/color]
[color=black][font=Courier New]      acPoly.AddVertexAt(0,colPt(0), 0, 0, 0)[/font][/color]
[color=black][font=Courier New]      acPoly.AddVertexAt(1, colPt(1), 0, 0, 0)[/font][/color]
[color=black][font=Courier New]      acPoly.AddVertexAt(2,colPt(2), 0, 0, 0)[/font][/color]
[color=black][font=Courier New]      acPoly.AddVertexAt(3,colPt(3), 0, 0, 0)[/font][/color]
[color=black][font=Courier New]      acPoly.AddVertexAt(4,colPt(4), 0, 0, 0)[/font][/color]
[color=black][font=Courier New]      '' Close the polyline[/font][/color]
[color=black][font=Courier New]      acPoly.Closed = True[/font][/color]
[color=black][font=Courier New]      '' Query the area ofthe polyline[/font][/color]
[color=black][font=Courier New]     Application.ShowAlertDialog("Area of polyline: " & _[/font][/color]
[color=black][font=Courier New]                                  acPoly.Area.ToString())[/font][/color]
[color=black][font=Courier New]      '' Dispose of thepolyline[/font][/color]
[color=black][font=Courier New]End Using[/font][/color]
[color=black][font=Courier New]End Sub[/font][/color]
Thanks for that RM.
You're welcome :)
Civil 3D is a beast... It's hard enough just trying to keep track of all of the API changes in AutoCAD, let alone gigantic verticals such as Civil 3D. Since you mentioned it though, and you're working with .NET, you might find the "Snoop Civil 3D" plug-in Augusto released at DevBlog to be useful (it's akin to MgdDbg for AutoCAD [which I also have an Autoloader .bundle for here], just without Civil 3D-specific Event monitoring)... For whatever reason, they've not provided an Autoloader plug-in, so I did in this post. There's a few posts before the one I've linked here that will provide additional information.
Let me know if you have any comment/questions about using it.
Cheers :beer:
You're welcome :)
Cheers :beer:
I edited my post since you replied.
I'm done for today and I'm now sitting in the living room after a delicious evening meal and have a a bottle of very good red wine that I'm sharing with the Little Lady.
Thanks for the advice, it will be looked at when the effects of the wine have worn off. :beer:
... unlike Dave I'm an old dog who finds it difficult to change his ways. I'll stick with VB.
.... You wouldn't want to know when I graduated High School then. :P :rofl:
You and the little lady have a lovely evening. :beer:
I bet I was already in retirement by then! About 8 years ago?;) :roll:
We did, thanks.:thumbsup:
[stuartVoice]
I don't wanna say!
[/stuartVoice]
images?q=tbn:ANd9GcRY3BMY1c2wB2zUn5ZsL9s4Ir8jPqwLZrcWwudghSbYfWiUwOIkxw
Hooray SNL (Saturday Night Live) Mad TV skits!
Edited by BlackBox
Ehhhehehehehe
