humpo Posted May 8, 2013 Share Posted May 8, 2013 Hi All probably very easy solution, but can anyone advise how to delete the layer "AR-FURN-E" on the attached drawing? also, there is a circle to the right of the building where if you zoom out, a small dot will appear inside, what is this?? cheers 133 LG floor.dwg Quote Link to comment Share on other sites More sharing options...
humpo Posted May 8, 2013 Author Share Posted May 8, 2013 i have worked it out. LAYDEL was the command i needed. it also deleted the strange dot Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 10, 2013 Share Posted May 10, 2013 Sounds like a block, you can not delete a layer if a block is using it. Just LI and make window around dot it will list all items found. Quote Link to comment Share on other sites More sharing options...
