Hi All
probably very easy solution, but can anyone advise how to delete the layer "AR-FURN-E" on the attached drawing?
also, there is a circle to the right of the building where if you zoom out, a small dot will appear inside, what is this??
cheers :)
133 LG floor.dwg
i have worked it out. LAYDEL was the command i needed. it also deleted the strange dot :)
Sounds like a block, you can not delete a layer if a block is using it.
Just LI and make window around dot it will list all items found.
