What's the macro command for loading lisp
How can appload a lisp from macro i do the following but it open dialog , what's wrong ??
^C^C^_appload ;Ffjdshj.LSP;
  • Replies 29
  • hosyn
    12
  • hmsilva
    9
  • ReMark
    3
  • MSasu
    2
hosyn,
if your lisp file is not in a "Support File Search Path", you must provide the full path, and for instance, your command name would be "test", you could test if was loaded, if not, load it and run the code...
^C^C(if (not c:test) (load "C:/mylisp/Ffjdshj"));test
Henrique
I checked them and unfortunately don't act well:(
^C^C^_appload ;c:\my doc\Ffjdshj.LSP;
Just for load Ffjdshj.lsp
^C^C(load "C:/my doc/Ffjdshj")
or
^C^C(load "C:\\my doc\\Ffjdshj")
Henrique
What's the macro command for loading lisp file from customize bottom toolbar that when i click that bottom load lisp file.
It is getting tiring to continually have to move and merge your threads and remind you to use Code Tags.
Please review the forum posting and code posting guidelines.
I checked them but not work:(
What did you check?
if yhe path you posted is correct and the filename too,
must work!
Henrique
When i locate in custom toolbar and run it i have this result in prompt:
(load "C:
hosyn,
copy and paste here, the command string you have in your custom toolbar, dont type. just copy/paste
Henrique
Edited by hmsilva
typo...
Hosyn, I'm afraid you didn't stated the full path into your first post; please adjust the macro like:
^C^C(load "C:\\my doc\\Ffjdshj.lsp" "Unable to find Ffjdshj.lsp")
And don't forget that the macro should contain a space at end.
Dear Msasu
I copy and paste the above code and
this is the result of yor code:
Command:
Command:
Command: (load "C:
("_>
("_> my doc
("_>
("_> Ffjdshj.lsp" "Unable to find Ffjdshj.lsp")
After the run macro apear (load"c: and after some enter have this result.:?o:)o:)o:)o:)o:)
Copy and paste just this
If it works then add the ^C^C in your macro in a tool.
