kushab Posted June 16, 2013 Share Posted June 16, 2013 Doc1.docx Please tomorow is my deadline I can;t finish if anyone will help me. because i do not now how Quote Link to comment Share on other sites More sharing options...
JD Mather Posted June 16, 2013 Share Posted June 16, 2013 Draw a circle diameter 1.75 Draw a concentric circle diameter 3.5 Attach the dwg of what you have completed so far (the two concentric circles). Quote Link to comment Share on other sites More sharing options...
kushab Posted June 16, 2013 Author Share Posted June 16, 2013 Drawing1.dwg It has some errors how can I improve those and which is the next step. Thanks Quote Link to comment Share on other sites More sharing options...
Organic Posted June 16, 2013 Share Posted June 16, 2013 Honestly, I would start again. Your units are off to start with. Work in metres, not mm. Be accurate with your work. A circle with radius 174.939mm is not the same as a circle with radius 175mm. All your geometry is off like that. Start by drawing the box at the top and the crankshaft below. Do the connecting rod/gears at the end as they are the hardest. Quote Link to comment Share on other sites More sharing options...
nestly Posted June 16, 2013 Share Posted June 16, 2013 Here is the basic process of construction, If you were given this as an assignment, you should have enough training to fill in the rest. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted June 16, 2013 Share Posted June 16, 2013 (edited) Honestly, I would start again. Your units are off to start with. Work in metres, not mm. Be accurate with your work. .... Start by drawing the box at the top and the crankshaft below. Do the connecting rod/gears at the end as they are the hardest. The units are inches, not mm, not meters. Start with the two circles as I CLEARLY STATED in my first response. There is nothing really difficult in the entire drawing, but if you can't do the hard(er) stuff, why even begin? (and there are no gears to be drawn?) One person who doesn't know what they are doing trying to teach another! kushab, I asked you to draw two concentric circles - you went beyond that without first getting that step correct. Your first circle is wrong - so let's start over and keep it more basic. Start a new file. Draw a circle with the diameter 1.75" and attach the file here. Ignore nestly as well. (I'll explain why later.) Are you really using Mechanical 2008 version, or are you using later version? Edited June 16, 2013 by JD Mather Quote Link to comment Share on other sites More sharing options...
JD Mather Posted June 16, 2013 Share Posted June 16, 2013 To draw your first circle. type C on the keyboard and hit Enter. click anywhere on the screen to place the center point of the circle. type D on the keyboard and hit Enter. type 1.75 and hit Enter. Save the file and attach it here. We can finish the entire assignment in about 30-minutes, step-by-step. Quote Link to comment Share on other sites More sharing options...
kushab Posted June 16, 2013 Author Share Posted June 16, 2013 Thanks for helping me, i am starting from the beggining I draw the two circles . Drawing1.dwg Quote Link to comment Share on other sites More sharing options...
kushab Posted June 16, 2013 Author Share Posted June 16, 2013 I draw the first circle as you said. Drawing2.dwg Quote Link to comment Share on other sites More sharing options...
JD Mather Posted June 16, 2013 Share Posted June 16, 2013 OK, now we are getting somewhere. In your two circle drawing you used 1.75 Radius rather than Diameter which resulted in two circles twice as big as they should be. In the second file with just one circle as instructed - you have drawn it correctly. Go ahead and draw the second circle with Diameter 3.5 concentric (same centerpoint) as the first circle. I think you know how to do that now. Quote Link to comment Share on other sites More sharing options...
Organic Posted June 16, 2013 Share Posted June 16, 2013 The units are inches, not mm, not meters.Start with the two circles as I CLEARLY STATED in my first response. There is nothing really difficult in the entire drawing, but if you can't do the hard(er) stuff, why even begin? (and there are no gears to be drawn?) One person who doesn't know what they are doing trying to teach another! Who says it is inches? There are no units shown on the image as far as I can see. For all we know it could be a large piece of mining process equipment and the units are metres. Just because in your opinion you start with the two circles does not mean that is the only way to do it. Perhaps gears was not the best term to loosely use although I meant the circles/pins/whatever joining the connecting rod to the piston and crankshaft. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted June 16, 2013 Share Posted June 16, 2013 Then draw a line from the centers of the circles vertically. type L and hit Enter click one of the circles (AutoCAD should find the center, if not post back and we'll fix that) move your cursor vertically and click for a length on the line about like this image. (don't worry about the angled line yet) Quote Link to comment Share on other sites More sharing options...
JD Mather Posted June 16, 2013 Share Posted June 16, 2013 Now - click on the vertical line and then click on the grip at the center of the circle. Click Right Mouse Button and select Copy. Click Right Mouse Button again and select Rotate. Type -65 and hit Enter. Save and attach the file here. Quote Link to comment Share on other sites More sharing options...
kushab Posted June 16, 2013 Author Share Posted June 16, 2013 I finished the second circle. thanks a lot. Drawing3.dwg Quote Link to comment Share on other sites More sharing options...
JD Mather Posted June 16, 2013 Share Posted June 16, 2013 Go ahead and draw the vertical line as instructed in post #12 & 13. Quote Link to comment Share on other sites More sharing options...
Organic Posted June 16, 2013 Share Posted June 16, 2013 OP, the two circles are not concentric. Turn on the 'Center' osnap and recreate the second circle. Quote Link to comment Share on other sites More sharing options...
kushab Posted June 16, 2013 Author Share Posted June 16, 2013 Is it good, because AUTOCAD didn't find the center of the circle Drawing4.dwg Quote Link to comment Share on other sites More sharing options...
JD Mather Posted June 16, 2013 Share Posted June 16, 2013 Oops, we need to back up, the circles are not concentric (sharing same center point) and the line is not even close to vertical. Delete the second circle and delete the line. Quote Link to comment Share on other sites More sharing options...
kushab Posted June 16, 2013 Author Share Posted June 16, 2013 whiat to do next ? Quote Link to comment Share on other sites More sharing options...
JD Mather Posted June 16, 2013 Share Posted June 16, 2013 Type the command osnaps on the keyboard and hit Enter. Set exactly as shown in image (Endpoint, Center, Intersection). Quote Link to comment Share on other sites More sharing options...
