hi,
i have received a drawing showing coordinates of various points for example
(E 3456.98, N 4276.87) etc.
how can i find the coordinates of other points in the same drawing.
---- i used EN.lisp but it gives wrong coordinates.
plz help
  • Replies 24
  • kallerman
    9
  • Lee Mac
    4
  • CheSyn
    3
  • Tharwat
    2
Posted Images
This is somewhat rudimentary, but could work. Give it a go and let me know if this is what you were looking for. (You can change the text settings if necessary)
(defun c:test ( / point p1 coord xval yval str)
   (while
       (if
           (and
               (setq point (car (entsel "\nSelect a point to label : "))
                       p1 (entget point)
               (= (cdr (assoc 0 p1)) "POINT")
               (setq p1 (entget point)
                     coord (cdr (assoc 10 p1))
                     xval (car coord)
                     xval (rtos xval 2 2)
                     yval (cadr coord)
                     yval (rtos yval 2 2)
               (setq str (strcat "(E " xval ", " "N " yval ")"))
                   (command "_.text" "Justify" "bl" coord "2.0" "" str )
           (princ "\nDid not select a point : ")
Edited by CheSyn
formatting
thnx but how to use it plzzzzzzzzzzz....
CheSyn
The back slash should be forward slash .
(defun c:test ([b][color=blue]\[/color][/b] point p1 coord xval yval str)
And it is a good practice to check if the selected object is matching your desired object name "POINT" to avoid error message
and crashing the routine .
e.g .
(and (setq point (car (entsel "\nSelect a point to label : ")))
      [color=blue]  (eq (cdr (assoc 0 (entget point))) "POINT")[/color]
im thankful for ur support,......
i did both, forward & backward slash,... but it doesnt give correct coordinates,
plz give ur expertise,..
Have you tried to ID the place where a coordinate has been written to see whether it gives the same coordinate as the figures?
Someone might have written coordinates into the drawing and then moved the whole drawing.
I am not familiar with EN.lsp perhaps you could post the routine.
Load it, and call the command with "test" (you can change this to whatever you want). Select a point, and text will show in its place. The command will loop until a point is selected (if you select another entity type).
CheSyn
e.g .
Very good, thank you! Please see the updated code above.
Kallerman,
I have updated the above code - and verified it works in my drawings.
Please try it. If it does not work for you, post a copy of the drawing you are working with. I'm sure someone will be able to help you, as I am leaving on vacation for 10 days.
Edited by CheSyn
i tried few routines and the ones u posted, it gives the same answer with all,..
Untitled.jpghere is attached the bottom left of my drawing area,..
if i set (4400, 3000) as origin the see the results in the screen shot,..
Untitled1.jpgsee the variation in results,....
This will return points in WCS:
(defun c:pt ( / p )
   (while (setq p (getpoint "\nPick point to label: "))
       (entmake
           (list
              '(000 . "MTEXT")
              '(100 . "AcDbEntity")
              '(100 . "AcDbMText")
               (cons 011 (getvar 'ucsxdir))
               (cons 010 (setq p (trans p 1 0)))
               (cons 001 (apply 'strcat (mapcar 'strcat '("E " "\\PN " "\\PZ ") (mapcar 'rtos p))))
               (cons 210 (trans '(0.0 0.0 1.0) 1 0 t))
This will returns points in UCS:
(defun c:pt ( / p )
       (entmake
           (list
              '(000 . "MTEXT")
               (cons 010 (trans p 1 0))
Lee , I can't see the difference between the two routines , but i think the second one - the trans function must be 0 1 and not 1 0 , Am I right ?
well.......... i created a new UCS, then i entered a line from origin (0,0) to point(4400', 3000') ,,, then i moved the whole layout from left bottom corner (4400, 3000) to that point
amd now it gives the correct coordinates,....BUT ALL IN INCHES,.... again a problem,....
58000.53" / 12 = 4833.37' ,...... it means its giving correct coordinates,.... but i need them in feet,
plz help
No, look closer.
I was unaware you were intending to alter the origin, as it was not specified in your original request. I will look into writing something if I have some free time on my vacation. If not, there are many knowledgeable members who can assist you.
Edit: disregard, I was too slow posting.
im thankful to you guys,...
my current problem is y the coordinates are in INCHES,.... ? THEY MUST BE IN FEET,.........
KINDLY GIVE SOLUTION,.....
HERE IS THE CODE IM USING:
(defun Styles()
   ;create text Style
   (if (not (tblsearch "style" "Gen-Text")) (command "-style" "Gen-Text" "Arial.ttf" "A""yes" "No" 2.5 "1" 0 "n" "n"))
   ;create dimension style
   (if (not (tblsearch "DImstyle" "Dim Arrow Ann"))
          (command "dim" "style" "Gen-Text"
           "DIMADEC"     0
           "DIMALT"      0
           "DIMALTD"     2
           "DIMALTF"     1.000
           "DIMALTRND"   0.0000
           "DIMALTTD"    2
           "DIMALTTZ"    0
           "DIMALTU"     2
           "DIMALTZ"     0
           "DIMASZ"      3
           "DIMATFIT"    3
           "DIMAUNIT"    0
           "DIMAZIN"     0
           "DIMBLK"      ""
           "DIMBLK1"     ""
           "DIMBLK2"     ""
           "DIMLDRBLK"   ""
           "DIMCEN"      0
           "DIMCLRD"     7
           "DIMCLRE"     7
           "DIMCLRT"     7
           "DIMDEC"      0
           "DIMDLE"      0.0000
           "DIMDLI"      1.0000
           "DIMEXE"      1.5000
           "DIMEXO"      1.5000
           "DIMFRAC"     0
           "DIMGAP"      1.0000
           "DIMJUST"     0
           "DIMLFAC"     1000.0000
           "DIMLIM"      0
           "DIMLUNIT"    2
           "DIMLWD"      0
           "DIMLWE"      0
           "DIMRND"      0.0000
           "DIMSAH"      0
           "DIMSCALE"    1.0000
           "DIMSD1"      0
           "DIMSD2"      0
           "DIMSE1"      0
           "DIMSE2"      0
           "DIMSOXD"     0
           "DIMTAD"      1
           "DIMTDEC"     0
           "DIMTIH"      0
           "DIMTIX"      0
           "DIMTM"       0.0000
           "DIMTMOVE"    0
           "DIMTOFL"     0
           "DIMTOH"      0
           "DIMTSZ"      0.0000
           "DIMTVP"      0.0000
           "DIMTXSTY"    "Gen-Text"
           "DIMTXT"      2.5000
           "DIMZIN"      0
           "DIMFIT"      5 /e)
         (command "dimstyle" "An" "y" "Dim Arrow Ann" "S" "")
       ) ;progn
     ) ;if
) ;defun
;;-------------------------------------------* error *-----------------------------------------------------
(defun trap1 (errmsg)
          (setq *error* temperr)
          (setvar "clayer" clay)
          (prompt "\n © Bijoy manoharan 2010 www.cadlispandtips.com")
) ;defun
;;-------------------------------------------Set Datum-----------------------------------------------------
(defun C:dat (/ num op sta pga stb pgb)
       (command "cmdecho"0)
       (command "ucs" "w")
   ;;; input station
       (if (not nf-ns) (setq nf-ns 0.000))    ; default number
       (setq NUM (getreal (strcat "\nEnter Eastward datum <" (rtos nf-ns 2 3) ">: ")))
       (if (not num) (setq num nf-ns) (setq nf-ns num))
  ;;; input pgl
       (if (not sf-ss) (setq sf-ss 0.000))    ; default number
       (setq SUM (getreal (strcat "\nEnter Northward datum <" (rtos sf-ss 2 3) ">: ")))
       (if (not sum) (setq sum sf-ss) (setq sf-ss sum))
  ;;; set orign point
       (setq op (getpoint "\nPick datum orgin point: "))
       (setq sta (car op))
       (setq pga (cadr op))
       (setq stb (- sta num))
       (setq pgb (- pga sum))
       (command "ucs" "m" (list stb pgb 0))
       (prompt "\nOrigin moved to new loaction - Enter Command EN to place Text")
) ;defun
;;-------------------------------------------Place Text----------------------------------------------------
(defun C:EN (/ enp1 ex ey dy ptl e TextObj vlText)
        (setq clay (getvar "clayer"))
        (setq temperr *error*)
        (setq *error* trap1)
        (if (not (tblsearch "layer" "Text Coordinate")) (command  "-LAYER" "N" "Text Coordinate" "C" "7" "Text Coordinate" "LT"  "Continuous" "Text Coordinate""LW" "0.15" "Text Coordinate" ""))
        (Styles)
        (command "CLAYER" "Text Coordinate")
        (command "-DIMSTYLE" "r" "Dim Arrow Ann")
(setq ptlist nil) ; for while command
 (while
         (setq enp1 (getpoint "\nPick Coordinate point: "))
         (setq ex (car enp1))  ;x coord
         (setq ey (cadr enp1)) ;y coord
         (setq enx (rtos ex 2 3))
         (setq eny (rtos ey 2 3))
         (setq ptl (getpoint "\nPick text location: "))
         (SETVAR 'DIMTAD 0) ; Justification centered
         (SETVAR 'DIMLDRBLK "_ORIGIN") ;; leader arrow
       (command "leader" enp1 ptl "" (strcat "E " enx) (strcat "N " eny) "")
       (setq TextObj (entlast))
  (vl-load-com)
       (setq vlText (vlax-ename->vla-object TextObj))
       (vlax-put-property vlText 'backgroundfill :vlax-true)  ; background mask
        (SETVAR 'DIMTAD 1 ) ; Justification above
        (setvar "DIMLDRBLK" ".") ;;leader arrow
        (setq ptlist (append ptlist (list pt))) ; to stop while command
    ) ;progn
  ) ;while
) ; defun
;;----------------------------------------Back to UCS World-----------------------------------------------------
(defun C:uw ()
       (command "ucs" "w")
       (prompt "\nUCS Origin is set to World")
) ; defun
(princ "\nEasting & Northing Lisp | © Bijoy manoharan 2010 | [url="http://www.cadlispandtips.com"]www.cadlispandtips.com[/url] |")
(princ "\nLisp Commands:DAT(to set Datum point),UW(Ucs World),EN(to Coordinate text)")
;;----------------------------------------------End-----------------------------------------------------
Edited by SLW210
Add Code Tags!!
The short answer is that your new drawing is not in the correct drawing units, and should probably be scaled to suit.
If you want to adjust your existing lisp, then look at the "rtos" function which needs the correct mode to do what you want. But if you alter the lisp for this drawing, then will all the rest of your drawings misbehave?
P.S. you should probably edit your previous post to enclose the lisp code in code quotes otherwise the Mods will be getting at you :shock:
Call me old school, but as a civil engineer I still work "unitless". I would have approached a drawing like this two fold. Assuming I received it from a client (presumably an architect), I would have started a new base civil drawing in decimal feet and XREF'd the drawing in at 1/12 and moved and rotated the XREF to a new origin (if necessary).
I also do this with my many of my own drawings (sans the 1/12 scaling) since we start survey projects in an assumed coordinate system; ie N=10,0000 E=5,000 Elev=100 and then post process the local control onto State Plane Coordinates and reference onto our GIS mapping.
