bosch Posted August 27, 2013 Share Posted August 27, 2013 The differents between autocad 2000 and autocad 2010 Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 27, 2013 Share Posted August 27, 2013 How much time do you have? Quote Link to comment Share on other sites More sharing options...
Tuns Posted August 27, 2013 Share Posted August 27, 2013 2010 is cleaner looking, easier to work with, and easier to customize than ACAD 2000. Quote Link to comment Share on other sites More sharing options...
Tiger Posted August 27, 2013 Share Posted August 27, 2013 Well, to see the differences up to the latest version, download the trial version from Autodesks homepage and see for yourself. So much has happened that I don't think anyone can list it all. Now, if the question is 'Can I go from 2000 to 2010 and still feel at home and produce drawings?' Hard question, depends on if you want to do it mostly I'd say. Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 27, 2013 Share Posted August 27, 2013 (edited) A partial list... The "Ribbon" including Tabs and Panels. Dynamic blocks. External references. Improved performance. Hatch improvements. Publishing. 3D enhancements. New commands added. Constraints/parametrics. Annotative scaling of hatches, text, linetypes, etc. Multileaders. Want more? The CUI. Hyperlinks. Contextual MTEXT. Tables. The QAT. eTransmit. Tool palettes. Loft command. NAV wheel. Mesh modeling. The "Gizmo". Convert to Solid. Convert to Surface. Send to 3D printer. Layer translator. Sectionplane. Scalelists. Sheet set manager. Action recorder. Fields. Datalinks. CAD standards checker. Page setup manager. AutoDesk Seek. The CommCenter. I haven't lost you yet have I? LoL Will you be requiring detailed information on each of the above next? Edited August 27, 2013 by ReMark Quote Link to comment Share on other sites More sharing options...
rkent Posted August 27, 2013 Share Posted August 27, 2013 The differents between autocad 2000 and autocad 2010 Here are some of the highlights, by no means is the list comprehensive. 2000i- trim to objects within blocks fillet anc chamfer multiple polylines enhanced rectang command plot merged lines in most plot device drivers new file open and navigation dialog 2002- associative dimensioning block attribute manager layer previous enhanced spell checking 2004- express tools gradient hatch fills mtext enhancements true color and color book support match properties enhancements xopen command, xref notification, xref multiple files at once EDU drawing warning qnew command allows setup of template to be used publish multiple drawings at once 2005- field text sheet set manager tables draworder texttofront layer manager adds filter tree mtext suports fields, color background hatches can be trimmed background plotting copy command defaults to multiple 2006- dynamic input enhanced grips CUI dimension flip arrows create separate hatches hatch editing enhanced join command copy undo option added fillet and chamfer zero radius with shift key offset command enhancements trim and extend toggle with shift key mtext editor is WYSIWYG mtext supports formatting using bullets, numbers, alpha drawing recovery manager temp override keys added scalelistedit command line hidden with CTRL+9 quickcalc autocomplete at command line 2007- 3D modeling - helix, loft, polysolid, pyramid, sweep 3D editing - presspull, imprint, sectionplance, flatshot 3D viewing- 3dforbit, 3dmove, 3drotate, chspace xref palette DUCS added to status bar fields - added autolisp variables slice with surface object 2008- Annotation property Multiline Leaders - MLeaderStyle, MLeaderAlign, MLeaderCollect, MLeaderEdit, AiMLeaderEditAdd Layer Dimming and Layout Overrides Dimensions - DimBreak, DimInspect, DimJogLine, DimSpace DimArc extension line, DimAng Quadrant option Dynamic blocks - displays tooltips with the purpose of grips CopyMode system variable new LayLockFadeCtl system variable LayIso command can lock and fade instead of freezing Mtext - annotative scaling, column wrapping, and spacing between paragraphs. Xclip adds invert option 2009- Ribbon Layers dialog into a palette (ClassicLayer command added) Quick Properties Quick Views Ribbon (dashboard removed) ExportLayout GenerateSection Big Red A application menu, QAT quick access toolbar rollover tips extended tooltips spell check - real time checking 2010- 2D parametrics - Geometric and Dimensional Constraints Super commands - Attach, Adjust, Clip, MeasureGeom, Ulayers, TextEdit MeasureGeom segment editing - hold down Ctrl during scale, rotate, move SECTIONPLANE, SECTIONPLANEJOG, SECTIONPLANETOBLOCK, SECTIONPLANESETTINGS Parameters Manager mtext grips added triangle grips for editing 2011 - Grid - lines in 2D Ribbon updates, added 3D Basic WS Grip added to polyline Selection cycling enhancement - SC toggle at bottom of screen Multifunctional grips SelectSimilar command added, HideObjects, Unhide, AddSelected command added HideObjects command added IsolateObjects, UnisolateObjects 3D object snaps 2012 - Autocomplete command VpControl viewport controls - navigation, views and visual styles on screen Ribbon sizing - three minimized settings mtext background remembers last used fill color and offset grip with lengthen option grips are multi-functional for more objects - arcs, assoc arrays, dims, elliptical arcs, lines, mleaders, 3d faces edges vertices Associative Arrays, grips editing Blend - connects two objects using a spline Extend works with Splines, Fillet works with Splines Support for multiple paths for PMP, PC3, CTB, STB files Snap can be set to work only while in a command, SnapMode sysvar Drawing Views - 2D drawing views from 3D model and 1st or 3rd angle projection Base View 3D editing - ChamferEdge and FilletEdge added Loop option 3D editing - OffsetEdge MeshCap has options added Point Clouds enhanced 2013 - drawing views additions, create details and sections Properties - shows realtime previews for colors, lineweights, lintypes, transparency, layers Array - displays contextual tab, uses default values to show instant previews Offset has preview before picking Polylines - reversed plines with varying widths handled with new sysvar PlineReverseWidths 2014- command line - spell checking, synonyms, block names, layer names, hatch name, visual styles, dim style autocorrect - after three misspellings the word is added autocorrect - after three misspellings the word is added type at command line to change layer, text style, dim style, visual style type at command line with hatch name to start hatch command type at the command line with a block name and the insert command will start mid string search at command line Drawing Tabs - tabs displayed for each drawing Chamfer command closes polylines Filleting polylines will close polylines Layers - merge selected layers in layer manager (LAYERDLGMODE must equal 1) Xref layer names are not shown in the properties palette Xrefs can be selected in quantities and the path or xref type changed in-mass Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 27, 2013 Share Posted August 27, 2013 Surely you jest when you say "by no means is the list comprehensive"? Your list details everything my list jumped over! Now you have gone and really scared the OP. Quote Link to comment Share on other sites More sharing options...
rkent Posted August 27, 2013 Share Posted August 27, 2013 Surely you jest when you say "by no means is the list comprehensive"? Your list details everything my list jumped over! Now you have gone and really scared the OP. There is a lot more than that to each release, those are the highlights for me. Going from 2000 to 2014 is a huge jump and I would imagine plotting would be the biggest challenge otherwise it is still just lines and circles. Quote Link to comment Share on other sites More sharing options...
Tuns Posted August 27, 2013 Share Posted August 27, 2013 My God. ಠ_ಠ Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 27, 2013 Share Posted August 27, 2013 The OP just decided not to upgrade as it will be time to retire before he learns all the new stuff. LoL Quote Link to comment Share on other sites More sharing options...
PotGuy Posted August 27, 2013 Share Posted August 27, 2013 I got lost about half way. Quote Link to comment Share on other sites More sharing options...
rkent Posted August 27, 2013 Share Posted August 27, 2013 The OP just decided not to upgrade as it will be time to retire before he learns all the new stuff. LoL ReMark and everyone - I think we should come up with a list of the biggest developments of AutoCAD for the past releases, say r13 to today. This might include things we don't like (Ribbon for some) or things we don't make use of (3D for some). I haven't thought about it a lot but off the top of my head I would nominate: Ribbon Properties Mtext 3D enhancements (I will have to get more specific) Tool palettes Annotative properties multiple layouts Anyone want to add to the list? Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 27, 2013 Share Posted August 27, 2013 I might take a shot at it when I have a moment. Quote Link to comment Share on other sites More sharing options...
Tyke Posted August 27, 2013 Share Posted August 27, 2013 I might take a shot at it when I have a moment. Boy guys (ReMark and others) that is a mamoth Task. But where is the OP? Perhaps he is already in hospital suffering from a heart attack. I had never realised that so much had happened! Quote Link to comment Share on other sites More sharing options...
rkent Posted August 27, 2013 Share Posted August 27, 2013 Boy guys (ReMark and others) that is a mamoth Task. But where is the OP? Perhaps he is already in hospital suffering from a heart attack. I had never realised that so much had happened! OP? We don't really care about the OP in any thread, other than for them to provide a topic for us to beat to death. Quote Link to comment Share on other sites More sharing options...
Tuns Posted August 27, 2013 Share Posted August 27, 2013 You should put a disclaimer there saying, "No actual animals were harmed in the making of this photo." Also I really like the addition of the CUI to AutoCAD... Mostly because I'm on LT but it is very nice to have none the less. Quote Link to comment Share on other sites More sharing options...
rkent Posted August 27, 2013 Share Posted August 27, 2013 I am attaching an xls file with a fairly comprehensive list of new features for each release of AutoCAD, enjoy. Something I have been compiling for a while now from different sources. AutoCAD release details rkent.xlsx Quote Link to comment Share on other sites More sharing options...
tzframpton Posted August 27, 2013 Share Posted August 27, 2013 ReMark and everyone - I think we should come up with a list of the biggest developments of AutoCAD for the past releases, say r13 to today. This might include things we don't like (Ribbon for some) or things we don't make use of (3D for some). I haven't thought about it a lot but off the top of my head I would nominate: Ribbon Properties Mtext 3D enhancements (I will have to get more specific) Tool palettes Annotative properties multiple layouts Anyone want to add to the list? Some key added items to your list off the top of my head: 2D: Dynamic Blocks Tables Multileaders Sheet Set Manager 3D: Mental Ray rendering engine Photometric Lighting Parametric Solids Materials Quote Link to comment Share on other sites More sharing options...
vlisp Posted January 11, 2015 Share Posted January 11, 2015 ReMark and everyone - I think we should come up with a list of the biggest developments of AutoCAD for the past releases, say r13 to today. This might include things we don't like (Ribbon for some) or things we don't make use of (3D for some). I haven't thought about it a lot but off the top of my head I would nominate: Ribbon Properties Mtext 3D enhancements (I will have to get more specific) Tool palettes Annotative properties multiple layouts Anyone want to add to the list? If you are drawing in 2D there in no big difference between 2000 and 2010. AutoCad 2000 support Vlisp, so you can make anything for 2D drawing. Quote Link to comment Share on other sites More sharing options...
nestly Posted January 11, 2015 Share Posted January 11, 2015 If you are drawing in 2D there in no big difference between 2000 and 2010 ... and there's no big difference between these two versions either because you can make calls with either Quote Link to comment Share on other sites More sharing options...
