LINHOREKA Posted September 1, 2013 Share Posted September 1, 2013 (edited) Hi, this lisp is working in 2D only: it generate a perspective view from a selected 2D plan or elevation. 1. Command: P2D 2. Select the source frame (trapezoid polyline) of the plan or elevation 3. Select drawing objects in that source plan or elevation 4. Select destination frame >>> a new perspective drawing would be draw arcordingly (see image and example drawing) 5. Repeat step 4 until you select none It is working only with straight lines, straight polylines and points. Pretty useful when you want to take a leap up from your 2D, for but donot have time to create a 3D model. New version on Apps Exchange Store, extrusion enabled P2D EXAMPLE.dwg P2D command.LSP Edited October 8, 2013 by LINHOREKA Update link of new version 1 Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted September 1, 2013 Share Posted September 1, 2013 Thank you for sharing your program LINHOREKA To provide some food for thought, you might be interested in this outstanding program by Sean Tessier Quote Link to comment Share on other sites More sharing options...
LINHOREKA Posted September 2, 2013 Author Share Posted September 2, 2013 (edited) Wow, with Sean Tessier, we can make 3D street art ! There is another kind of simple perspective 2D like this: A profile + 1 vanishing point = This image (from CAD APLUS) Edited September 2, 2013 by LINHOREKA Quote Link to comment Share on other sites More sharing options...
nod684 Posted September 2, 2013 Share Posted September 2, 2013 nice one! does this work for blocks too? Quote Link to comment Share on other sites More sharing options...
LINHOREKA Posted September 2, 2013 Author Share Posted September 2, 2013 No, it works only with elementary objects of straight lines and polylines. Try lisp suggested by Lee Mac, works with curves, hatches. But no block avaiable neither ! I found my lisp has an advantage: it can transform from any trapezoid frames to any others. I test to make 3D street arts and here it is: 1. If objects lay inside the frame polylines, it is ok 2. If objects lay outside, it fails (not yet understand why ) Anyway, it is interesting. Someday I would upgrade it to work with all objects, and correct this trouble. P2D EXAMPLE.dwg Quote Link to comment Share on other sites More sharing options...
LINHOREKA Posted September 2, 2013 Author Share Posted September 2, 2013 Ah, i work it out: the objects cannot go too high over the horizontal sky line ! Here is another example shows how it work well enough: It implies 3D street art need alot of area if draw objects extrude up, but less area if draw objects extrude down ! That is why valley is prefered, while moutains is not Quote Link to comment Share on other sites More sharing options...
SEANT Posted September 2, 2013 Share Posted September 2, 2013 Hey guys, thanks for the mention. Perspective transform is an interesting field. From what I can see, LINHOREKA, we both used a similar process, as did maicy in the links below. The alternative is straight matrix manipulation as demoed by SOFITO_SOFT and Kean (Through the Interface). The links here show some interesting variations on the theme. Those for theswamp.org will require registration. It is such a good site, though, any AutoCAD developer would be happy they made the effort. http://www.theswamp.org/index.php?topic=36905.0 http://www.theswamp.org/index.php?topic=37183.0 http://through-the-interface.typepad.com/through_the_interface/2013/08/applications-for-linear-algebra-straightening-out-perspective.html http://through-the-interface.typepad.com/through_the_interface/2013/08/update-on-the-project-to-de-skew-images-inside-autocad.html http://through-the-interface.typepad.com/through_the_interface/2013/08/generating-png-files-for-de-skewed-portions-of-perspective-images.html Quote Link to comment Share on other sites More sharing options...
LINHOREKA Posted September 24, 2013 Author Share Posted September 24, 2013 Hi everyone, new version is coming : (but not yet ) 1 Quote Link to comment Share on other sites More sharing options...
LINHOREKA Posted October 4, 2013 Author Share Posted October 4, 2013 Hi, New Version on AutoCAD Exchange Store: Your 2D Perspective New Feature: Extrusion ! It is now quite handy for drafters who want to add some 3D views in technical drawings, but too lazy (like me) to try managing the 3D Model stuff. Quote Link to comment Share on other sites More sharing options...
SEANT Posted October 4, 2013 Share Posted October 4, 2013 This looks excellent. Very impressive. And congratulations on your Exchange listing. Quote Link to comment Share on other sites More sharing options...
LINHOREKA Posted October 4, 2013 Author Share Posted October 4, 2013 Sean, you can do it much better than me. Mine doesnot work with curves, hatches nor texts: too complicated for me coding those with Lisp. The only one thing better in my routine is: it is handy, all in one command, and you can start next command by picking on the new created plines of current command. Actually it is my come back to AutoLisp language. I stop working with Lisp for years and even new to vla, vlax, vlr functions Quote Link to comment Share on other sites More sharing options...
leyo32 Posted October 9, 2013 Share Posted October 9, 2013 need help> this feature is great, need help coz when i select the destination frame it turned 180 degress instead of 90 deg. so its coming horizontal instead of vertical, kindly someone teach me to reset it to previous. thanks! Quote Link to comment Share on other sites More sharing options...
LINHOREKA Posted October 9, 2013 Author Share Posted October 9, 2013 Just click R to rotate it all around. And make sure you have installed the new version avaiable on the Autodesk App Exchange Store. You are using AutoCAD Architecture ? Does it work with Architecture ? Quote Link to comment Share on other sites More sharing options...
leyo32 Posted October 9, 2013 Share Posted October 9, 2013 yes, i am using Acad architecture. this feature working! thanks for the info. Quote Link to comment Share on other sites More sharing options...
leyo32 Posted October 9, 2013 Share Posted October 9, 2013 Linhoreka just installed the new version and its working great!!! Thanks a lot for the help! Quote Link to comment Share on other sites More sharing options...
LINHOREKA Posted November 12, 2013 Author Share Posted November 12, 2013 This is a more detail explain of how it works: http://www.yourspreadsheets.co.uk/your2dperspective---how-it-works.html Thanks 1 Quote Link to comment Share on other sites More sharing options...
Sooshiant Posted August 19, 2022 Share Posted August 19, 2022 Awesome Quote Link to comment Share on other sites More sharing options...
