dahabit Posted September 19, 2013 Share Posted September 19, 2013 (edited) Hi Everyone, I just upgraded to autocad 2014 so far everything has been running smoothly only only problem so far is I am not able to modify an existing wall that was drawn in the previous version. See attachment. Anyone has any idea as to why this is? http://i.imgur.com/kLVjydX.png Thanks. EDIT 1: I just noticed that I can't draw the wall either. Previously I could go the tool palette or go into draw and draw some walls, now I don't see that option anywhere. Edited September 19, 2013 by dahabit Quote Link to comment Share on other sites More sharing options...
tzframpton Posted September 19, 2013 Share Posted September 19, 2013 Looks to me like you're in the plain AutoCAD profile. Make sure you're in the AutoCAD Architecture profile. You must start the program from the Architecture Profile, you cannot open AutoCAD then switch to the Architecture Profile - the AEC Tools only load when you start the program in the correct Profile. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted September 20, 2013 Share Posted September 20, 2013 Are you using AutoCAD Architecture 2014? Quote Link to comment Share on other sites More sharing options...
dahabit Posted September 20, 2013 Author Share Posted September 20, 2013 Looks to me like you're in the plain AutoCAD profile. Make sure you're in the AutoCAD Architecture profile. You must start the program from the Architecture Profile, you cannot open AutoCAD then switch to the Architecture Profile - the AEC Tools only load when you start the program in the correct Profile. Thank you, it worked. Quote Link to comment Share on other sites More sharing options...
