Madruga_SP Posted November 26, 2013 Share Posted November 26, 2013 Hi guys! I need some help... I'm trying to add dimension with the strech actions. Anybody can help me out please?? Thank in advance TEST BLOCK.dwg Quote Link to comment Share on other sites More sharing options...
steven-g Posted November 26, 2013 Share Posted November 26, 2013 Like this ? TEST BLOCK.dwg Quote Link to comment Share on other sites More sharing options...
Madruga_SP Posted November 26, 2013 Author Share Posted November 26, 2013 Perfect steven! Thank you very much Actually I need to do something more specific. Take a look in my attached file, please. In my file is explaining better my task. Thank you TEST BLOCK.dwg Quote Link to comment Share on other sites More sharing options...
steven-g Posted November 26, 2013 Share Posted November 26, 2013 I'm not sure what you want to do Quote Link to comment Share on other sites More sharing options...
Mike_Taylor Posted November 26, 2013 Share Posted November 26, 2013 So, you're wanting the dimension to be divided by 1250 the multiplied by 100 and to update dynamically? Quote Link to comment Share on other sites More sharing options...
Madruga_SP Posted November 26, 2013 Author Share Posted November 26, 2013 yes Mike!!!! I wanna learn too. Quote Link to comment Share on other sites More sharing options...
Madruga_SP Posted November 27, 2013 Author Share Posted November 27, 2013 Hey guys, I've created a dinamic block just like I wanted to. But I wasted a lot of time, because I have to create many dimensions style for each block. So, I'm posting my block and some advice will be really appreciated. I'm looking for the smarter way to make the block, because I have to create more like that! Thank you! MARGEM 4DOBx45.dwg Quote Link to comment Share on other sites More sharing options...
Madruga_SP Posted November 28, 2013 Author Share Posted November 28, 2013 Hey guys, My dinamic block there is a stamp and I need to fill it in. But I can't fill it without explode the block. How Can I fill the stamp without explode?? Thank in advance Quote Link to comment Share on other sites More sharing options...
dbroada Posted November 28, 2013 Share Posted November 28, 2013 You basically have your CARIMBO(?) block held within the MARGEM block. You need to get the CARIMBO to the same level. I would propose openning MARGEM in the block editor and then explode CARIMBO. Save the changes and the block should work as you want. You may have to BATTMAN the block to get the attributes in the desired order. Quote Link to comment Share on other sites More sharing options...
Madruga_SP Posted November 28, 2013 Author Share Posted November 28, 2013 Thanks for replay, dbroada You basically have your CARIMBO(?) block held within the MARGEM block. You need to get the CARIMBO to the same level. I would propose openning MARGEM in the block editor and then explode CARIMBO.Yes, I did that. But didn't work.When I change the block in the visibility parameter didn't work properly. Quote Link to comment Share on other sites More sharing options...
dbroada Posted November 28, 2013 Share Posted November 28, 2013 In that case I would still explode CARIMBO and reconstruct the visibility parameters from scratch. Quote Link to comment Share on other sites More sharing options...
Madruga_SP Posted November 28, 2013 Author Share Posted November 28, 2013 I'm trying to do that... test.dwg Quote Link to comment Share on other sites More sharing options...
dbroada Posted November 28, 2013 Share Posted November 28, 2013 I didn't realise you had two title blocks. I'm afraid attributes and visibility states don't work well together, especially if you use the same tag name more than once. I don't have time to look in to this right now but I would investigate scaling the block elements rather than use visibility states. Steven-g (?) has a few tricks using look up tables that may help here. Quote Link to comment Share on other sites More sharing options...
Mike_Taylor Posted November 28, 2013 Share Posted November 28, 2013 Sorry for the lack of response, we got slammed with a tight deadline on Tuesday. First create a 2 lines (one in the X-direction and one in the Y) line the from the 2 points you are getting your dimensions from (put these on a non plot layer). From there override the text in the dimension, right click, insert field, select object form the drop down, select formula, in the box where you can type stuff in on the bottom right, right click again slect insert field, once again select object, select the object option, select your line and choose the length parameter. From there you can divide and multiply as needed. Just ensure the 2 lines you are measuring are being added to your stretch parameter. As for your title block attributes, a look-up table would be best. You can use that to re-position and scale attributes to acheive what you are looking for. Unfortunately this is all I will likely have time to post today as I have 2 jobs to complete. Quote Link to comment Share on other sites More sharing options...
Madruga_SP Posted November 28, 2013 Author Share Posted November 28, 2013 Thank for the tip Mike, If you post an example is better to understand. Maybe when you have a free time, you could help me out... Thank you very much Quote Link to comment Share on other sites More sharing options...
steven-g Posted November 28, 2013 Share Posted November 28, 2013 Yeah the same tag names in a block is a definate no-no, it doesn't work, and communication of attributes between visibility states doesn't work either. I would look at the scaling suggestion, or just the basic block and scale it when it is inserted. Quote Link to comment Share on other sites More sharing options...
Madruga_SP Posted November 28, 2013 Author Share Posted November 28, 2013 Hi Steven, Even if I change tag names, it didn't work... i don't know what to do. Attached a example, please! test.dwg Quote Link to comment Share on other sites More sharing options...
Madruga_SP Posted November 29, 2013 Author Share Posted November 29, 2013 Hi guys! I'm trying to make other block using lookup parameter just like Mike had adviced me. But I need a help, every time a change the block's size I lost the origin... I'd like the all the block's size keep the same origin (0,0,0). Anyone Can help me out, please?? Thank in advance test-lookup.dwg Quote Link to comment Share on other sites More sharing options...
steven-g Posted November 29, 2013 Share Posted November 29, 2013 OK how about this as an example, I only used it for the title attribute, when you insert the block it will prompt for the title, but you have to change the visibility state before it starts working (before then all you will see is ----), but then the information is inside the block and you can then have as many visibility states as you want. Take a look see if this is OK test (2).dwg Quote Link to comment Share on other sites More sharing options...
Madruga_SP Posted November 29, 2013 Author Share Posted November 29, 2013 Thanks for the quick replay, So, I'm trying to create a lookup and put the dimension scale and visibility state in it. But I'm still have a problem with the attribute, I've already changed all tag's names and didn't work... Any help will be really apreciated. Thank you Quote Link to comment Share on other sites More sharing options...
