121madhu Posted December 3, 2013 Share Posted December 3, 2013 1. In utilities need offset the line 2m. and 1.5m and 4m….etc. Every line create the new layer (new layer name user defined ) no need color. 2. the layer name I defined as the line type Example:- layer name: MV Electrical (---MV Electrical---MV Electrical---MV Electrical---MV Electrical---) And how much distance between the text also user defined No need line between text to text Thanks I am sorry for my poor English Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 3, 2013 Share Posted December 3, 2013 Please post a example dwg or image. To have different spacing of the text would mean that it is not a line type but text and lines, you can though create the smae linetype many times with different text spacing. *WATER_MAIN,Water main ----W----W----W----W----W----W-- A,40,-4.0,["W",STANDARD,S=1.8,R=0.0,X=-1.8,Y=-2.0],-4 *WATER_MAIN2,Water main2 ----W----W----W----W----W----W-- A,20,-5.08,["W",STANDARD,S=1.8,R=0.0,X=-1.8,Y=-.9],-3 Quote Link to comment Share on other sites More sharing options...
121madhu Posted December 4, 2013 Author Share Posted December 4, 2013 hi sir check this pic. Quote Link to comment Share on other sites More sharing options...
satishrajdev Posted December 4, 2013 Share Posted December 4, 2013 TRY THIS :- *Give offset distance in + or - according to your offset direction. (DEFUN C:TEST (/ A B C) (VL-LOAD-COM) (WHILE (SETQ A (GETSTRING "\nSpecify Name of New Layer :")) (SETQ B (CAR (ENTSEL "\nSelect Line to Offset :"))) (INITGET 1) (SETQ C (GETDIST "\nSpecify Offset Distance :")) (VLA-ADD (VLA-GET-LAYERS (VLA-GET-ACTIVEDOCUMENT (VLAX-GET-ACAD-OBJECT)) ) A ) (VLA-OFFSET (VLAX-ENAME->VLA-OBJECT B) C ) (VLA-PUT-LAYER (VLAX-ENAME->VLA-OBJECT (ENTLAST)) A) ) (PRINC) ) Quote Link to comment Share on other sites More sharing options...
Tharwat Posted December 4, 2013 Share Posted December 4, 2013 Satish , do you know that the getstring function with enter means not nil value ? Quote Link to comment Share on other sites More sharing options...
satishrajdev Posted December 4, 2013 Share Posted December 4, 2013 Oops... i didnt realise that.... how to avoid that Tharwat Quote Link to comment Share on other sites More sharing options...
Tharwat Posted December 4, 2013 Share Posted December 4, 2013 Oops... i didnt realise that.... how to avoid that Tharwat You can add the operator (not equal to [/=] or (not (eq .....))) to avoid THAT. Quote Link to comment Share on other sites More sharing options...
satishrajdev Posted December 4, 2013 Share Posted December 4, 2013 SOMETHING LIKE THIS ???? (DEFUN C:TEST (/ A B C) (VL-LOAD-COM) (WHILE (WHILE (OR (= A NIL) (= A "")) (SETQ A (GETSTRING "\nSpecify Name of New Layer :")) ) (SETQ B (CAR (ENTSEL "\nSelect Line to Offset :"))) (INITGET 1) (SETQ C (GETDIST "\nSpecify Offset Distance :")) (VLA-ADD (VLA-GET-LAYERS (VLA-GET-ACTIVEDOCUMENT (VLAX-GET-ACAD-OBJECT)) ) A ) (VLA-OFFSET (VLAX-ENAME->VLA-OBJECT B) C ) (VLA-PUT-LAYER (VLAX-ENAME->VLA-OBJECT (ENTLAST)) A) ) (PRINC) ) Quote Link to comment Share on other sites More sharing options...
Tharwat Posted December 4, 2013 Share Posted December 4, 2013 This is enough ... (while (/= (setq A (getstring "\n Specify Name of New Layer :")) "") ..... Quote Link to comment Share on other sites More sharing options...
satishrajdev Posted December 4, 2013 Share Posted December 4, 2013 Thank you Quote Link to comment Share on other sites More sharing options...
Tharwat Posted December 4, 2013 Share Posted December 4, 2013 Thank you Not a problem ... Quote Link to comment Share on other sites More sharing options...
121madhu Posted December 4, 2013 Author Share Posted December 4, 2013 thank you satish & tharwat my request specify which side offset and continue this lisp when i press Esc. another one is line type Quote Link to comment Share on other sites More sharing options...
satishrajdev Posted December 4, 2013 Share Posted December 4, 2013 Your welcome, But I didn't get what you said next, what you want to do exactly....specify clearly or give example Quote Link to comment Share on other sites More sharing options...
satishrajdev Posted December 5, 2013 Share Posted December 5, 2013 Try this :- (DEFUN C:TEST (/ A B C D) (VL-LOAD-COM) (WHILE (/= (SETQ A (getstring "\nSpecify Name of New Layer :")) "") (SETQ B (CAR (ENTSEL "\nSelect Line to Offset :"))) (INITGET 1) (SETQ C (GETDIST "\nSpecify Offset Distance :")) (SETQ D (GETPOINT "\nSpecify Point on Side to Offset :")) (VLA-ADD (VLA-GET-LAYERS (VLA-GET-ACTIVEDOCUMENT (VLAX-GET-ACAD-OBJECT)) ) A ) (VLA-OFFSET (VLAX-ENAME->VLA-OBJECT B) (POINTSIDE B D) ) (VLA-PUT-LAYER (VLAX-ENAME->VLA-OBJECT (ENTLAST)) A) ) (PRINC) ) (DEFUN POINTSIDE (OBJ PNT / P1 PA P2) (SETQ P1 (VLAX-CURVE-GETCLOSESTPOINTTO OBJ (TRANS PNT 1 0)) PA (VLAX-CURVE-GETPARAMATPOINT OBJ P1) ) (IF (EQUAL '(0.0 0.0 0.0) (VLAX-CURVE-GETSECONDDERIV OBJ PA) 1e-8 ) (SETQ P1 (VLAX-CURVE-GETPOINTATPARAM OBJ (FIX PA)) P2 (VLAX-CURVE-GETPOINTATPARAM OBJ (1+ (FIX PA))) ) (SETQ P2 (MAPCAR '+ P1 (VLAX-CURVE-GETFIRSTDERIV OBJ PA))) ) (IF (MINUSP (SIN (- (ANGLE P1 PNT) (ANGLE P2 PNT)))) (SETQ C (- C)) (SETQ C (+ C)) ) ) Quote Link to comment Share on other sites More sharing options...
121madhu Posted December 5, 2013 Author Share Posted December 5, 2013 yes i am looking this its works perfect thank you very much satish. i am create this line-type and loaded *TELECOMLINE,TELECOM TELECOM TELECOM TELECOM TELECOM TELECOM TELECOMA,.1,-.1,["TELECOM",STANDARD,S=.1,R=0.0,X=-0.1,Y=-.05],-25 *SPARE_LINE,SPARE line ----SPARE----SPARE----SPARE----SPARE----SPARE----SPARE-- A,.1,-.1,["SPARE",STANDARD,S=.1,R=0.0,X=-0.1,Y=-.05],-25 *STORM WATER_LINE,STORM WATER line ----STORM WATER----STORM WATER----STORM WATER----STORM WATER----STORM WATER----STORM WATER-- A,.1,-.1,["STORM WATER",STANDARD,S=.1,R=0.0,X=-0.1,Y=-.05],-25 *MV ELECTRICAL_LINE,MV ELECTRICAL line ----MV ELECTRICAL----MV ELECTRICAL----MV ELECTRICAL----MV ELECTRICAL----MV ELECTRICAL----MV ELECTRICAL-- A,.1,-.1,["MV ELECTRICAL",STANDARD,S=.1,R=0.0,X=-0.1,Y=-.05],-25 *ELECTRICITY_LINE,ELECTRICITY line ----ELECTRICITY----ELECTRICITY----ELECTRICITY----ELECTRICITY----ELECTRICITY----ELECTRICITY-- A,.1,-.1,["ELECTRICITY",STANDARD,S=.1,R=0.0,X=-0.1,Y=-.05],-25 *LANDSCAPING_LINE,LANDSCAPING line ----LANDSCAPING----LANDSCAPING----LANDSCAPING----LANDSCAPING----LANDSCAPING----LANDSCAPING-- A,.1,-.1,["LANDSCAPING",STANDARD,S=.1,R=0.0,X=-0.1,Y=-.05],-25 *IRRIGATION_LINE,IRRIGATION line ----IRRIGATION----IRRIGATION----IRRIGATION----IRRIGATION----IRRIGATION----IRRIGATION-- A,.1,-.1,["IRRIGATION",STANDARD,S=.1,R=0.0,X=-0.1,Y=-.05],-25 example:- when i offset line layer name:- TELECOM so my line type in layer also telecom its possible or not Quote Link to comment Share on other sites More sharing options...
satishrajdev Posted December 5, 2013 Share Posted December 5, 2013 Have you created your linetype of your own...if yes then where have you save that.... Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 6, 2013 Share Posted December 6, 2013 Just need to add this line as well (VLA-PUT-LINETYPE (VLAX-ENAME->VLA-OBJECT (ENTLAST)) A) Quote Link to comment Share on other sites More sharing options...
121madhu Posted December 7, 2013 Author Share Posted December 7, 2013 Have you created your linetype of your own...if yes then where have you save that.... yes and save my desktop name ma.lin (VLA-PUT-LINETYPE (VLAX-ENAME->VLA-OBJECT (ENTLAST)) A) error massage coming :; error: Automation Error. Key not found Quote Link to comment Share on other sites More sharing options...
satishrajdev Posted December 7, 2013 Share Posted December 7, 2013 Have you created *.lin file for every linetype or in that ma.lin file only all linetypes are available??? error massage coming :; error: Automation Error. Key not found Is it coming from my code???? Quote Link to comment Share on other sites More sharing options...
