StijnTas Posted January 23, 2014 Share Posted January 23, 2014 (edited) [PROBLEM SOLVED] Hi, Is it possible to make a dynamical block where the attribute is horizontal in combination of the alignment parameter (not rotate)? If I align to an arc the attribute need to stay at an horizontal position. Greetings. Edited September 11, 2014 by StijnTas Quote Link to comment Share on other sites More sharing options...
MedlandCAD Posted January 30, 2014 Share Posted January 30, 2014 TORIENT is my favourite. Type that in, select your block, select the basepoint of your attribute, type in the angle you want it rotated to (zero) and hit enter. I made a macro and a button up for this where I could just pick my blocks and hit the button. Job done. I recommend you do that. Another command is RATT. It will align your attribute to zero in accordance with what zero degrees is in relation to your UCS. Quote Link to comment Share on other sites More sharing options...
StijnTas Posted January 31, 2014 Author Share Posted January 31, 2014 @MedlandCAD: I didn't find the command RATT but the TORIENT command works great for this job. I put it on the ribbon. It's still not fully automatic. Is there a way to use the rotation angle of the alignment (example: 48.2°) to rotate the text inside the block with a negative value of -48.2? I'm really thankful with the reply because it will help me a lot. For the curiosity I'll look further for a full automatic solution. Quote Link to comment Share on other sites More sharing options...
MedlandCAD Posted February 3, 2014 Share Posted February 3, 2014 I wrote a good reply to this and then the site logged me out. The abbreviated version: Set your UCS to PLAN so that the XandY are perfectly horizontal and vertical. TORIENT set to zero will make them flat. If you don't wanna keep flicking your UCS back and forth then make a button in CUI with the macro ^C^CTORIENT;-48.2; or whatever angle you require and then just select a block and hit the button. Quote Link to comment Share on other sites More sharing options...
MedlandCAD Posted February 3, 2014 Share Posted February 3, 2014 Actually, in that macro, if -48.2 doesn't work then try 311.8 (which is 360 take 48.2) Quote Link to comment Share on other sites More sharing options...
steven-g Posted September 10, 2014 Share Posted September 10, 2014 If you make the text style annotative, there is an option to have the text always match the layout. Quote Link to comment Share on other sites More sharing options...
StijnTas Posted September 11, 2014 Author Share Posted September 11, 2014 @steven [sOLVED]: Thanks for the tip. It works great and simple. Quote Link to comment Share on other sites More sharing options...
