sjunior Posted February 19, 2014 Share Posted February 19, 2014 I have several problems with block.Firstly, I was trying to purge some of my block but they couldn't be remove even after i have exploded them. They refuse me from explode the block. Secondly, i was trying to insert blocks. There wasn't image be seen on the screen Whats the problem? Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 19, 2014 Share Posted February 19, 2014 First you erase all the blocks then you purge the block definition. Just because you exploded them doesn't mean the block definition disappears. If you can't see a block you are attempting to insert it could be that the insertion point is not on the block itself. Attach a sample DWG file to your next post and someone here will take a look at it. Quote Link to comment Share on other sites More sharing options...
sjunior Posted February 19, 2014 Author Share Posted February 19, 2014 i have set the base point of the block as middle and change the scale to 1000 but its still unseen. Can anyone teach me to remove the block that was been created in the following attachment? Symbol.dwg Mr Lim.dwg Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 19, 2014 Share Posted February 19, 2014 Are you talking about removing the 13A switch block? Yes? Use QSELECT to find all the blocks of which there are two. Erase them then purge your drawing of the block. Done. What block are you trying to insert? Quote Link to comment Share on other sites More sharing options...
sjunior Posted February 19, 2014 Author Share Posted February 19, 2014 there are three block inside, non of them can be removed Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 19, 2014 Share Posted February 19, 2014 I found only one block called 13A switch socket outlet (metal clad). What are the other two block names? Or do you mean there are three 13A switch socket outlet blocks? Quote Link to comment Share on other sites More sharing options...
sjunior Posted February 19, 2014 Author Share Posted February 19, 2014 sry, there are only two blocks. both are the same call 13A switch socket outlet (metal clad). Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 19, 2014 Share Posted February 19, 2014 OK....they're gone. Now what? What block are you trying to insert? Quote Link to comment Share on other sites More sharing options...
sjunior Posted February 19, 2014 Author Share Posted February 19, 2014 sry, how you do it? Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 19, 2014 Share Posted February 19, 2014 Found the blocks, exploded them (not a good idea generally) then purged the block definition. Quote Link to comment Share on other sites More sharing options...
sjunior Posted February 19, 2014 Author Share Posted February 19, 2014 When i try to insert some block into following folder the image isn't seen? Pls tell me how you do it!!! thanks! big squa.dwg Quote Link to comment Share on other sites More sharing options...
sjunior Posted February 19, 2014 Author Share Posted February 19, 2014 whats a better idea for removing the block? Sry, I still dont know how to do it? where can i find the block to explode them? can you tell me the steps? Quote Link to comment Share on other sites More sharing options...
sjunior Posted February 19, 2014 Author Share Posted February 19, 2014 is there any videos can show me how to do it? Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 19, 2014 Share Posted February 19, 2014 Slow down a bit. Why do you want to remove the block? I don't do videos. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 19, 2014 Share Posted February 19, 2014 When i try to insert some block into following folder the image isn't seen? Pls tell me how you do it!!! thanks! The reason you cannot see your blocks as they are being inserted is the layer you are inserting them on, although "current", is also turned "off"! Turn the layer on and you'll see the blocks. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 19, 2014 Share Posted February 19, 2014 Re: Symbol drawing. Did you know you had constraints enabled? They should all be deleted. I see little reason why constraints would be necessary. Here's your drawing back. Mr Lim Symbols.dwg Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 19, 2014 Share Posted February 19, 2014 When i try to insert some block into following folder the image isn't seen? Pls tell me how you do it!!! thanks! The attached drawing needs some work. BTW...it looks like I used an imperial template not a metric template. Basically you are drawing in decimal inches not millimeters. This may prove to be a bit of a problem when it comes time to plot the drawing. Also...I'd suggest placing your title block and border in the layout and not in model space. Are you a student? Are you taking an AutoCAD course? Quote Link to comment Share on other sites More sharing options...
sjunior Posted February 19, 2014 Author Share Posted February 19, 2014 okay!thanks. Yes, i am learning autocad at singapore as a student but the professor teach very fast. Quote Link to comment Share on other sites More sharing options...
sjunior Posted February 19, 2014 Author Share Posted February 19, 2014 i dont know what is constraints. My professor teach very fast and simple. Quote Link to comment Share on other sites More sharing options...
sjunior Posted February 19, 2014 Author Share Posted February 19, 2014 whats constraints? Quote Link to comment Share on other sites More sharing options...
