ASH_CAD Posted March 14, 2014 Share Posted March 14, 2014 Hi Not sure if this is possible but is it possible this to cut any shape using MVIEW? For example, if I have a floor plan but only want the MVIEW to be of one room which is not square/rectangle and not view any part of the adjoining rooms/areas? Great forum BTW Quote Link to comment Share on other sites More sharing options...
tzframpton Posted March 14, 2014 Share Posted March 14, 2014 Yes. Draw a Polyline, then initiate MVIEW and watch pay attention to the command line. You'll have an option to select the polygon as the Viewport. *EDIT* Object is what you want. As noted: Command: MVIEWSpecify corner of viewport or [ON/OFF/Fit/Shadeplot/Lock/Object/Polygonal/Restore/LAyer/2/3/4] : O Select object to clip viewport: Regenerating model. Quote Link to comment Share on other sites More sharing options...
ASH_CAD Posted March 14, 2014 Author Share Posted March 14, 2014 Thanks tzf I am little confused. Do I draw the PLINE in MS or PS? Clip object to viewport? Quote Link to comment Share on other sites More sharing options...
tzframpton Posted March 14, 2014 Share Posted March 14, 2014 Paperspace. MVIEW Object Select the Polyline Done. Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 14, 2014 Share Posted March 14, 2014 Are you expecting to print your floor plan to some sort of standard scale? Quote Link to comment Share on other sites More sharing options...
ASH_CAD Posted March 14, 2014 Author Share Posted March 14, 2014 No, remark OK, I'm being dumb tzf I need to create an initial Mview so I can "see" the floor plan in the first place in PS? Then it allows me to draw a PLINE but when I MVIEW > OBJECT it doesn't let me select the PLINE I just drew. Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 14, 2014 Share Posted March 14, 2014 Try this. After drawing your polyline.... Type -vports at the command line. Press the Enter key. Select the Object option. Now pick your polyline. What happens? Quote Link to comment Share on other sites More sharing options...
ASH_CAD Posted March 14, 2014 Author Share Posted March 14, 2014 After creating a plane and typing vports in PS, I get a Viewports layout dialogue box. If I select Single. It does;t give me the option for selecting Object. Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 14, 2014 Share Posted March 14, 2014 You obviously missed one small but very import thing. See that dash up there ^ ^ ^ in front of the word vports? When I ask you to type something I usually tell you exactly what to type. -vports Quote Link to comment Share on other sites More sharing options...
ASH_CAD Posted March 14, 2014 Author Share Posted March 14, 2014 I did miss that "-" It still won't let me select the PLINE though. Does the PLINE have to be on a certain layer, etc? Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 14, 2014 Share Posted March 14, 2014 No it does not. The pline just has to be in your layout. Did you erase the default viewport that AutoCAD sometimes includes with a layout prior to creating your new polyline? BTW...I confirmed my method works by testing it first in AutoCAD 2007 the same program you're running. Quote Link to comment Share on other sites More sharing options...
ASH_CAD Posted March 14, 2014 Author Share Posted March 14, 2014 I did originally. I just tried with a new Layout and same issue. The PLINE is on the ASH_MVIEW layer. When not in MVIEW it allows me to select the PLINE but as soon as i use MVIEW > OBJECT the PLINE becomes unelectable. Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 14, 2014 Share Posted March 14, 2014 Please stop trying to use MVIEW. Follow the directions I gave you the first time and use -vports. Remember the dash. If you can't figure it out attach a copy of the drawing to your next post. Someone here will take a look at it. Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 14, 2014 Share Posted March 14, 2014 To create your viewport using the MVIEW command you need to use the POLYGONAL option. This option allows you to draw your custom viewport in any shape you want just as though you were doing it with a polyline. There is no need to draw a polyline viewport first if you use this option. BTW...the polygonal viewport method (via MVIEW) is covered in your AutoCAD 2007 Help file. I just confirmed that too. OK. Now you have two ways of doing it. One of them should work for you. Quote Link to comment Share on other sites More sharing options...
ASH_CAD Posted March 14, 2014 Author Share Posted March 14, 2014 Floor plan attached. Floor plan.dwg Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 14, 2014 Share Posted March 14, 2014 The problem was most likely that you were drawing your polyline inside the default viewport in the layout. Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 14, 2014 Share Posted March 14, 2014 Here's your drawing back. I created a layer called VPorts and gave it the color magenta. I made it the current layer. I even created a sample polygonal viewport. Now you can do whatever you want. Erase what is there. Start MVIEW, select the POLYGONAL option and draw your new viewport. Have fun. Sorry but I have to run off now. Time for dinner. Floor plan_Vport.dwg Quote Link to comment Share on other sites More sharing options...
tzframpton Posted March 14, 2014 Share Posted March 14, 2014 Sorry but I have to run off now. Time for dinner.Can I come? Whatcha havin'? Quote Link to comment Share on other sites More sharing options...
rkent Posted March 14, 2014 Share Posted March 14, 2014 The current layer in your drawing was locked which would keep it from being picked. I would draw a closed pline over the top of a viewport, then use the clip command, pick the original vport, then pick our pline. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 14, 2014 Share Posted March 14, 2014 A circle is a valid shape as well Baked beans on toast saving for that new laptop Quote Link to comment Share on other sites More sharing options...
