callvey Posted March 21, 2014 Posted March 21, 2014 Hi, I am trying to modify a titleblock's att tag name, I have found loads of lisp routines that modify the value but cant seem to find one that can modify the name.. Is this even possible as I have read that the block has to be exploded for this to work?? Thanks Quote
callvey Posted March 21, 2014 Author Posted March 21, 2014 Yes, I need an automated method as I have over 1500 files to process. Quote
callvey Posted March 21, 2014 Author Posted March 21, 2014 I tried this but it doesnt work; (defun c:attr_rename_list ( / x_en enn edd ss slen ix atnam namelist hit blk_ent matchname newed x) ; Process all block instances on active drawing. Check each ; attribute for match on first element in list below. On any ; match, rename the attribute to the new name given in the ; second element. ; *********** ATTRIBUTE OLD versus NEW names list ****************** (setq namelist (list ; list old name and new name. Old name can contain wild cards. (list "OLD_TAG_NAME#1" "NEW_TAG_NAME#1") ; list old name and new name. (list "OLD_TAG_NAME#2" "NEW_TAG_NAME#2") (list "OLD_TAG_NAME#3" "NEW_TAG_NAME#3") (list "OLD_TAG_NAME#4" "NEW_TAG_NAME#4") (list "OLD_TAG_NAME#5" "NEW_TAG_NAME#5") ) ) ; ************************************************** ******************** ; Extract selection set of all block inserts on active drawing (setq ss (ssget "_X" '((0 . "INSERT")))) (if (/= ss nil) (progn (setq slen (sslength ss)) (setq ix 0) (while (< ix slen) (setq blk_ent (ssname ss ix)) ; get next block insert to process (setq ix (1+ ix)) ; increment for next time (setq enn (entnext blk_ent)) (setq edd (entget enn)) (while (AND enn (/= (cdr (assoc 0 edd)) "SEQEND") (/= (cdr (assoc 0 edd)) "INSERT") ) (if (= (cdr (assoc 0 edd)) "ATTRIB") (progn (setq atnam (cdr (assoc 2 edd))) (setq hit nil) (foreach x namelist (if (not hit) (progn ; no match yet, keep processing (setq matchname (car x)) (if (wcmatch atnam matchname) (progn ; found exact match or wild-card match ; Change name now. Substitute in new name. (setq newed (subst (cons 2 (cadr x)) (assoc 2 edd) edd)) (entmod newed) ; update the title block instance (entupd blk_ent) (princ "\n") (princ atnam) (princ " --> ") (princ (cadr x)) (setq hit 1) ; flag that found ) ) ) ) ) ) ) ; go to next sub ent in block instance and loop back up (if (setq enn (entnext enn)) (setq edd (entget enn))) ) ) (setq ss nil) ; release the selection set ) ) (princ) ; prettier ) Quote
MSasu Posted March 21, 2014 Posted March 21, 2014 Out of curiosity, as I can undestand the reason to change the prompt and/or the default value; why would one want to change the tag which isn't visible to regular edit operations? Quote
callvey Posted March 21, 2014 Author Posted March 21, 2014 The drawing is connected to a sql Database, the values are updated dynamically based on the name of the att tag. For example when I change an area/zone within the drawing it updates the value in the titleblock. some of my titleblocks read from different columns in the database, so I have to modify Att name to accommodate this. Quote
Tharwat Posted March 21, 2014 Posted March 21, 2014 What are the tag names that you'd like to change ? can you list them with current and new tag names ? Quote
callvey Posted March 21, 2014 Author Posted March 21, 2014 old tag - new tag AREA1 - AREA13 AREA2 - AREA14 AREA3 - AREA15 AREA4 - AREA16 AREA5 - AREA17 AREA6 - AREA18 AREA7 - AREA19 AREA8 - AREA20 Quote
Tharwat Posted March 21, 2014 Posted March 21, 2014 All right , try this code and let me know . (defun c:ChangeTags (/ *error* cmd l a) ;; Tharwat 21. Mar. 2014 ;; (defun *error* (msg) (if cmd (setvar 'CMDECHO cmd) ) (if (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*") (princ msg) (princ (strcat "*** Error : " msg "***")) ) (princ) ) (or doc (setq doc (vla-get-activedocument (vlax-get-acad-object))) ) (setq cmd (getvar 'CMDECHO) l '(("AREA1" . "AREA13") ("AREA2" . "AREA14") ("AREA3" . "AREA15") ("AREA4" . "AREA16") ("AREA5" . "AREA17") ("AREA6" . "AREA18") ("AREA7" . "AREA19") ("AREA8" . "AREA20") ) ) (setvar 'CMDECHO 0) (vlax-for x (vla-get-blocks doc) (if (and (eq :vlax-false (vla-get-isxref x)) (eq :vlax-false (vla-get-islayout x)) ) (vlax-for o x (if (and (eq (vla-get-objectname o) "AcDbAttributeDefinition") (setq a (assoc (strcase (vla-get-tagstring o)) l)) ) (progn (vla-put-tagstring o (cdr a)) (command "_.attsync" "_Name" (vla-get-name x)) ) ) ) ) ) (setvar 'CMDECHO cmd) (princ) ) (vl-load-com) Quote
callvey Posted March 21, 2014 Author Posted March 21, 2014 Fantastic stuff. really appreciate this code, ive been wheel spinning for days..I really do need to start learning this stuff:notworthy: Quote
Tharwat Posted March 21, 2014 Posted March 21, 2014 Fantastic stuff. really appreciate this code, ive been wheel spinning for days..I really do need to start learning this stuff:notworthy: Waw excellent . happy to hear that . Quote
callvey Posted March 22, 2014 Author Posted March 22, 2014 I've been wondering.. I have batch run this against a list if files, manually selecting the files from a folder.Would it be possible to identify a block based upon a specific attribute value it has.? And if it has that value then change the tag string? Quote
BIGAL Posted March 22, 2014 Posted March 22, 2014 You can make it work by using a script which will open the dwg make the changes then close the dwg do next and so on. To make it work you need to set the values of the attributes and pass these to the main program. For simplicity use this style Tharwart will help I am sure. You must add the defun to automatically load by adding code to acaddoc.lsp (setq namelist (list (list "OLD_TAG_NAME#1" "NEW_TAG_NAME1") (list "OLD_TAG_NAME#2" "NEW_TAG_NAME2") (list "OLD_TAG_NAME#3" "NEW_TAG_NAME3") (list "OLD_TAG_NAME#4" "NEW_TAG_NAME4") (list "OLD_TAG_NAME#5" "NEW_TAG_NAME5") ) ) Open dwg1 (c:attr_rename_list) Close Y (setq namelist (list (list "OLD_TAG_NAME#1" "NEW_TAG_NAME6") (list "OLD_TAG_NAME#2" "NEW_TAG_NAME7") (list "OLD_TAG_NAME#3" "NEW_TAG_NAME8") (list "OLD_TAG_NAME#4" "NEW_TAG_NAME9") (list "OLD_TAG_NAME#5" "NEW_TAG_NAME10") ) ) Open dwg2 (c:attr_rename_list) Close Y Alternative would be to use pairs and make list using the defun to re-make the list. (c:attr_rename_list "OLD_TAG_NAME#1" "NEW_TAG_NAME6" "OLD_TAG_NAME#2" "NEW_TAG_NAME7" "OLD_TAG_NAME#3" "NEW_TAG_NAME8" "OLD_TAG_NAME#4" "NEW_TAG_NAME9" "OLD_TAG_NAME#5" "NEW_TAG_NAME10") Quote
callvey Posted March 22, 2014 Author Posted March 22, 2014 Hi Bigal thanks for you reply. So I'm using the code that tharwat posted along with auto script to batch it. However when i use auto script i have to manually select the files that require the change. I was wondering, because the files that need updating have a unique attribute value within the block, I could somehow select all files and the batch would run only modifying those files with the unique attribute. Don't know if it's possible but worth an ask. Thanks Quote
BIGAL Posted March 24, 2014 Posted March 24, 2014 The code posted should look for a unique attribute tag so if it does not exsit it should not change anything, you could narrow the changes to only certain block names also as a extra to the ssget function to exclude blocks you do not want changed. I am sure Tharwat will respond. Quote
Tharwat Posted March 24, 2014 Posted March 24, 2014 Would it be possible to identify a block based upon a specific attribute value it has.? And if it has that value then change the tag string? That is simply could be done the same way that I did in my posted code and change the list accordingly with a replacement of one function as you can see in the following codes . Be sure to have your values in capital letters . (defun c:ChangeTags (/ *error* cmd l a) ;; Tharwat 24. Mar. 2014 ;; (defun *error* (msg) (if cmd (setvar 'CMDECHO cmd) ) (if (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*") (princ msg) (princ (strcat "*** Error : " msg "***")) ) (princ) ) (or doc (setq doc (vla-get-activedocument (vlax-get-acad-object)))) (setq cmd (getvar 'CMDECHO) l '(("VALUE1" . "AREA13") ("VALUE2" . "AREA14") ("VALUE3" . "AREA15")) ) (setvar 'CMDECHO 0) (vlax-for x (vla-get-blocks doc) (if (and (eq :vlax-false (vla-get-isxref x)) (eq :vlax-false (vla-get-islayout x))) (vlax-for o x (if (and (eq (vla-get-objectname o) "AcDbAttributeDefinition") (setq a (assoc (strcase (vla-get-textstring o)) l)) ) (progn (vla-put-tagstring o (cdr a)) (command "_.attsync" "_Name" (vla-get-name x))) ) ) ) ) (setvar 'CMDECHO cmd) (princ) ) (vl-load-com) I am sure Tharwat will respond. Thank you BIGAL for that big trust , highly appreciated . Quote
callvey Posted March 24, 2014 Author Posted March 24, 2014 Thanks Tharwat I will try this when I get into work and let you know. Quote
Tharwat Posted March 24, 2014 Posted March 24, 2014 Thanks Tharwat I will try this when I get into work and let you know. You're welcome , best of luck . Quote
callvey Posted March 24, 2014 Author Posted March 24, 2014 I tried that but it doesnt do what I need. I am running this through auto-script. So I have two types of titleblock- I only want the routine to work on the one where TAG NAME - VALUE DESC2 = BASEMENT So out of 1500 files 750 of them could have a value of BASEMENT for DESC2 so where DESC2 has a value of BASEMENT AREA1 - AREA13 AREA2 - AREA14 etc.. and if it doesnt have a value of BASEMENT do nothing. Hope this makes sense and thank you for help again. Quote
Tharwat Posted March 24, 2014 Posted March 24, 2014 It did not work because you might not have changed the values that I included within the routine to suit your required value(s) to change the tag name when it matches , have you ? Quote
