Hide namesake block,and Cancel the hidden
Thanks to everyone.
I want use a command to hide namesake block ,and use a command to show it.
Thank for help me!
  • Replies 25
  • liuhaixin88
    12
  • Tharwat
    10
  • steven-g
    2
  • flyfox1047
    1
Thanks to everyone.
Thank for help me!
:cry:Give a reply, ok?
What do you mean by hide with a command, I should say how do you see it working, the command 'hideobjects' will let you pick one or several objects to be hidden (unhide brings them all back), another method would be put objects on their own layer, and turn the layer on/off possibly with the use of a macro. It all depends on what you are doing.
steven,thanks for your reply!
hideobjects I know:
;;hideobjects
(defun c:yc ()
 (if (ssget)
     (vlax-for        obj
                   (vla-get-activeselectionset
                     (vla-get-activedocument (vlax-get-acad-object))
       (vla-put-Visible obj :vlax-false)
;;display objects
(defun c:hfxs (/ ss)
 (if (setq ss (ssget "x" '((60 . 1))))
   (vlax-for obj
     (vla-put-Visible obj :vlax-true)
but I want hide a block, the same name of the block all hide.
What is the name of the block(s) that you want to include within that routine ?
Are they Dynamic blocks or Normal ?
Are they Attributed ?
Maybe something based on 'selectsimilar'
Hi, Tharwat,Glad to meet you! Why do you change the Profile Picture ?
1. The name of the block is uncertain, You must select a block by mouse.
2. Both
3. Both
Thanks me too :)
Did not you like it ? I could change it if so .
Try the following routine and let me know about the result .
(defun c:test (/ s sel nm lst ss)
 ;;    Tharwat 26.Mar.2014        ;;
 ;; Hide Block name by Selection    ;;
 (or doc (setq doc (vla-get-activedocument (vlax-get-acad-object))))
 (princ "\n Select Blocks to hide all with the same name ...")
 (if (setq s (ssget "_:L" '((0 . "INSERT"))))
   (progn (vlax-for x (setq sel (vla-get-activeselectionset doc))
            (if (not (member (setq nm (vla-get-effectivename x)) lst))
              (setq lst (cons nm lst))
          (vla-delete sel)
          (if (setq ss (ssget "_X"
                              (list '(0 . "INSERT")
                                    (cons 410 (getvar 'CTAB))
                                    (cons 2 (strcat "`*U*," (apply 'strcat (mapcar '(lambda (u) (strcat u ",")) lst))))
                     (if (member (setq nm (vla-get-effectivename x)) lst)
                       (vl-catch-all-apply 'vla-put-visible (list x :vlax-false))
            (vla-delete sel)
(vl-load-com)
Thanks me too :)
ha!ha! I like the previous.
This code very nice! perfect!:beer: but how to display it?
Excellent , happy to hear :)
Huh ? :huh:
Huh ? :huh:
After the hidden, how to display?
You already have one in your previous code .
This?
;;display objects
   (vlax-for obj
It's not that, this will display all the objects. I just want display the block.
So how would the routine know what are the blocks or objects that you have used before to redisplay them back unless you have them in a list to put on and off ?
Dear Tharwat,
Mean there is no way ?
Dear Tharwat,
I did not mean that , let me make easy to read .
Suppose that you run my routine and selected a few specific blocks , let 's say "a" "b" "c" and you closed the drawing .
Then you opened the drawing and wanted to reshow these specific blocks back , how would the code know what are the name of blocks that you have hide them before you close the drawing ?
But if you have a specific name of block to hide and show , you can write these names in a list inside the routine and that would give the chance to notify the block names to show and hide all along .
I mean: Show all hide block.
So add the dxf code in your routine as the following .
(0 . "INSERT")(60 . 1)
Edited by Tharwat
OK! nice! Thank you!
Edited by liuhaixin88
