LISP autoload problem in AutoCAD 2013
Dimitri-SMB
Hi boys and girls!
I have a good one for you...
I have a set of LISP routines (around 20 of them), which I use pretty much all the time. I used to autoload them into each drawing using either StartUp suit (if I was lazy), or by ACADDOC.lsp, if StartUp suit was glitching...
Never had a problem.
However, I've just had my CAD upgraded from 2011 to 2013, and SOME of my LISP files simply won't autoload, whatever I do! About half of them...
I've tried StartUp suit. I've tried creating autoload functions within both ACADDOC.lsp and ACAD.lsp. I even tried to copy ALL codes from ALL files into a single file (ACADDOC)... Some of routines just won't autoload.
I know that both ACAD.lsp and ACADDOC.lsp are loading within each drawing. I know that LISP files are not corrupt, because they load manually without a problem. It's just a pain to do it manually each time I open a drawing.
The only reason I can think of that some of my routines have some old code, incompatible with 2013 release autoloading feature (strange!).
It does my HEAD in!
Any thoughts???
Thanks in advance!
