Results 1 to 4 of 4
    Forum Newbie
    AutoCAD 2015
    Jul 2014
    7
    Default Reference Manager makes my dynamic block MTEXT out of wack!
    I have a Detail Bubble dynamic block with MTEXT. Every time I use the Reference Manager, the MTEXT does not show up at the original location.
    I couldn't upload the pic to show what I mean.
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,960
    Can you post a .dwg with the block?
    To post an image or .dwg etc., select "Go Advanced" at lower right of reply box, then select "Manage Attachments".
    Forum Newbie
    AutoCAD 2015
    Jul 2014
    7
    Here is the image. I will try to attach the drawing in a bit since this browser took forever to attached this image.
    Thanks!
    Forum Newbie
    AutoCAD 2015
    Jul 2014
    7
    Here is the .dwg file. Notice how the text moved.
    Thanks!
    CAD Tutor File.dwg
  1. Using Dynamic Block as an External Reference
    By alijahed in forum AutoCAD Drawing Management & Output
    Last Post: 22nd Dec 2013, 09:05 pm
  2. Dynamic Block - rotating reference issue
    By jalbes in forum AutoCAD Drawing Management & Output
    Last Post: 6th Apr 2013, 03:10 pm
  3. Dynamic block with mtext field
    By jwstimac in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Mar 2012, 08:24 pm
  4. Insert block onto dynamic reference
    By eaystcw in forum AutoCAD Drawing Management & Output
    Last Post: 19th Oct 2011, 04:37 pm
  5. Dynamic Block Reference itself
    By autorestorer in forum AutoCAD General
    Last Post: 22nd Aug 2011, 01:04 pm
Tags for this Thread
