spiker7221 Posted July 22, 2014 Share Posted July 22, 2014 I'm new to Inventor 2014 and am having trouble with it's capabilities. I have a vertical part..rotated in several directions (see below). The top and bottom needs to be level with the ground plane when all is done. Chopped flat. Plan view - rotate it 37.023 degrees South elevation - rotate it 2.46 degrees to the left. West elevation - rotate it 8.75 to the right. I tried to create a 3d void in the South view, but it first needs a plane to start.....which is rotated and skewed a bit. Can I project a sketch in the South view and use as a void to remove from the piece? Thanks for any help. Mike Test corner vertical.ipt Quote Link to comment Share on other sites More sharing options...
JD Mather Posted July 22, 2014 Share Posted July 22, 2014 There were no dimensions in Sketch1? I got lost from there. Quote Link to comment Share on other sites More sharing options...
spiker7221 Posted July 22, 2014 Author Share Posted July 22, 2014 There were no dimensions in Sketch1?I got lost from there. So sorry for that. I figured it out. I created a plane by using Angle to Plane Around Edge. I enabled the visibility of my XZ plane and Z axis. Worked like a charm. Here's my end result. What do you think? Thanks for your reply, Mike in Dallas Test corner vertical REV 2.ipt Quote Link to comment Share on other sites More sharing options...
JD Mather Posted July 22, 2014 Share Posted July 22, 2014 2D drawing view Quote Link to comment Share on other sites More sharing options...
JD Mather Posted July 22, 2014 Share Posted July 22, 2014 I assume you are going to use some assembly constraints. This might be an interesting solution (see attached). Test Corner_JD.ipt Quote Link to comment Share on other sites More sharing options...
