kizaerf Posted September 8, 2014 Share Posted September 8, 2014 Is there a shortcut for setting a certain dimstyle as default similar to right clicking 'set current as default' (which is available for some features) without going into the dialogue box? It would be fine to do that if the author of the drawings didn't have 50 with similar names. Thanks Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 9, 2014 Share Posted September 9, 2014 -dimstyle stylename hopefully works with Architecture Quote Link to comment Share on other sites More sharing options...
Stefan BMR Posted September 10, 2014 Share Posted September 10, 2014 I use this lisp and a macro attached to a button. ^C^Csetdim. Select an existing dimension object and run SetDim to make it current. It also switch current layer to dimension's layer. (defun C:SETDIM (/ e) (if (setq e (ssget ":E:S" '((0 . "DIMENSION")))) (progn (setq e (entget (ssname e 0))) (command "DIMSTYLE" "R" (cdr (assoc 3 e))) (setvar "CLAYER" (cdr (assoc 8 e))) ) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
