Coordinate lisp
Madruga_SP
Hi guys,
Happy New Year!!!:D
I need to put the coordinate about 176 blocks in my drawing.
I'm looking for a lisp to do that. I was wondering if someone could help me.
I'm using ID command and copy and paste the x and y coordinate. I'm wasting a lot of time.
I'll will be really happy if someone could help me out.
I'm attaching a example
Thank in advance
  • Replies 28
  • Madruga_SP
    15
  • pBe
    8
  • Tharwat
    3
  • ReMark
    1
There are plenty of lisp routines that will place coordinates in a drawing but I don't know of one that will do it automatically. Here is a description of one such program.
Auto Coordinate Dynamic Block is used to label coordinates automatically in the drawing instead of using any lisp. The attribute fields get the eastward and northward values, The dynamic properties of the block make it flexible and can adjust the size by Annotative scale.
Yep Henrique,
Because the table is complicated and I think that a lisp isn't doing that.
But if the code make as I want to. It will be great, mate!
I was thinking something that you pick the points and in the end create a text file with coordinates.
Then I copy and paste the results.
Regards
coordinate-test.dwg
Okay then, via pick points? or global?
no answer?
Anyhoo.
(defun c:nsf (/ data file ss op number coord str2dis) ;<< Not So Fancy
 (setq data nil)
 (if (and
(ssget "_X"
       (list '(0 . "INSERT")
	     '(2 . "quadra")
	     (cons 410 (getvar 'ctab))
(setq file
       (getfiled "Enter file name" (getvar 'dwgprefix) "txt" 1)
     (vlax-for	itm (setq
	      ss (vla-get-ActiveSelectionSet
		   (vla-get-ActiveDocument (vlax-get-acad-object))
(setq number (atoi (vla-get-textstring
		     (car (vlax-invoke itm 'Getattributes))
(setq coord (vlax-get itm 'Insertionpoint))
(if (/= number 0)
  (setq	data (cons
	       (list number
		     (strcat
		       (rtos (car coord) 2 4)
		       "\t\t"
		       (rtos (cadr coord) 2 4)
	       data
     (vla-delete ss)
     (setq op (open file "w"))
     (foreach val (vl-sort data '(lambda (a b) (< (car a) (car b))))
(princ
  (Strcat
    "\n"
    (setq str2dis (strcat (itoa (car val)) "\t" (cadr val)))
(write-line str2dis op)
     (close op)
     (startapp "Notepad" file)
Edited by pBe
Sorry for delay.
I went to lunch.
Could be pick all block's named quadra and give me the coordinates?
I don't know how to use your code.
Edited by Madruga_SP
Sorry for delay.
I went to lunch.
Load the code and type NSF at the command prompt:
command: NSF
Simple like that
Madruga , I am really surprised that you don't know how to load a lisp file ! :o
My bad guys. I've realized that I had to explode the block to renumber them.
The code isn't working
Thank you pBe!!
Your code is wonderful worked like a charm.
But I exploded all blocks to renumber and now it's just a circle and text. :cry:
You must be using another Attributed block than the one you have uploaded in this thread . I guess
Hi my friend Tharwat,
I had to insert all blocks again.
It works great!
Thank you
It works great!
Thank you
Good to hear that :thumbsup:
All credits go to pBe for the nice codes for sure :)
Kudos for everyone!!
I'm really happy with the goal.
Thank you
