vernonlee Posted January 21, 2015 Share Posted January 21, 2015 Did a search but fail to find one. Basically i have certain words in a mixture of text & mtext as well as inside blocks & nested blocks that I need to chane to a different color depending on which words. Would be great if the process is as such 1) run lisp 2) key in the words (no need whole words or case sensitive) 3) key in the color number 3) select the area of search (this includes deep nested blocks) currently i go into every block to use the FIND command to change & it is tedious Thanks Quote Link to comment Share on other sites More sharing options...
ttray33y Posted January 22, 2015 Share Posted January 22, 2015 Did a search but fail to find one. Basically i have certain words in a mixture of text & mtext as well as inside blocks & nested blocks that I need to chane to a different color depending on which words. Would be great if the process is as such 1) run lisp 2) key in the words (no need whole words or case sensitive) 3) key in the color number 3) select the area of search (this includes deep nested blocks) currently i go into every block to use the FIND command to change & it is tedious Thanks Hi buddy, sorry but this is only I can offer, im still a newbie, but anyway it works. Noob macro below. (setq BLK "?") (defun c:test () (setvar "cmdecho" 1) (setq cBLK (getstring (strcat "\nEnter block name of text <" BLK ">: "))) (if (= cBLK "") (setq cstr BLK) (setq BLK cBLK) ) (command "-bedit" BLK "") (command "zoom" "1000" "") (c:OTA) (princ) ) (setq str "?") (defun C:OTA(/ cntr eset en enlist pt clr) (setvar "cmdecho" 1) (setq cstr (getstring (strcat "\nEnter text string <" str ">: "))) (if (= cstr "") (setq cstr str) (setq str cstr) ) (defun FilterTxtValuX(eset valu) (setq cntr 0 newSet(ssadd)) (while(< cntr (sslength eset)) (setq en(ssname eset cntr)) (setq enlist(entget en)) (if(= (strcase valu) (strcase (cdr(assoc 1 enlist)))) (ssadd en newSet) ) (setq cntr(+ cntr 1)) ) newSet ) (setvar "cmdecho" 0) (setq clr(acad_colordlg 1 nil)) (setq eset (ssget"X" (list (cons -4 "<OR") (cons 0 "MTEXT") (cons 0 "TEXT") (cons -4 "OR>") ) ) ) (if(and eset(> (sslength eset) 0))(setq eset(FilterTxtValuX eset str))) (if (and eset (> (sslength eset) 0)) (progn (command "change" eset "" "Properties" "Color" clr "") ) ) (setvar "cmdecho" 1) (command "bclose" "") (command "zoom" "e") (princ) ) (princ "\n Type test.") (princ) how it works. Enter the name of the block of where the text resides. Enter the text string (will ony work on words & strings without spaces) Enter color number. greetings from Phils. Quote Link to comment Share on other sites More sharing options...
vernonlee Posted January 22, 2015 Author Share Posted January 22, 2015 (edited) Hi Bro, many thanks for the effort. Have tried it out & it works as per your instructions. I do need something speedy that I can just window to select the following (without needing the block names) for the changes:- 1) standalone text, mtext, 2) blocks (with text inside these blocks) 3) nested blocks (text inside the block within these blocks) Appreciate your effort Edited January 22, 2015 by vernonlee Quote Link to comment Share on other sites More sharing options...
Tharwat Posted January 22, 2015 Share Posted January 22, 2015 (edited) Give this a go and let me know . (defun c:Test (/ _doc c ss i sn name lst st) ;;; Tharwat 22.01.2015 ;;; (defun _change:color:in:block (e c st / o e) ;;; ;;; ;;; Variables : ;;; ;;; e = Block Definition ( "INSERT" ) ;;; ;;; c = Color to replace color of objects in blocks ;;; ;;; st = Text string to be searched for to be colored ;;; ;;; ___________________________________________________________ ;;; (setq e (tblobjname "BLOCK" (cdr (assoc 2 (entget e))))) (while (setq e (entnext e)) (cond ((and (eq (cdr (assoc 0 (setq o (entget e)))) "INSERT") (not (member '(66 . 1) o)) (not (member (cdr (assoc 2 o)) lst)) ) (progn (setq lst (cons (cdr (assoc 2 o)) lst)) (_change:color:in:block e c st) ) ) ((and (wcmatch (cdr (assoc 0 o)) "*TEXT") (eq (cdr (assoc 1 o)) st) ) (entmod (append o (list (cons 62 c)))) ) ) ) ) (if (and (/= "" (setq st (getstring t "\n Specify the Text string to color :")) ) (setq c (acad_colordlg ) (setq ss (ssget "_:L" (list '(-4 . "<OR") '(0 . "INSERT") '(-4 . "<AND") '(0 . "TEXT,MTEXT") (cons 1 st) '(-4 . "AND>") '(-4 . "OR>") ) ) ) ) (progn (vla-startundomark (setq _doc (vla-get-activedocument (vlax-get-acad-object))) ) (repeat (setq i (sslength ss)) (if (wcmatch (cdr (assoc 0 (entget (setq sn (ssname ss (setq i (1- i)))))) ) "*TEXT" ) (if (eq (cdr (assoc 1 (entget sn))) st) (entmod (append (entget sn) (list (cons 62 c)))) ) (if (not (member (setq name (cdr (assoc 2 (entget sn ) ) ) ) lst ) ) (progn (setq lst (cons name lst)) (_change:color:in:block sn c st) ) ) ) ) (vla-endundomark _doc) (vla-regen _doc acallviewports) ) ) (princ) )(vl-load-com) Edited January 23, 2015 by Tharwat Quote Link to comment Share on other sites More sharing options...
vernonlee Posted January 23, 2015 Author Share Posted January 23, 2015 (edited) WOW Tharwat. It works almost perfect bro. Could normal text & mtext ...etc that is not blocked be included in this lisp package to be colored as well? Currently those standalone text did not change & is also unselectable. Only blocks can be selected. Thanks alot Edited January 23, 2015 by vernonlee Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 23, 2015 Share Posted January 23, 2015 (edited) I dont belive you can do multi colour words in standard text you can in mtext so 1st step may be to convert to mtext then insert colour codes. This is image TextString = "{\\fArial|b0|i0|c0|p34;HEADING \\C1;asdf\\C256; \\C3;ghh\\C256; jjjj}" It may be as simple as modify the text string asdf now \\C1;asdf\\c256 Found VL-string-subst now to find time for code this is close but I have discovered a problem I need to remove the preceeding colour switch from the text. (setq Col (getint "\nEnter colour num")) (setq str (getstring "\nEnterstring")) (setq obj (vlax-ename->vla-object (car (entsel)))) (setq extext (vla-get-textstring obj)) (setq newstr (strcat "[url="file://\\c"]\\c[/url]" (rtos col 2 0) ";" str )) (setq newtext (vl-string-subst newstr str extext)) (vla-put-textstring newtext obj) Edited January 23, 2015 by BIGAL Quote Link to comment Share on other sites More sharing options...
vernonlee Posted January 23, 2015 Author Share Posted January 23, 2015 Hi BIGAL, Just to clarify, i am changing color only for whole words currently. However your concept of changing colour for individual words in a string of sentences is interesting & may be useful in the future. Looking forward to your creations. I just need color change for whole words at the moment. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted January 23, 2015 Share Posted January 23, 2015 If you want to only change the whole line ie all words CHprop will work or just entmod the dxf code 62. I have since like below worked out the correct way to do colour for 1 word. (setq obj (vlax-ename->vla-object (car (entsel)))) ; pick mtext (vla-put-textstring obj "{\\fArial|b0|i0|c0|p34;\\C32;HEADING\\C256; assdff jkfhkjh jnfkj }" ) Quote Link to comment Share on other sites More sharing options...
vernonlee Posted January 23, 2015 Author Share Posted January 23, 2015 BIGAL Errr.... how to run that command? I guess "CAR" is the word to change the color? Also, just wanted to run a single command that changes text & text within blocks & nested blocks. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted January 23, 2015 Share Posted January 23, 2015 WOW Tharwat. It works almost perfect bro. Could normal text & mtext ...etc that is not blocked be included in this lisp package to be colored as well? Currently those standalone text did not change & is also unselectable. Only blocks can be selected. Thanks alot I modified the program to include (m)texts . Quote Link to comment Share on other sites More sharing options...
vernonlee Posted January 23, 2015 Author Share Posted January 23, 2015 Hi Tharwat. Tested. The text within block is ok. But for text outside block, every words selected had their color changed. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted January 23, 2015 Share Posted January 23, 2015 That's odd , Upload a sample drawing and what is the text string that you type when the program asks you to enter . Quote Link to comment Share on other sites More sharing options...
vernonlee Posted January 23, 2015 Author Share Posted January 23, 2015 (edited) test color change text.dwg Hi Tharwat. Attached is a sample. I have my explaination inside the drawing. Thanks Edited January 23, 2015 by vernonlee Quote Link to comment Share on other sites More sharing options...
Tharwat Posted January 23, 2015 Share Posted January 23, 2015 I have updated the program and added some extra improvements Quote Link to comment Share on other sites More sharing options...
vernonlee Posted January 23, 2015 Author Share Posted January 23, 2015 Hi Tharwat. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted January 23, 2015 Share Posted January 23, 2015 Hi Tharwat. Haha ... Happy to help Quote Link to comment Share on other sites More sharing options...
vernonlee Posted January 27, 2015 Author Share Posted January 27, 2015 Hi Tharwat. Would you be able to modify the lisp such that it will highlight the text as long as it has a particular word? Thanks Quote Link to comment Share on other sites More sharing options...
Tharwat Posted January 27, 2015 Share Posted January 27, 2015 Would you be able to modify the lisp such that it will highlight the text as long as it has a particular word? As far I can tell , you can not highlight texts in Blocks but for texts objects , it is possible . Quote Link to comment Share on other sites More sharing options...
vernonlee Posted January 27, 2015 Author Share Posted January 27, 2015 As far I can tell , you can not highlight texts in Blocks but for texts objects , it is possible . Not quite sure what you meant but perhaps I can clarify further. As what your lisp routine can do is to color the selected text (including text in blocks) base on keying in of full whole words. EXAMPLE: Drawing has DOOR A, DOOR B, DOOR C & WINDOW A Current lisp routine if "DOOR A" is keyed in, all "DOOR A" will be selected to change color. If possible can the routine select base on a wildcard word instead, as such:- Modified lisp routine if "DOOR" is keyed in, all "DOOR A", "DOOR B" & "DOOR C" will be selected to change color (Only WINDOW A is not selected) if "A" is keyed in, all "DOOR A" & "WINDOW A" will be selected to change color (Only DOOR B & DOOR C are not selected) Thanks Quote Link to comment Share on other sites More sharing options...
Tharwat Posted January 27, 2015 Share Posted January 27, 2015 This ? (defun c:Test (/ _doc c ss i sn name lst st) ;;; Tharwat 27.01.2015 ;;; (defun _change:color:in:block (e c st / o e) ;;; ___________________________________________________________ ;;; ;;; Variables : ;;; ;;; e = Block Definition ( "INSERT" ) ;;; ;;; c = Color to replace color of objects in blocks ;;; ;;; st = Text string to be searched for to be colored ;;; ;;; ___________________________________________________________ ;;; (setq e (tblobjname "BLOCK" (cdr (assoc 2 (entget e))))) (while (setq e (entnext e)) (cond ((and (eq (cdr (assoc 0 (setq o (entget e)))) "INSERT") (not (member '(66 . 1) o)) (not (member (cdr (assoc 2 o)) lst)) ) (progn (setq lst (cons (cdr (assoc 2 o)) lst)) (_change:color:in:block e c st) ) ) ((and (wcmatch (cdr (assoc 0 o)) "*TEXT") (wcmatch (cdr (assoc 1 o)) (strcat st "*")) ) (entmod (append o (list (cons 62 c)))) ) ) ) ) (if (and (/= "" (setq st (getstring t "\n Specify the Text string to color :")) ) (setq c (acad_colordlg ) (setq ss (ssget "_:L" (list '(-4 . "<OR") '(0 . "INSERT") '(-4 . "<AND") '(0 . "TEXT,MTEXT") (cons 1 (strcat st "*")) '(-4 . "AND>") '(-4 . "OR>") ) ) ) ) (progn (vla-startundomark (setq _doc (vla-get-activedocument (vlax-get-acad-object))) ) (repeat (setq i (sslength ss)) (if (wcmatch (cdr (assoc 0 (entget (setq sn (ssname ss (setq i (1- i)))))) ) "*TEXT" ) (if (wcmatch (cdr (assoc 1 (entget sn))) (strcat st "*")) (entmod (append (entget sn) (list (cons 62 c)))) ) (if (not (member (setq name (cdr (assoc 2 (entget sn ) ) ) ) lst ) ) (progn (setq lst (cons name lst)) (_change:color:in:block sn c st) ) ) ) ) (vla-endundomark _doc) (vla-regen _doc acallviewports) ) ) (princ) )(vl-load-com) Quote Link to comment Share on other sites More sharing options...
