Hi guys, to all LSP expert pls help me
at first this LSP code was working and I'm using for long time using auto cad 2012. But now LSP code is not working
Code tag:
pls see attachment,
what went wrong?
Im using this LSP for my scr. for multiple drawings and it is really useful.
CHATTRIB.LSP
Edited by Cheezee
Code posting is not working so what I did is to attach my lsp
  • Replies 26
  • Tharwat
    11
  • Cheezee
    11
  • pBe
    4
  • SLW210
    1
Posted Images
Nothing is wrong with that function , but if the block name is a dynamic block that wouldn't work .
@Tharwat How do I know if block is dynamic block?
This is what I get when I'm using my CHATTRIB LSP
Entget the entity name of your block then search for the cdr value of DXF 2 , if it is start with *U it means a Dynamic Block , otherwise it is not . :)
Sorry Tharwat I really don't understand how to know if my block is dynamic
I try to input Entget but autocad said unknown
I have attach my .dwg and .lsp in my previous message.
Pls mind to upload and made some recommendation how to make my LSP work again.
Copy and paste the following line of codes into your command line then press Enter to start so select a block , if it start with *U so it is Dynamic otherwise it's not .
(cdr (assoc 2 (entget (car (entsel "\n Select a Block :")))))
Anyway , try this modification and let me know .
NOTE: add your function changeAttribValue to the following routine .
(defun C:CHATTRIB  (/ ss sn a attag bname oldval newval)
 (and (/= "" (setq bname (getstring "\nBlock name: ")))
      (/= "" (setq attag (getstring T "\nTag: ")))
      (/= "" (setq oldval (getstring T "\nOld value: ")))
      (/= "" (setq newval (getstring T "\nNew value: ")))
      (setq ss (ssget "_X"
                      (list '(0 . "INSERT")
                            '(66 . 1)
                            (cons 2 (strcat "`*U*," bname)))))
      (repeat (setq a (sslength ss))
        (if (eq (vla-get-effectivename
                  (vlax-ename->vla-object
                    (setq sn (ssname ss (setq a (1- a))))))
                bname)
          (changeAttribValue
            sn
            attag
            oldval
            newval)
 )(vl-load-com)
Sorry Sir SLW210, I will edit my post
thank you sir,
Sir Tharwat It is confirmed Dynamic block
Sir How can I change this block, so that I can use your code?
I manage to find out how to change dynamic block to static block,
but I can't still use the chageattribute code.
Does this mean we can't use lsp in AutoCAD 2012?
I already modified your codes and added a few functions to it , did not you try it ?
Sir Tharwat there is an error
pls see attachment for snap shot
I also already gave you a note that you need to add the function changeAttribValue to my modified program , got it ?
I don't know where to put the add function,
this is usually step
Once I appload the lsp
then typing in the command
_CHATTRIB
BLOCK NAME:___ (It ask for block name)
Old value: ___ (after I enter the block name It instantly ask for Old value)
New value: ___ (same with previous it ask instantly for New value)
and then error after I enter my desire New value
Where in this command can I add the changeattribvalue?
(defun c:CHATTRIB (/ ss sn a attag bname oldval newval)
 (defun changeAttribValue (ent atttag oldval newval / entl)
   (while (and ent
               (/= "SEQEND" (cdr (assoc 0 (setq entl (entget ent)))))
     (and (= atttag (cdr (assoc 2 entl)))
          (= oldval (cdr (assoc 1 entl)))
          (entmod (subst (cons 1 newval) (assoc 1 entl) entl))
          (entupd ent)
          (mapcar 'princ (list "\n" oldval " -> " newval))
     (setq ent (entnext ent))
                            '(66 . 1)
                bname
          (changeAttribValue
            sn
            attag
            oldval
            newval
)(vl-load-com)
Sir Tharwat thank you so much it work I can finally change the attribute value with your code
thank you very much.
