Fierce12 Posted February 13, 2015 Share Posted February 13, 2015 I'm creating a macro for a linetype that has a ltscale of 0.5, but once the command is done I want it to revert to 1.0. This is what I have so far ^C^CCELTSCALE;0.5;-LINETYPE;SET;BYLAYER;^C-LWEIGHT;BYLAYER;-COLOR;BYLAYER;-LAYER;MAKE;"V-WETL";COLOR;RED;;LTYPE;DASHDOT2;;^C^C_pline;CELTSCALE;1; I thought maybe the end portion would be the solution but it doesn't work. What am I doing wrong? Is there another way of doing this? Thanks Quote Link to comment Share on other sites More sharing options...
SLW210 Posted February 13, 2015 Share Posted February 13, 2015 It would help to put the Macro in Code Tags. It doesn't help that everything is one long sentence. Quote Link to comment Share on other sites More sharing options...
Fierce12 Posted February 13, 2015 Author Share Posted February 13, 2015 Sorry here it is again. ^C^CCELTSCALE;0.5;-LINETYPE;SET;BYLAYER;^C-LWEIGHT;BYLAYER;-COLOR;BYLAYER;-LAYER;MAKE;"V-WETL";COLOR;RED;;LTYPE;DASHDOT2;;^C^C_pline; Essentially what I want is once i'm done drawing the polyline I want the celtscale to go back to 1. Thanks Quote Link to comment Share on other sites More sharing options...
steven-g Posted February 13, 2015 Share Posted February 13, 2015 Try this to get you started ^C^CCELTSCALE;0.5;-LINETYPE;SET;BYLAYER;^C-LWEIGHT;BYLAYER;-COLOR;BYLAYER;-LAYER;MAKE;"V-WETL";COLOR;RED;;^C^CLTYPE;S;DASHDOT2;;pline;\\\;CELTSCALE;1; See if you can spot the subtle differences, there will be a problem though running this because you need to hard code into the macro how many segments the polyline will have, if you could leave the celtscale of the end, then no problems Quote Link to comment Share on other sites More sharing options...
Fierce12 Posted February 13, 2015 Author Share Posted February 13, 2015 Thanks steven-g, This is better than what I had, but unfortunately I'd like to be able to have the option of having any number of line segments (or pick points) for the polyline. This is a good solution in the interim. I can always draw the polyline and then match the properties to other lines. Then again i can always draw the line at 1 scale and change the properties to .5 ltscale. Im' just trying to avoid thes extra steps. Thanks again! Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 13, 2015 Share Posted February 13, 2015 This can't be handled by putting the polyline on a toolpalette and changing it's scale properties? Quote Link to comment Share on other sites More sharing options...
Fierce12 Posted February 13, 2015 Author Share Posted February 13, 2015 Interesting thought ReMark. Didn't think of taking that approach. I like using menus, but i may have some hatches and using the palette for hatches is a better solution. While I think i'll take this approach. I'd still be interested if there is a way for a macro to work. Thanks Quote Link to comment Share on other sites More sharing options...
steven-g Posted February 13, 2015 Share Posted February 13, 2015 This can't be handled by putting the polyline on a toolpalette and changing it's scale properties? Give that man a choclate biscuit. Possibly 2 Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 13, 2015 Share Posted February 13, 2015 Thanks. Can I get some hot tea with that biscuit? It is freakin' cold today! I think I may have frozen my giblets. Quote Link to comment Share on other sites More sharing options...
