Results 1 to 5 of 5
    Forum Newbie
    Architecture 2015
    Feb 2015
    2
    Default title block basic setup - dwg vs dwt - etc
    i've learned a few different techniques for making an affective title block but i want to weigh in on what you guys think as I have not mastered this yet.
    Right now i'm drawing my title block linework and permanent text in model space. then I xref that file into paper space of drawing for each layout/sheet. I use fields for the unique text on each page. I copy and paste these fields into each layout/sheet. I don't see too much of an issue here, however its a little time consuming to copy and paste these fields every time i make a new layout/sheet.
    Is there a simple way to insert my title block xref and insert these fields in one step? I think this is where the dwt file comes into play but i dont know. whats the difference between dwt and dwg?
    What if i want to shift the position of the sheet number on every page? Can we setup the title block to allow one to shift the sheet number once and apply the change to every page?
    Thanks for your help in advance!
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,169
    Instead of creating a "NEW" layout, import or copy one that already has the XREF and the FIELDS.
    Drafting is a breeze.
    Forum Newbie
    Architecture 2015
    Feb 2015
    2
    Quote Originally Posted by RobDraw View Post
    Thanks Rob, This makes sense. What about changing the position of a "field" on every page. Is this possible? Im sure I cant be the only one that ever wanted to accomplish this, however Im not able to find a good answer on the web. Being that I don't really know what a DWT is than I have to assume this might be the answer.
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,169
    IME, the field should stay in the same position for each sheet. Elsewise, you would need to adjust for each sheet.
  5. #5
    Senior Member zaphod's Avatar
    AutoCAD 2017
    Sep 2013
    Houston, TX
    174
    Quote Originally Posted by adnet23 View Post
    might be possible using viewports.
  1. Attribute in title block exists in BLock Editor but not in Project.
    By Pawnsurfer in forum AutoCAD Drawing Management & Output
    Last Post: 19th Feb 2015, 09:10 pm
  2. link title of file to the title block inside
    By 19cruthik68 in forum AutoCAD Drawing Management & Output
    Last Post: 12th Jun 2012, 09:25 am
  3. Replies: 8
    Last Post: 12th Dec 2011, 06:54 pm
  4. title block setup
    By jcreech in forum AutoCAD Beginners' Area
    Last Post: 4th Dec 2009, 06:15 pm
  5. Replies: 4
    Last Post: 17th Oct 2009, 03:21 am
Tags for this Thread
