Split a dynamic block into a single block for each state
woodman78
I am looking to split a dynamic block with visibility states into a series of blocks with a block for each visibility state. Can anyone help with this?
Its quite easy. This would be fun to code :)
Grab all Visibility names via GetDynamicBlockProperties
Create one block for each via ConvertToStaticBlock
Did i not say its easy and fun to code?
Thanks guys I already use Lee's RB command but does anyone have a way to make a block static on a certain visibility state?
Have you tried the CB option in Lee's lisp, from the description, it sounds like it may be able to do it?
Many thanks for all the recommendations guys :thumbsup:
It was indeed quite fun to code - here's a quick draft:
;; Split Dynamic Block by Visibility State  -  Lee Mac
(defun c:dynsplit ( / *error* blk dis llp obj prp tmp urp )
   (defun *error* ( msg )
       (LM:endundo (LM:acdoc))
       (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
   (while
       (progn (setvar 'errno 0) (setq obj (car (entsel "\nSelect dynamic block to split: ")))
           (cond
               (   (= 7 (getvar 'errno))
                   (princ "\nMissed, try again.")
               (   (null obj) nil)
               (   (= 4 (logand 4 (cdr (assoc 70 (tblsearch "layer" (cdr (assoc 8 (entget obj))))))))
                   (princ "\nSelected object is on a locked layer.")
               (   (/= "AcDbBlockReference" (vla-get-objectname (setq obj (vlax-ename->vla-object obj))))
                   (princ "\nSelected object is not a block.")
               (   (= :vlax-false (vla-get-isdynamicblock obj))
                   (princ "\nSelected block is not dynamic.")
               (   (null (setq prp (LM:getvisibilityparametername obj)))
                   (princ "\nSelected dynamic block does not have a visibility parameter.")
   (if obj
           (LM:startundo (LM:acdoc))
           (setq blk (vla-get-effectivename obj)
                 dis 0.0
                 prp
               (vl-some
                  '(lambda ( x )
                       (if (= (strcase prp) (strcase (vla-get-propertyname x))) x)
                   (vlax-invoke obj 'getdynamicblockproperties)
           (foreach x (vlax-get prp 'allowedvalues)
               (vla-put-value prp (vlax-make-variant x vlax-vbstring))
               (vla-move
                   (setq tmp (vla-copy obj))
                   (vlax-3D-point 0 0)
                   (vlax-3D-point dis 0)
               (vla-converttostaticblock tmp (uniqueblockname (strcat blk "_" x)))
               (vla-getboundingbox tmp 'llp 'urp)
               (setq dis (+ dis (* 1.1 (apply '- (mapcar '(lambda ( x ) (car (vlax-safearray->list x))) (list urp llp))))))
           (vla-delete obj)
(defun uniqueblockname ( key / cnt rtn )
   (if (tblsearch "block" key)
           (setq cnt 1)
           (while
               (tblsearch "block"
                   (setq rtn (strcat key "(" (itoa (setq cnt (1+ cnt))) ")"))
           rtn
       key
;; Get Visibility Parameter Name  -  Lee Mac
;; Returns the name of the Visibility Parameter of a Dynamic Block (if present)
;; blk - [vla] VLA Dynamic Block Reference object
;; Returns: [str] Name of Visibility Parameter, else nil
(defun LM:getvisibilityparametername ( blk / vis )
   (if
       (and
           (vlax-property-available-p blk 'effectivename)
           (setq blk
               (vla-item
                   (vla-get-blocks (vla-get-document blk))
                   (vla-get-effectivename blk)
           (= :vlax-true (vla-get-isdynamicblock blk))
           (= :vlax-true (vla-get-hasextensiondictionary blk))
           (setq vis
               (vl-some
                  '(lambda ( pair )
                       (if
                           (and
                               (= 360 (car pair))
                               (= "BLOCKVISIBILITYPARAMETER" (cdr (assoc 0 (entget (cdr pair)))))
                           (cdr pair)
                   (dictsearch
                       (vlax-vla-object->ename (vla-getextensiondictionary blk))
                       "ACAD_ENHANCEDBLOCK"
       (cdr (assoc 301 (entget vis)))
;; Start Undo  -  Lee Mac
;; Opens an Undo Group.
(defun LM:startundo ( doc )
   (LM:endundo doc)
   (vla-startundomark doc)
;; End Undo  -  Lee Mac
;; Closes an Undo Group.
(defun LM:endundo ( doc )
   (while (= 8 (logand 8 (getvar 'undoctl)))
       (vla-endundomark doc)
;; Active Document  -  Lee Mac
;; Returns the VLA Active Document Object
(defun LM:acdoc nil
   (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
   (LM:acdoc)
(vl-load-com) (princ)
Brilliant as usual LeeMac. Stunning stuff. It is exactly what I was after even down to the naming of the blocks. Thanks.
  • 4 weeks later...
  • 8 years later...
