Guest Posted June 11, 2015 Share Posted June 11, 2015 Hi. I need help with a lisp. This lisp change layer to attribiute blocks. When the root start ask me to "Specify Layer name :" All the times i have already create this layer before run this lisp. Is it possible if the lisp can not find this layer to create it automaticaly and then continue (defun c:chlay (/ ss ly doc) ;; Tharwat 27.May.2014 ;; (if (and (/= (setq ly (getstring t "\n Specify Layer name :")) "") (if (not (tblsearch "LAYER" ly)) (progn (alert (strcat "Layer name < " ly " > is not found !!")) nil) t ) (princ "\n Select attributed blocks to change layer of Attributes ") (setq ss (ssget "_:L" '((0 . "INSERT") (66 . 1)))) ) (progn (vla-startUndomark (setq doc (vla-get-activedocument (vlax-get-acad-object)))) ((Lambda (i / sn e) (while (setq sn (ssname ss (setq i (1+ i)))) (setq e (tblobjname "BLOCK" (cdr (assoc 2 (entget sn))))) (while (setq e (entnext e)) (entmod (subst (cons 8 ly) (assoc 8 (entget e)) (entget e)))) (foreach x (vlax-invoke (vlax-ename->vla-object sn) 'getattributes) (vla-put-layer x ly)) ) ) -1 ) (vla-Endundomark doc) ) ) (princ) )(vl-load-com) Thanks Quote Link to comment Share on other sites More sharing options...
Tharwat Posted June 11, 2015 Share Posted June 11, 2015 What is the permanent layer name that you want to include in the lisp ? And what about the color,Ltype, and LineWeight ? Quote Link to comment Share on other sites More sharing options...
Guest Posted June 11, 2015 Share Posted June 11, 2015 Hi Tharwat .The name of the layer is not standard.It is better to type the name of the layer Quote Link to comment Share on other sites More sharing options...
Guest Posted June 11, 2015 Share Posted June 11, 2015 And what about the color,Ltype, and LineWeight ? But the most times the name of the layer is MES with color red and linetype continuous and and LineWeight default Quote Link to comment Share on other sites More sharing options...
Tharwat Posted June 11, 2015 Share Posted June 11, 2015 When the root start ask me to "Specify Layer name :" All the times i have already create this layer before run this lisp. Is it possible if the lisp can not find this layer to create it automaticaly and then continue Hi Tharwat .The name of the layer is not standard.It is better to type the name of the layer So what's for this thread ? Quote Link to comment Share on other sites More sharing options...
Guest Posted June 11, 2015 Share Posted June 11, 2015 TharwatQuote Originally Posted by prodromosm View Post When the root start ask me to "Specify Layer name :" All the times i have already create this layer before run this lisp. Is it possible if the lisp can not find this layer to create it automaticaly and then continue Quote Originally Posted by prodromosm View Post Hi Tharwat .The name of the layer is not standard.It is better to type the name of the layer So what's for this thread ? Nice !!!!!!! I don't want to create all the times the layers ... Because the most of the times i run the lisp and then i go back and create the layer and run the lisp again ..... I want if the lisp can not find the layer , dont stop but create it and continue Quote Link to comment Share on other sites More sharing options...
Tharwat Posted June 11, 2015 Share Posted June 11, 2015 But the most times the name of the layer is MES with color red and linetype continuous and and LineWeight default (defun c:chlay (/ ss doc) ;; Tharwat 11.06.2015 ;; (if (not (tblsearch "LAYER" "MES")) (entmake (list '(0 . "LAYER") '(100 . "AcDbSymbolTableRecord") '(100 . "AcDbLayerTableRecord") '(2 . "MES") '(62 . 1) '(6 . "Continuous") '(370 . -3) '(70 . 0))) ) (princ "\n Select attributed blocks to change layer of Attributes ") (if (setq ss (ssget "_:L" '((0 . "INSERT") (66 . 1)))) (progn (vla-startUndomark (setq doc (vla-get-activedocument (vlax-get-acad-object)))) ((Lambda (i / sn e) (while (setq sn (ssname ss (setq i (1+ i)))) (setq e (tblobjname "BLOCK" (cdr (assoc 2 (entget sn))))) (while (setq e (entnext e)) (entmod (subst (cons 8 "MES") (assoc 8 (entget e)) (entget e)))) (foreach x (vlax-invoke (vlax-ename->vla-object sn) 'getattributes) (vla-put-layer x "MES")) ) ) -1 ) (vla-Endundomark doc) ) ) (princ) )(vl-load-com) Quote Link to comment Share on other sites More sharing options...
Guest Posted June 11, 2015 Share Posted June 11, 2015 We can not change it to something like this ? (defun c:chlay3 (/ ss doc) ;; Tharwat 11.06.2015 ;; (if (and (/= (setq ly (getstring t "\n Specify Layer name :")) "") (if (not (tblsearch "LAYER" ly)) (entmake (list '(0 . "LAYER") '(100 . "AcDbSymbolTableRecord") '(100 . "AcDbLayerTableRecord") '(2 . ly ) '(62 . 1) '(6 . "Continuous") '(370 . -3) '(70 . 0))) ) (princ "\n Select attributed blocks to change layer of Attributes ") (if (setq ss (ssget "_:L" '((0 . "INSERT") (66 . 1)))) (progn (vla-startUndomark (setq doc (vla-get-activedocument (vlax-get-acad-object)))) ((Lambda (i / sn e) (while (setq sn (ssname ss (setq i (1+ i)))) (setq e (tblobjname "BLOCK" (cdr (assoc 2 (entget sn))))) (while (setq e (entnext e)) (entmod (subst (cons 8 ly) (assoc 8 (entget e)) (entget e)))) (foreach x (vlax-invoke (vlax-ename->vla-object sn) 'getattributes) (vla-put-layer x ly )) ) ) -1 ) (vla-Endundomark doc) ) ) (princ) )(vl-load-com) Quote Link to comment Share on other sites More sharing options...
Guest Posted June 11, 2015 Share Posted June 11, 2015 Hi Tharwat . Can you tell me were is the error ? (defun c:chlay3 (/ ss doc) ;; Tharwat 11.06.2015 ;; (if (and (/= (setq ly (getstring t "\n Specify Layer name :")) "") (if (not (tblsearch "LAYER" ly)) (entmake (list '(0 . "LAYER") '(100 . "AcDbSymbolTableRecord") '(100 . "AcDbLayerTableRecord") '(2 . ly ) '(62 . 1) '(6 . "Continuous") '(370 . -3) '(70 . 0))) ) (princ "\n Select attributed blocks to change layer of Attributes ") (if (setq ss (ssget "_:L" '((0 . "INSERT") (66 . 1)))) (progn (vla-startUndomark (setq doc (vla-get-activedocument (vlax-get-acad-object)))) ((Lambda (i / sn e) (while (setq sn (ssname ss (setq i (1+ i)))) (setq e (tblobjname "BLOCK" (cdr (assoc 2 (entget sn))))) (while (setq e (entnext e)) (entmod (subst (cons 8 ly) (assoc 8 (entget e)) (entget e)))) (foreach x (vlax-invoke (vlax-ename->vla-object sn) 'getattributes) (vla-put-layer x ly )) ) ) -1 ) (vla-Endundomark doc) ) ) (princ) )(vl-load-com) Thanks Quote Link to comment Share on other sites More sharing options...
tombu Posted June 11, 2015 Share Posted June 11, 2015 Hi Tharwat . Can you tell me were is the error ? (if (not (tblsearch "LAYER" ly)) (entmake (list '(0 . "LAYER") '(100 . "AcDbSymbolTableRecord") '(100 . "AcDbLayerTableRecord") [b][color="red"]'(2 . ly )[/color][/b] '(62 . 1) '(6 . "Continuous") '(370 . -3) '(70 . 0))) ) Thanks Take a look at: http://www.lee-mac.com/quote.html about when using Apostrophe is ok and when it is not. Quote Link to comment Share on other sites More sharing options...
Guest Posted June 11, 2015 Share Posted June 11, 2015 Ηι tombu .I can not understand . I guess that the erros is here '(2 . ly ) but i don't know how to write it !!! Quote Link to comment Share on other sites More sharing options...
tombu Posted June 11, 2015 Share Posted June 11, 2015 The value of ly must be evaluated which the quote function does not do so try (cons 2 ly) instead. Quote Link to comment Share on other sites More sharing options...
Guest Posted June 11, 2015 Share Posted June 11, 2015 Not working .Gives me this error ; error: malformed list on input (defun c:test (/ ss doc) ;; Tharwat 11.06.2015 ;; (if (and (/= (setq ly (getstring t "\n Specify Layer name :")) "") (if (not (tblsearch "LAYER" ly)) (entmake (list '(0 . "LAYER") '(100 . "AcDbSymbolTableRecord") '(100 . "AcDbLayerTableRecord") (cons 2 ly) '(62 . 1) '(6 . "Continuous") '(370 . -3) '(70 . 0))) ) (princ "\n Select attributed blocks to change layer of Attributes ") (if (setq ss (ssget "_:L" '((0 . "INSERT") (66 . 1)))) (progn (vla-startUndomark (setq doc (vla-get-activedocument (vlax-get-acad-object)))) ((Lambda (i / sn e) (while (setq sn (ssname ss (setq i (1+ i)))) (setq e (tblobjname "BLOCK" (cdr (assoc 2 (entget sn))))) (while (setq e (entnext e)) (entmod (subst (cons 8 ly) (assoc 8 (entget e)) (entget e)))) (foreach x (vlax-invoke (vlax-ename->vla-object sn) 'getattributes) (vla-put-layer x ly )) ) ) -1 ) (vla-Endundomark doc) ) ) (princ) )(vl-load-com) Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 12, 2015 Share Posted June 12, 2015 (edited) Try (list ( cons 2 ly)) Given the number of posts I would start to consider setting up a library of defuns like makelay you would save all of these in 1 lisp and auto load at startup this way its available for any routine given the example above. ; save this in the libray lisp (defun entmaklay (ly / ) (entmake (list '(0 . "LAYER") '(100 . "AcDbSymbolTableRecord") '(100 . "AcDbLayerTableRecord") (cons 2 ly) '(62 . 1) '(6 . "Continuous") '(370 . -3) '(70 . 0))) ) ) ; these 4 lines is all you need in any program now (if (and (/= (setq ly (getstring t "\n Specify Layer name :")) "") (if (not (tblsearch "LAYER" ly)) (entmklay ly) )) Edited June 12, 2015 by BIGAL Quote Link to comment Share on other sites More sharing options...
Guest Posted June 12, 2015 Share Posted June 12, 2015 Hi BIGAL. I did the changes but not working ... ;; Tharwat 11.06.2015 ;; (defun entmaklay (ly / ) (entmake (list '(0 . "LAYER") '(100 . "AcDbSymbolTableRecord") '(100 . "AcDbLayerTableRecord") (list (cons 2 ly)) '(62 . 1) '(6 . "Continuous") '(370 . -3) '(70 . 0))) ) ) (defun c:test (/ ss doc) (if (and (/= (setq ly (getstring t "\n Specify Layer name :")) "") (if (not (tblsearch "LAYER" ly)) (entmklay ly) )) (princ "\n Select attributed blocks to change layer of Attributes ") (if (setq ss (ssget "_:L" '((0 . "INSERT") (66 . 1)))) (progn (vla-startUndomark (setq doc (vla-get-activedocument (vlax-get-acad-object)))) ((Lambda (i / sn e) (while (setq sn (ssname ss (setq i (1+ i)))) (setq e (tblobjname "BLOCK" (cdr (assoc 2 (entget sn))))) (while (setq e (entnext e)) (entmod (subst (cons 8 ly) (assoc 8 (entget e)) (entget e)))) (foreach x (vlax-invoke (vlax-ename->vla-object sn) 'getattributes) (vla-put-layer x ly )) ) ) -1 ) (vla-Endundomark doc) ) ) (princ) )(vl-load-com) Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 12, 2015 Share Posted June 12, 2015 Sorry the cons 2 works its in your ly I admit i dont do a lot of error checking take it for granted if some uses lisp they do what it asks. maybe if (and (/= (setq ly (getstring "\n Specify Layer name :")) nil) ; mine (setq ly (getstring "\n Specify Layer name :")) ; I use a dcl now more often looks nicer and middle of screen. Quote Link to comment Share on other sites More sharing options...
Guest Posted June 12, 2015 Share Posted June 12, 2015 Now i have this error !!! ; error: no function definition: ENTMKLAY ;; Tharwat 11.06.2015 ;; (defun c:test (/ ss doc) (defun entmaklay (ly / ) (entmake (list '(0 . "LAYER") '(100 . "AcDbSymbolTableRecord") '(100 . "AcDbLayerTableRecord") (list (cons 2 ly)) '(62 . 1) '(6 . "Continuous") '(370 . -3) '(70 . 0))) ) ) (setq ly (getstring "\n Specify Layer name :")) (if (not (tblsearch "LAYER" ly)) (entmklay ly) )) (princ "\n Select attributed blocks to change layer of Attributes ") (if (setq ss (ssget "_:L" '((0 . "INSERT") (66 . 1)))) (progn (vla-startUndomark (setq doc (vla-get-activedocument (vlax-get-acad-object)))) ((Lambda (i / sn e) (while (setq sn (ssname ss (setq i (1+ i)))) (setq e (tblobjname "BLOCK" (cdr (assoc 2 (entget sn))))) (while (setq e (entnext e)) (entmod (subst (cons 8 ly) (assoc 8 (entget e)) (entget e)))) (foreach x (vlax-invoke (vlax-ename->vla-object sn) 'getattributes) (vla-put-layer x ly )) ) ) -1 ) (vla-Endundomark doc) ) ) (princ) )(vl-load-com) Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 12, 2015 Share Posted June 12, 2015 entmaklay entmklay also the idea is to keep the entmakes outside your c:test extras you may like to add entline entarc entaddblock chklay ; update defun entmaklay (ly / ) (if (not (tblsearch "LAYER" ly)) (entmake (list '(0 . "LAYER") '(100 . "AcDbSymbolTableRecord") '(100 . "AcDbLayerTableRecord") (list (cons 2 ly)) '(62 . 1) '(6 . "Continuous") '(370 . -3) '(70 . 0))) ) ) ) ;to use only 1 line required (entmaklay ly) ; or (entmaklay "ASDF") here is some sample code from an extensive package written over 20 years ago (if (= setsc nil)(scaleset)) (setq lay_search wall--3) (setq lay_colour wall--3col) (setq l_type wall--3lin) (lay_miss) (setq lay_search door--2) (setq lay_colour door--2col) (setq l_type door--2lin) (lay_miss) (setq lay_search text--2) (setq lay_colour text--2col) (setq l_type text--2lin) (lay_miss) Quote Link to comment Share on other sites More sharing options...
tombu Posted June 12, 2015 Share Posted June 12, 2015 Try: (defun entmaklay (ly / ) (if (not (tblsearch "LAYER" ly)) (entmake (list '(0 . "LAYER") '(100 . "AcDbSymbolTableRecord") '(100 . "AcDbLayerTableRecord") (cons 2 ly) '(62 . 1) '(6 . "Continuous") '(370 . -3) '(70 . 0) ) ) ) ) (defun c:chlay (/ ss ly doc) ;; Tharwat 27.May.2014 ;; (if (and (/= (setq ly (getstring t "\n Specify Layer name :")) "") (if (not (tblsearch "LAYER" ly))(entmaklay ly)) (princ "\n Select attributed blocks to change layer of Attributes ") (setq ss (ssget "_:L" '((0 . "INSERT") (66 . 1)))) ) (progn (vla-startUndomark (setq doc (vla-get-activedocument (vlax-get-acad-object)))) ((Lambda (i / sn e) (while (setq sn (ssname ss (setq i (1+ i)))) (setq e (tblobjname "BLOCK" (cdr (assoc 2 (entget sn))))) (while (setq e (entnext e)) (entmod (subst (cons 8 ly) (assoc 8 (entget e)) (entget e)))) (foreach x (vlax-invoke (vlax-ename->vla-object sn) 'getattributes) (vla-put-layer x ly)) ) ) -1 ) (vla-Endundomark doc) ) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
Guest Posted June 12, 2015 Share Posted June 12, 2015 Thank you tombu ,BIGAL ,Tharwat Quote Link to comment Share on other sites More sharing options...
