Extract an attribute from all blocks in a drawing
AldLuj28
Hi there.. im new in the forum and in coding in AutoLisp... so im looking for a form in which i can extract a specific attribute from all blocks that are in a DWG and then this list write it in a txt file :unsure:
Welcome to the forum :)
Are you a ware of the command attout ?
Yeah im aware of it im trying to do something like this:
(defun C:AELD (/ objBlock strValue)
(setq AllBlocks (ssget "X" (list (cons 0 "INSERT"))))
(repeat (sslength AllBlocks)
 (setq objBlock (vlax-ename->vla-object (CDR (CAR (entget (ssname AllBlocks))))))
 (foreach objAttribute (vlax-invoke objBlock "getattributes")
(if (= (strcase (vla-get-tagstring objAttribute));
     (strcase "DeviceID"))
    (setq strValue (vla-get-textstring objAttribute))
(princ strValue)
but it throws me an error : too few arguments
Edited by rkmcswain
added [CODE] tags
Things like this ?
(defun c:Test (/ ss sn i e)
 ;; Tharwat 18.06.2015 ;;
 (if (setq ss (ssget '((0 . "INSERT") (66 . 1))))
     (setq sn (ssname ss (setq i (1- i))))
     (while (/= (cdr (assoc 0 (setq e (entget sn)))) "SEQEND")
       (if (not (eq (cdr (assoc 1 e)) nil))
         (print (cdr (assoc 1 e)))
       (setq sn (entnext sn))
Yeah something like that but i want that all the blocks are selected automacally.. cause i need a specific attribute from all blocks
Just add "_X" after the ssget function.
Ok, but if i want to ... find only the attribute named "DevicedID1" that is part from all the blocks, what i need to add.. and one thing more to write this string in a text i can use (setq fil(open "file" "w")?
Try this ...
(defun c:Test (/ ss fl on sn i e)
 (if (and (setq ss (ssget "_X" '((0 . "INSERT") (66 . 1))))
          (setq fl (getfiled "Specify name of txt file"
                             (getvar 'dwgprefix)
                             "txt"
                             1
          (setq on (open fl "w"))
       (if (and (eq (cdr (assoc 0 e)) "ATTRIB")
                (eq (strcase (cdr (assoc 2 e))) "DEVICEDID1")
         (write-line (cdr (assoc 1 e)) on)
 (if on
   (close on)
Thanks ..finally i made it work... i changed some stuff ... and the result its this totally functional :
(defun c: PROMISE (/ ss fl on sn i e)
(setq on (open "C:\\Temp\\Emblemas.txt" "w"))
(if(not(eq (cdr (assoc 1 e)) ""))
(princ (strcat "," (cdr (assoc 1 e))) on)
(if on
(close on)
Again thanks a lot for the help :D
Edited by AldLuj28
Firstly , what you have modified is not matching or following what you have asked in your previous post .
Secondly , it is a very bad idea to remove the author name from my codes or anyone's codes/ works.
