Results 1 to 9 of 9
    Junior Member
    AutoCAD 2015
    Mar 2015
    22
    Default Extrim command very slow
    Hello everybody!
    If I want to use the "extrim" command, I do select a line first and after this I click on side next to the line.
    After that, AutoCad does, first, zooms in very, very slow to the line I'd selected. Second, he trims all the lines next to the selected line, on the side I've chosen.
    Finally, AutoCad zooms out very, very slow...........
    Sometimes it takes 30 seconds or something for extrim a couple of lines.
    I'm using AutoCad 2015 at this moment. I had also used older versions. Some versions also had this problem but in some versions it went very fast!
    Zoom in, extrim and zoom out were done in 1 second.
    Anybody knows how I can solve this?
    (variables Edgemode=0 and Projmode=1)
    example extrim.dwg
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    Attach a copy of the drawing to your next post. Someone will test it on their system to see if they experience the same problem.
    Junior Member
    AutoCAD 2015
    Mar 2015
    22
    Example attached
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    I fully expected a copy of the actual drawing not an example. But....................
    No problem here. Probably took about a tenth of a second to complete the task.
  5. #5
    Junior Member
    AutoCAD 2015
    Mar 2015
    22
    If I use the extrim command in this example drawing (size 33.5kb), it tooks 10 seconds already before AutoCad was finished. The bigger the drawing, the longer it takes.
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    Maybe you have an under-performing system.
    Addendum:
    I opened your drawing a second time and arrayed the horizontal lines nine additional times and stretched the one vertical (trimming) line. Then I ran the EXTRIM command. Practically the same result. The command executed in barely the blink of an eye. I then doubled the number of lines (close to 200), ran the command and attained similar results.
  7. #7
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,126
    Maybe you can post your computer specifications?
    Are you working on a network?
  8. #8
    Junior Member
    AutoCAD 2015
    Mar 2015
    22
    Quote Originally Posted by SLW210 View Post
    Computer specifactions:
    Windows 7 SP1
    Intel(R) Xeon(R) CPU E3-1220 v3 @ 3.10 GHz
    RAM 16 GB
    System 64-bit
    Yes I am working on a network.
  9. #9
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    My computer specs are not as good as yours yet I have no problem. Strange.
  1. EXTRIM Between Two Lines
    By sidhu412 in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Aug 2014, 07:19 pm
  2. Adding " Extrim" command to my Tool Platte
    By samifox in forum AutoCAD General
    Last Post: 31st Jan 2013, 04:49 pm
  3. Extrim not working in lisp
    By BIGAL in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Jan 2013, 12:53 am
  4. Extrim command
    By chizifreshi in forum AutoCAD General
    Last Post: 30th Jan 2012, 02:57 pm
  5. slow command prompt
    By geo in forum AutoCAD General
    Last Post: 3rd Dec 2008, 10:29 pm
Tags for this Thread
