AbhilashDK2014 Posted October 8, 2015 Share Posted October 8, 2015 Hi All, I am a complete newbie for AutoCad and AutoCad.NET. I am stuck with a problem. I am asking the user to select a block reference which has three attribures namely LINEUP, BAY and HL. Then I am trying to create a copy of it. But the attributes LINEUP and BAY (Values of these) are not being copied. Can You please help me out with this issue. Original Block With Attributes : See Image OriginalBlockWithAttributes.png New Block Without Values of the Attributes : See Image NewBlockWithoutAttributes.png Here is the VB.NET Code : <CommandMethod("WithAttr2")> _ Public Sub WithAttr2() Dim doc As Document = Application.DocumentManager.MdiActiveDocument Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor Dim database As Database = ed.Document.Database Dim blockName As String Dim blockRef1 As BlockReference Dim options As PromptEntityOptions = New PromptEntityOptions("\nSelect block reference") options.SetRejectMessage("\nSelect only block reference") options.AddAllowedClass(GetType(BlockReference), False) Dim acSSPrompt As PromptEntityResult = ed.GetEntity(options) Using tx As Transaction = database.TransactionManager.StartTransaction() Dim blockRef As BlockReference = TryCast(tx.GetObject(acSSPrompt.ObjectId, OpenMode.ForRead), BlockReference) Dim block As BlockTableRecord = Nothing If (blockRef.IsDynamicBlock) Then 'get the real dynamic block name. block = TryCast(tx.GetObject(blockRef.DynamicBlockTableRecord, OpenMode.ForRead), BlockTableRecord) Else block = TryCast(tx.GetObject(blockRef.BlockTableRecord, OpenMode.ForRead), BlockTableRecord) End If If (block <> Nothing) Then Dim sfilter As New SelectionFilter(New TypedValue() {New TypedValue(CInt(DxfCode.Start), "INSERT"), New TypedValue(2, block.Name)}) Dim res As PromptSelectionResult = ed.SelectAll(sfilter) If res.Status = PromptStatus.OK Then 'display result MsgBox("---> Selected " & res.Value.Count & " objects", res.Value.Count) Dim Objectset As SelectionSet = res.Value For Each id As ObjectId In Objectset.GetObjectIds() blockRef1 = TryCast(tx.GetObject(id, OpenMode.ForRead), BlockReference) MsgBox(blockRef1.Name) blockName = blockRef1.Name 'Dim pt As New Point3d(0, 0, 0) 'ACADBlockMgr.InsertBlockWithAtt(blockRef1.Name, pt) Next End If End If tx.Commit() End Using Using trans As Transaction = database.TransactionManager.StartTransaction Dim blkTable As BlockTable = TryCast(database.BlockTableId.GetObject(OpenMode.ForRead), BlockTable) Dim blkRecId As ObjectId = blkTable(blockName) MsgBox(blkRecId.ToString()) If blkRecId <> ObjectId.Null Then Dim blkTableRecord As BlockTableRecord = trans.GetObject(blkRecId, OpenMode.ForRead) Using acBlkRef As New BlockReference(New Point3d(2, 2, 0), blkTableRecord.Id) Dim currentSpaceBlkTableRec As BlockTableRecord = trans.GetObject(database.CurrentSpaceId, OpenMode.ForWrite) currentSpaceBlkTableRec.AppendEntity(acBlkRef) trans.AddNewlyCreatedDBObject(acBlkRef, True) 'Check For Attributes If blkTableRecord.HasAttributeDefinitions Then 'Add attributes from Block Table Records For Each objId As ObjectId In blkTableRecord Dim dbObj As DBObject = trans.GetObject(objId, OpenMode.ForRead) If TypeOf dbObj Is AttributeDefinition Then Dim attrDef As AttributeDefinition = dbObj MsgBox(attrDef.Tag & " " & attrDef.TextString) If Not attrDef.Constant Then Using attRef As New AttributeReference attRef.SetAttributeFromBlock(attrDef, acBlkRef.BlockTransform) attRef.Position = attRef.Position.TransformBy(acBlkRef.BlockTransform) attRef.TextString = attrDef.TextString acBlkRef.AttributeCollection.AppendAttribute(attRef) trans.AddNewlyCreatedDBObject(attRef, True) End Using End If End If Next End If End Using End If trans.Commit() End Using End Sub What am I doing wrong here. Please let me know. Thanks in Advance, Abhilash D K Quote Link to comment Share on other sites More sharing options...
