3drookie Posted October 15, 2015 Posted October 15, 2015 When using loft,if Mode is Solid, what determines the wall thickness of the resulting solid? Related: I am trying to work around the error of curved objects/surfaces intersecting with themselves when they are thickened. Thanks in advance Quote
ReMark Posted October 15, 2015 Posted October 15, 2015 (edited) Normally it would be the distance between the lofted profiles but without seeing your drawing I can't give you a definitive answer. Attach a copy of the drawing to your next post. Someone here will take a look at it and perhaps have a solution to your problem. Edited October 16, 2015 by ReMark Quote
