Page 6 of 6 FirstFirst ... 4 5 6
Results 51 to 55 of 55
  1. #51
    Full Member
    AutoCAD 2010
    Nov 2015
    37
    ReMark,
    The dilemma is that each discipline do their drawings differently, so they behave differently somehow.
  2. #52
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    If you are plotting from a layout there should be no reason to preview assuming all plot parameters have not changed for some inexplicable reason.
    Giving you time to make that check of the final product. Problems are more likely to show up after printing. Settings are easy. Machines are less reliable in my experience. I look at each and every sheet that I generate, be it PDF or hard copy, before they go out. I've got more confidence in my plot settings than I do in even our expensive plotters and PDF software.
    Quote Originally Posted by Elly26 View Post
    IMHO, that shouldn't happen but it shouldn't matter. I don't know enough about your work environment to offer suggestions but there are ways to manage these problems that will make your job easier. Getting them adopted into your standards could help you out a lot.
    Drafting is a breeze.
  3. #53
    Full Member
    AutoCAD 2010
    Nov 2015
    37
    RobDraw,
    Exactly what I am trying to explain.
  4. #54
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    RobDraw,
    That's funny. I was disagreeing with you.
  5. #55
    Full Member
    AutoCAD 2010
    Nov 2015
    37
    "I look at each and every sheet that I generate, be it PDF or hard copy, before they go out."
    That I agree with.
  1. Can't Open Drawings
    By DannySully91 in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 11th Feb 2015, 09:08 pm
  2. two open drawings
    By welcad in forum AutoCAD Beginners' Area
    Last Post: 9th Apr 2011, 08:22 pm
  3. Cannot open MEP drawings with ADT
    By BDIZZEL124 in forum MEP
    Last Post: 14th Apr 2008, 02:06 pm
  4. Open drawings using VB .NET
    By bsamc2000 in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Sep 2007, 03:15 pm
  5. Drawings won't open!
    By Cadastrophic in forum AutoCAD Drawing Management & Output
    Last Post: 17th Nov 2006, 04:03 pm
