3dwannab Posted December 6, 2015 Share Posted December 6, 2015 I was hoping to get help with a LISP to: Select a hatch The lisp then takes the scale size and hatch pattern name and selects the same hatches with those attributes. I can then globally and manually change them in the properties dialog. This is particularly useful when adjusting hatch scales. I'm not worried about layers, colors etc. Just these two properties. Thanks. My lisp knowledge is basic: I know how to select only hatches via below but I'd like to know how to get the info from whats picked and use that info: (defun c:QS_HATCH_ALL (/ ss) (if (setq ss (ssget '((0 . "HATCH")))) (princ (strcat "\nNumber of found hatches : < " (itoa (sslength ss)) " >")) (princ "\n*** Nothing Selected ***") ) (sssetfirst nil ss) (princ) ) Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 6, 2015 Share Posted December 6, 2015 Try this (setq ent (entget (car (entsel "Pick a hatch")))) (setq hname (cdr (assoc 2 ent))) (setq sc (cdr (assoc 41 ent))) (setq ss (ssget (list (cons 0 "HATCH")(cons 2 hname)(cons 41 sc)))) Quote Link to comment Share on other sites More sharing options...
Tharwat Posted December 6, 2015 Share Posted December 6, 2015 Try this UNTESTED codes. (defun c:qs_hatch (/ s e ss) (princ "\nPick on hatch object to select similar with Pattern name & Scale :") (and (setq s (ssget "_+.:S:E" '((0 . "HATCH")))) (setq e (entget (ssname s 0))) (setq ss (ssget "_X" (list '(0 . "HATCH") (assoc 2 e) (assoc 41 e) (cons 410 (getvar 'ctab)) ) ) ) ) (sssetfirst nil ss) (princ) ) Quote Link to comment Share on other sites More sharing options...
3dwannab Posted December 6, 2015 Author Share Posted December 6, 2015 Try this (setq ent (entget (car (entsel "Pick a hatch")))) (setq hname (cdr (assoc 2 ent))) (setq sc (cdr (assoc 41 ent))) (setq ss (ssget (list (cons 0 "HATCH")(cons 2 hname)(cons 41 sc)))) Tried this but didn't work I'm afraid. Probably something I did. (defun c:test ( \hname sc ss) (setq ent (entget (car (entsel "Pick a hatch")))) (setq hname (cdr (assoc 2 ent))) (setq sc (cdr (assoc 41 ent))) (setq ss (ssget (list (cons 0 "HATCH")(cons 2 hname)(cons 41 sc)))) ;;(sssetfirst nil ss) ) ;_ end defun Tharwat Thank you Thank you. Don't know how I managed without this before now! What does the line do: (setq s (ssget "_+.:S:E" '((0 . "HATCH")))) Quote Link to comment Share on other sites More sharing options...
Tharwat Posted December 6, 2015 Share Posted December 6, 2015 Tharwat Thank you Thank you. Don't know how I managed without this before now! What does the line do: (setq s (ssget "_+.:S:E" '((0 . "HATCH")))) You're welcome. That line with the ssget function is to allow the user to pick only ONE object and the we have only one object name which is HATCH in the previous example. Quote Link to comment Share on other sites More sharing options...
3dwannab Posted December 6, 2015 Author Share Posted December 6, 2015 You're welcome. That line with the ssget function is to allow the user to pick only ONE object and the we have only one object name which is HATCH in the previous example. I see thank you. Just noticed one thing I never thought of was a solid hatch which doesn't have scale (I think) as the LISP fails when selecting it. I know shows up in the properties but the LISP should still work. Would it be hard to make the LISP work when selecting soild hatch only: - select it with the same pattern, layer AND color as opposed my previous request. - if I select any other type hatch the previous LISP takes care of them. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted December 6, 2015 Share Posted December 6, 2015 (edited) This should work . (defun c:qs_hatch (/ s e ss c fltr) ;; Tharwat 06.Dec.2015 ;; (princ "\nPick on hatch object to select similar with Pattern name & Scale :" ) (and (setq s (ssget "_+.:S:E" '((0 . "HATCH")))) (setq e (entget (ssname s 0))) (setq fltr (list (assoc 8 e) (if (setq c (assoc 62 e)) c '(62 . 256) ) ) ) (if (eq (cdr (assoc 2 e)) "SOLID") (setq fltr (append fltr (list (assoc 2 e)))) (setq fltr (list (assoc 2 e) (assoc 41 e))) ) (setq ss (ssget "_X" (append '((0 . "HATCH")) (list (cons 410 (getvar 'ctab))) fltr ) ) ) ) (sssetfirst nil ss) (princ) ) Edited December 6, 2015 by Tharwat Quote Link to comment Share on other sites More sharing options...
3dwannab Posted December 6, 2015 Author Share Posted December 6, 2015 Thanks for that. But if I select a solid hatch it selects other hatch patterns on the same layer also. To recap: - For solid hatches - select same pattern name, layer, color - For all others - the first method you wrote. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted December 6, 2015 Share Posted December 6, 2015 Codes updated above. Quote Link to comment Share on other sites More sharing options...
3dwannab Posted December 6, 2015 Author Share Posted December 6, 2015 Codes updated above. Attached is drawing. Still the same. If I select the solid hatch for the glazing it selects other hatch patterns too. It's a true color so maybe that's an issue? test dwg.dwg Quote Link to comment Share on other sites More sharing options...
Tharwat Posted December 6, 2015 Share Posted December 6, 2015 Sorry , I forgot to add the pattern name with the filter and that's why it did select the rest of the other pattern names when you pick a solid. Anyway codes updated above. Quote Link to comment Share on other sites More sharing options...
3dwannab Posted December 6, 2015 Author Share Posted December 6, 2015 Sorry but it's missing the filter for the color in solid hatches Quote Link to comment Share on other sites More sharing options...
Tharwat Posted December 6, 2015 Share Posted December 6, 2015 Updated again. Quote Link to comment Share on other sites More sharing options...
3dwannab Posted December 6, 2015 Author Share Posted December 6, 2015 Ah, append added!! It was a simple fix. I really need to learn LISP. I'm learning max script so I don't want to melt my brain altogether!! Thanks very much Quote Link to comment Share on other sites More sharing options...
Tharwat Posted December 6, 2015 Share Posted December 6, 2015 Excellent. You're most welcome Quote Link to comment Share on other sites More sharing options...
eyeofnewt555 Posted February 7, 2017 Share Posted February 7, 2017 This should work . Aaaand, hope you're still paying attention over a year later. How could the filters on this be edited to ignore differences in scale and to only select hatches on the same layer as the one originally selected? Also, would it be difficult to have this work on multiple hatches? Let's say I select one instance of hatch "A" and one instance of hatch "B" -- could it grab all instances of both of those hatches on same layer? Basically, the way SelectSimilar works. Thanks for any help! Quote Link to comment Share on other sites More sharing options...
3dwannab Posted February 9, 2017 Author Share Posted February 9, 2017 Aaaand, hope you're still paying attention over a year later. How could the filters on this be edited to ignore differences in scale and to only select hatches on the same layer as the one originally selected? Also, would it be difficult to have this work on multiple hatches? Let's say I select one instance of hatch "A" and one instance of hatch "B" -- could it grab all instances of both of those hatches on same layer? Basically, the way SelectSimilar works. Thanks for any help! Hi, This is my first LISP. I was lazy the last two years so, I sat down for the last day or so to finally learn the basics anyway. I'm also sure that some LISP masters out there could write this in a 1/2 a line but any comments from them on it would be nice. With this LISP you can select any object and that in turn, will select any hatch on that objects layer. You don't need to select a hatch for it to work which is nice. Here you go: (I've left some help links in there that helped me write it): Syntax to run command is 'QSH' or 'QS_Hatch_On_Same_Layer' ; Select hatches on same layer by 3dwannab ; 09.02.2017 ; Usage: Select any object to select hatches on that layer ; uncomment below to get alart that selection is not 'HATCH' (defun c:QSH nil (c:QS_Hatch_On_Same_Layer)) (defun c:QS_Hatch_On_Same_Layer ( / ss layName ) (while (not (setq ss (car (entsel "\nSelect object:\n\nSelects hatches\non layer >>> "))))) (cond ((/= nil ss) (progn (setq layName (cdr (assoc 8 (entget ss)))) (setq ss (ssget "X" (list (cons 8 layName) '(0 . "HATCH") (cons 410 (getvar 'ctab))))) (if ss ( (progn (princ (strcat "\n" (itoa (setq len (sslength ss))) (if (> len 1) " items" " item") " selected")) (sssetfirst nil ss) ) ) (alert (strcat (getvar "loginname") ", no hatch on layer:\n\n'" layName "' exists in '" (getvar "ctab") "'.")) ) ) ) ) (princ) ) (princ "\n:: QS_Hatch_On_Same_Layer.lsp | Version 1.0 | by 3DwannaB ::") (princ "\n:: Type \"QS_Hatch_On_Same_Layer\" OR \"QSH\" to Invoke ::") (princ) ; Some help can be found here that helped me along the way: ; ------------------------------------------------------------ ; http://help.autodesk.com/view/ACD/2015/ENU/?guid=GUID-7BE77062-C359-4D01-915B-69CF672C653B ; http://www.lee-mac.com/ssget.html ; http://www.cadtutor.net/forum/showthread.php?55964-How-to-select-the-blocks-only-in-current-space-(either-model-or-paper-space)&p=421701&viewfull=1#post421701 Quote Link to comment Share on other sites More sharing options...
eyeofnewt555 Posted February 9, 2017 Share Posted February 9, 2017 Neat! congrats on your first lisp! I'm hoping to get to that point one day! If you're up for more practice, do you think it could still filter by patter name? So grab a hatch and run the lisp and it grabs all hatches of the same name on the same layer? Quote Link to comment Share on other sites More sharing options...
3dwannab Posted February 9, 2017 Author Share Posted February 9, 2017 Neat! congrats on your first lisp! I'm hoping to get to that point one day! If you're up for more practice, do you think it could still filter by patter name? So grab a hatch and run the lisp and it grabs all hatches of the same name on the same layer? Love the practice! It's additive. With this, I've went down a different route using the vla method which IMO is easier to understand. This took an hour to write. The other took me over a day ! BUT, my advice is, don't be scared and try to learn it. I've put links to where I got help in the code below. ; Select hatches on same layer & pattern by 3dwannab ; 09.02.2017 ; v1.1 ; Usage: Select hatch to select other hatches on similar Layer and pattern (vl-load-com) (defun c:QSH nil (c:QS_Hatch_Same_Layer&Pattern)) (defun c:QS_Hatch_Same_Layer&Pattern ( / ss layName hatchName ) (setq ss nil) (while (= ss nil) (setq ss (vlax-ename->vla-object (car (entsel "\nSelect hatch to select similar\nlayer & pattern: ")))) (cond ((= "AcDbHatch" (vla-get-ObjectName ss)) ;; cond 1 - is a hatch object (progn (setq hatchName (vla-get-PatternName ss)) (setq layName (vla-get-Layer ss)) (setq ss (ssget "X" (list (cons 8 layName) '(0 . "HATCH") (cons 2 hatchName) (cons 410 (getvar 'ctab))))) (princ (strcat "\n >>> " (itoa (setq len (sslength ss))) (if (> len 1) " items" " item") " selected <<< ")) (sssetfirst nil ss)(princ) ) ) ((/= "AcDbHatch" (vla-get-ObjectName ss)) ; cond 2 - not a hatch object (princ "\n >>> Please select a hatch ! <<< ")(princ) ) ) ) ) (princ "\n:: QS_Hatch_Same_Layer&Pattern.lsp | Version 1.1 | by 3Dwannab ::") (princ "\n:: Type \"QS_Hatch_Same_Layer&Pattern\" OR \"QSH\" to Invoke ::") (princ) ; Some help can be found here that helped me along the way: ; ------------------------------------------------------------ ; http://forums.augi.com/showthread.php?163322-Merge-all-hatch-objects-by-pattern-name ; http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/get-layer-name-and-colour-from-selected-object/td-p/5697086 ; http://forums.augi.com/showthread.php?68534-how-to-select-just-hatch-patterns ; http://www.afralisp.net/visual-lisp/tutorials/properties-methods-part-1.php ; http://www.afralisp.net/visual-lisp/tutorials/properties-methods-part-3.php ; http://www.afralisp.net/visual-lisp/tutorials/properties-methods-part-3.php Quote Link to comment Share on other sites More sharing options...
3dwannab Posted February 9, 2017 Author Share Posted February 9, 2017 Here's another selection filter tool if you're interested. I found this in my quest to learn. http://www.kimprojects.com/a-much-better-select-similar-autocad/ Quote Link to comment Share on other sites More sharing options...
