Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
    Senior Member ksperopoulos's Avatar
    ksperopoulos's Computer Details
    Windows 8.1 Enterprise; 64-bit
    HP Elitebook 8760w
    16GB
    NVIDIA Quadro 4000M
    AutoCAD 2016
    Feb 2009
    Kansas City, MO
    438
    Default Create Dimension Style Using Visual Lisp?
    Is there a way to create a dimension style via Visual LISP instead of AutoLISP? It seems like the only way I can find is by setting variables instead of properties (similar to how one can with layers, text styles, etc.).
    Kyle
    AutoCad MEP 2016; Fabrication CADmep 2016; Navisworks Manage 2016; Revit 2016
    HP Elitebook 8760w; Windows 8.1 Enterprise; 64-bit; 16GB RAM; NVIDIA Quadro 4000M
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2015
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,124
    Hi,
    An abstract example.
    Code:
    (vla-add (vla-get-dimstyles (vla-get-activedocument (vlax-get-acad-object))) "New Dim")
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,454
    The Visual LISP route will still involve configuring system variables and then using the copyfrom method.
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    HP Elitebook 8760w
    16GB
    NVIDIA Quadro 4000M
    AutoCAD 2016
    Feb 2009
    Kansas City, MO
    438
    Thank you for your response. I should have been more clear. I already have been able to add the style to the collection via vla-add, I am more interested though in setting the properties associated with the style.
    Kyle
  5. #5
    HP Elitebook 8760w
    16GB
    NVIDIA Quadro 4000M
    AutoCAD 2016
    Feb 2009
    Kansas City, MO
    438
    Quote Originally Posted by Lee Mac View Post
    Thank you Lee. That's what I thought. I just wanted to make sure I was headed down the right path if I chose to go with VL.
    Kyle
  6. #6
    HP Elitebook 8760w
    16GB
    NVIDIA Quadro 4000M
    AutoCAD 2016
    Feb 2009
    Kansas City, MO
    438
    I placed a dimensions using my dimension style in a drawing. I then did a vlax-dump-object on that it to see what it returned. I came up with a long list of information that seems like I would be able to use for creating the dimstyle. Can these properties be applied to a dimstyle or can they only be applied to an existing dimension in a drawing?
    Code:
    ; IAcadDimRotated: AutoCAD Rotated Dimension Interface
    ; Property values:
    ;   AltRoundDistance = 0.0
    ;   AltSubUnitsFactor = 100.0
    ;   AltSubUnitsSuffix = ""
    ;   AltSuppressLeadingZeros = 0
    ;   AltSuppressTrailingZeros = 0
    ;   AltSuppressZeroFeet = -1
    ;   AltSuppressZeroInches = -1
    ;   AltTextPrefix = ""
    ;   AltTextSuffix = ""
    ;   AltTolerancePrecision = 2
    ;   AltToleranceSuppressLeadingZeros = 0
    ;   AltToleranceSuppressTrailingZeros = 0
    ;   AltToleranceSuppressZeroFeet = -1
    ;   AltToleranceSuppressZeroInches = -1
    ;   AltUnits = 0
    ;   AltUnitsFormat = 2
    ;   AltUnitsPrecision = 2
    ;   AltUnitsScale = 25.4
    ;   Application (RO) = #<VLA-OBJECT IAcadApplication 00007ff7b8dfa130>
    ;   Arrowhead1Block = "ArchTick"
    ;   Arrowhead1Type = 4
    ;   Arrowhead2Block = "ArchTick"
    ;   Arrowhead2Type = 4
    ;   ArrowheadSize = 0.09375
    ;   DecimalSeparator = "."
    ;   DimConstrDesc = Exception occurred
    ;   DimConstrExpression = Exception occurred
    ;   DimConstrForm = 0
    ;   DimConstrName = Exception occurred
    ;   DimConstrReference = 0
    ;   DimConstrValue = Exception occurred
    ;   DimensionLineColor = 256
    ;   DimensionLineExtend = 0.0625
    ;   DimensionLinetype = "Continuous"
    ;   DimensionLineWeight = 25
    ;   DimLine1Suppress = 0
    ;   DimLine2Suppress = 0
    ;   DimLineInside = 0
    ;   DimTxtDirection = 0
    ;   Document (RO) = #<VLA-OBJECT IAcadDocument 000000bfffb0abd8>
    ;   EntityTransparency = "ByLayer"
    ;   ExtensionLineColor = 256
    ;   ExtensionLineExtend = 0.0625
    ;   ExtensionLineOffset = 0.0625
    ;   ExtensionLineWeight = 25
    ;   ExtLine1Linetype = "Continuous"
    ;   ExtLine1Suppress = 0
    ;   ExtLine2Linetype = "Continuous"
    ;   ExtLine2Suppress = 0
    ;   ExtLineFixedLen = 1.0
    ;   ExtLineFixedLenSuppress = 0
    ;   Fit = 3
    ;   ForceLineInside = 0
    ;   FractionFormat = 2
    ;   Handle (RO) = "A73B"
    ;   HasExtensionDictionary (RO) = -1
    ;   HorizontalTextPosition = 0
    ;   Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 000000bfaf276a38>
    ;   Layer = "0"
    ;   LinearScaleFactor = 1.0
    ;   Linetype = "ByLayer"
    ;   LinetypeScale = 1.0
    ;   Lineweight = -1
    ;   Material = "ByLayer"
    ;   Measurement (RO) = 940.458
    ;   Normal = (0.0 0.0 1.0)
    ;   ObjectID (RO) = 42
    ;   ObjectName (RO) = "AcDbRotatedDimension"
    ;   OwnerID (RO) = 43
    ;   PlotStyleName = "ByLayer"
    ;   PrimaryUnitsPrecision = 3
    ;   Rotation = 0.0
    ;   RoundDistance = 0.0
    ;   ScaleFactor = 1.0
    ;   StyleName = "MMC"
    ;   SubUnitsFactor = 100.0
    ;   SubUnitsSuffix = ""
    ;   SuppressLeadingZeros = 0
    ;   SuppressTrailingZeros = 0
    ;   SuppressZeroFeet = -1
    ;   SuppressZeroInches = 0
    ;   TextColor = 256
    ;   TextFill = 0
    ;   TextFillColor = 0
    ;   TextGap = 0.0625
    ;   TextHeight = 0.09375
    ;   TextInside = 0
    ;   TextInsideAlign = 0
    ;   TextMovement = 0
    ;   TextOutsideAlign = 0
    ;   TextOverride = ""
    ;   TextPosition = (-1843.13 1512.41 0.0)
    ;   TextPrefix = ""
    ;   TextRotation = 0.0
    ;   TextStyle = "MMC"
    ;   TextSuffix = ""
    ;   ToleranceDisplay = 0
    ;   ToleranceHeightScale = 1.0
    ;   ToleranceJustification = 1
    ;   ToleranceLowerLimit = 0.0
    ;   TolerancePrecision = 3
    ;   ToleranceSuppressLeadingZeros = 0
    ;   ToleranceSuppressTrailingZeros = 0
    ;   ToleranceSuppressZeroFeet = -1
    ;   ToleranceSuppressZeroInches = -1
    ;   ToleranceUpperLimit = 0.0
    ;   TrueColor = #<VLA-OBJECT IAcadAcCmColor 000000bfb5b704e0>
    ;   UnitsFormat = 4
    ;   VerticalTextPosition = 1
    ;   Visible = -1
    Kyle
  7. #7
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,141
    Had a quick look at my R12 lisp manual the paper one and there is close to 2 pages of dxf codes for making a dimstyle, so yes you should be able to change either 1 dim or alter a dimstyle. Tharwats code opens up the dim styles just need next step to get at each one I was doing something wrong when trying a dump.
  8. #8
    HP Elitebook 8760w
    16GB
    NVIDIA Quadro 4000M
    AutoCAD 2016
    Feb 2009
    Kansas City, MO
    438
    You may not have been doing anything wrong when you tried dumping the dimstyle. If you dump an existing dimstyle object or the dimstyle object added to the collection per the code Tharwat is demonstrating, you only get a little information returned. If you set the variables like Lee mentions above, that is how you can edit all the settings of a dimstyle. Just out of curiosity, I thought I would place a dimension in my drawing and do a dump on the entity. The above list is what is returned. I was hoping these might provide another avenue of modifying a dimension style.
    Kyle
  9. #9
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,141
    Getting their slowly a bit of a google you can only edit the current dimstyle so use copyfrom then set properties, which is what Lee was suggesting
    Code:
    (setq dims (vla-get-activedimstyle (vla-get-activedocument (vlax-get-acad-object))))
    (vla-put-name dims "BIGAL") ; renames your current dim style
    ; just use what you dumped above
  10. #10
    HP Elitebook 8760w
    16GB
    NVIDIA Quadro 4000M
    AutoCAD 2016
    Feb 2009
    Kansas City, MO
    438
    I think you, Lee, and I are all saying the same thing, but I was just looking at a different way of writing the code. I really like how easy it is to read visual lisp code. It may use longer function names, property names, etc., but when reading it, I can figure out what I did a lot quicker. So I was looking to incorporate this method with creating a dimension style from scratch. I now understand that you can only modify the properties of the current dimension style. I also understand that those properties can only be modified by setting each individual variable similar to this:
    Code:
    (vla-setvariable doc "DIMCLRD" 256)
    However, I was hoping to do something more along the lines of this:
    Code:
    (vlax-put-property dimobj "DimensionLineColor" 256)
    Kyle
  1. Need help !Use lisp Create text style & dimension style.
    By lucas3 in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Jan 2014, 05:53 pm
  2. How to create a text style for a dimension
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 6th Aug 2011, 05:30 pm
  3. dimension style create (plz chk my new lisp & how to improve)
    By autolisp in forum AutoLISP, Visual LISP & DCL
    Last Post: 31st Jul 2010, 08:01 am
  4. Tutorial: Create a visual style
    Last Post: 21st Oct 2007, 07:42 pm
  5. Tutorial: Create a custom visual style in AutoCAD 2007
    Last Post: 13th Nov 2006, 09:50 pm
