Results 1 to 8 of 8
    Forum Newbie
    AutoCAD 2016
    Mar 2015
    5
    Default field text in a linetype
    Hi All, i'm trying to make a new linetype with text, but i want the text to have a field that displays the length of the line. Does anyone know how to do this? Or if it's possible?
    Any help would be much appreciated!
    Forum Newbie
    AutoCAD 2016
    Mar 2015
    5
    thanks ReMark, the reason I would want it to be a linetype though would be so that I can have multiple segments, like as a polyline, and it can display the total length of the polyline. I'm thinking something like the GAS linetype or the HOT WATER supply linetype, but where the text is a field.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    Can't say I've seen anything like that and any workaround I have tried has been too clunky.
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,702
    On a single line it can be done using a dimension, but thats not applicable for a pline.
    Like Remark what about just pick and update objects or search by layer etc.
  5. #5
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,163
    Someone might know a way with LISP, you could use the measure command and insert a block with a field along a line/pline, you could of course add other text or a wipeout or background hatch
  6. #6
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,702
    This is based on Steven-g dwg it will label but if you change the pline the blocks do not change, one way around this is to erase all the blocks move the pline then redo the (c:plen), this involves other routines but the method is quite simple using ssget "F" done below
    Simplest is the need to be able to put the field in a .LIN
    A,5.08,-5.08,5.08,-5.08,["G",STANDARD,S=1.8,R=0.0,X=-1.8,Y=-.9],-3 need the "G" to be a field.
    Code:
    (defun c:plen ( / obj)
    (setq obj (entsel "Pick line or pline"))
    ; probably want a layer set here
    (command "measure" obj "B" "len" "Y" (getdist "enter spacing"))
    Code:
    ; pline co-ords example
    ; By Alan H
    (defun getcoords (ent)
      (vlax-safearray->list
        (vlax-variant-value
          (vlax-get-property
        (vlax-ename->vla-object ent)
        "Coordinates"
    (defun co-ords2xy ()
    ; convert now to a list of xy as co-ords are x y x y x y if 3d x y z x y z
    (setq len (length co-ords))
    (setq numb (/ len 2)) ; even and odd check required
    (setq I 0)
    (repeat numb
    (setq xy (list (nth i co-ords)(nth (+ I 1) co-ords) ))
    ; odd (setq xy (list (nth i co-ords)(nth (+ I 1) co-ords)(nth (+ I 2) co-ords) ))
    (setq co-ordsxy (cons xy co-ordsxy))
    (setq I (+ I 2))
    ; erase blocks
    (defun c:eraseblk ( / ss)
    (setq co-ords (getcoords (car (entsel "\nplease pick pline"))))
    (co-ords2xy) ; list of 2d points making pline
    (setq ss (ssget "f" co-ordsxy (list (cons 0 "Insert"))))
    (command "erase" ss "")
  7. #7
    Forum Newbie
    AutoCAD 2016
    Mar 2015
    5
    Thanks everyone,
    BIGAL, I used the first code you wrote above and saved it as a .lsp, loaded it with appload, and used the command "plen" on steven-g's drawing. It placed a measurement along my pline in regular intervals, which is great! but the measurement was always 15.81 m... which was the length of steven-g's line that he drew. When I draw a new line, it doesn't know to measure that one. Maybe the answer is in the second code you provided... but my novice autocad brain doesn't understand what to do with it.
  8. #8
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,702
    I tested the small plen again at 2000 as spacing on a new pline and works fine, you may need to play with the dynamic block in terms of scale etc for small distance.
    Used Bedit to edit block maintain insertion point.
  1. Dim text linked to another Dim using a dynamic text field
    By Manila Wolf in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Jan 2015, 07:22 am
  2. Sum Text Strings to Text Field...
    By tomjas in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Jul 2013, 08:05 pm
  3. Replies: 10
    Last Post: 5th Apr 2011, 04:43 pm
  4. Text Field Lisp??
    By feargt in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Apr 2009, 07:35 am
  5. Field text editing
    By Nippon in forum AutoCAD Drawing Management & Output
    Last Post: 31st Jul 2006, 09:18 am
Tags for this Thread
