Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Full Member
    AutoCAD 2014
    May 2015
    30
    Default Scaling a Floor Plan
    Hi Guys..
    I had drawn my floor plan using inches units in the insertion scale..I also used the floor pla dimensions indicated in the blueprint...ahmm..for example instead of making a 1,300..length of a rectangle ...I made it ..1.3 in my actual drawing....I thought I could just rescale it if I needed to...my problem is I'm using A1 paper for my drawing and I need to scale it to 1:100 in the layout..when I change the standard scale of my viewport to 1:100 the drawing looks too small on the A1 paper...any thoughts of what might be the problem to I have to change my units...or use the -dwgunitscommand
    Thank you
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    In all likelihood while you thought you were drawing in meters you were probably still drawing in millimeters. As others have suggested using -DWGUNITS is the place to start if you want to change from one type of unit to another.
    Full Member
    AutoCAD 2014
    May 2015
    30
    Hi @remark..I'm not sure what the units scale inserted content means..can you please explain it quite further...thanks
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    Well that is not what I was referring to but since you asked this is what AutoCAD Help has to say about the subject.
    INSUNITS (system variable)
    Specifies a drawing-units value for automatic scaling of blocks, images, or xrefs when inserted or attached to a drawing.
  5. #5
    Full Member
    AutoCAD 2014
    May 2015
    30
    thanks,,should I draw a floor plan next time on the actual size..so for example if the length of the lot is 1300 cm..I should draw it in autocad in 1300 with a unit of centimeters....and then scale the drawing on viewports for example 1:100..sorry for so much question I'm just confused with scaling...thank you
  6. #6
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,127
    Yes, draw full size in model space and use paper space viewport to scale the drawing for plotting.
  7. #7
    Super Member
    Ski_Me's Computer Details
    DELL (why oh lord must I suffer)
    Electrical
    Ski_Me's Discipline Details
    Fire Alarm tech
    Electrical
    AutoCAD 2018
    Apr 2012
    Edmond. OK
    643
    yes you should always draw full size in model space then use your paper space to scale your drawing. Much easier to let AutoCAD do all the thinking for you.
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    The last thing you ever want to do is draw "to scale" as one might do manually on a drafting board. Those days are long gone. Follow the above advice.
  9. #9
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    Quote Originally Posted by indigo View Post
    Hi Guys..
    Thank you
    You are mixing metric units (mm, cm, M) so you can't expect the 1:100 menu pick, which is set for mm, to scale the viewport correctly.1:0.1xp. Adjust for the 1000m/M for the correct scale.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  10. #10
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,709
    Cm's sounds odd normally it would be mm or metres.
  1. Scaling a floor plan in AutoCAD 2014
    By DonL in forum AutoCAD Beginners' Area
    Last Post: 3rd Sep 2013, 10:44 am
  2. Floor Plan
    By KharizzaJeh in forum AutoCAD General
    Last Post: 20th Mar 2013, 02:11 pm
  3. Flattening a .... somewhat large 3d hospital ground floor to a 2d floor plan
    By amylmc in forum AutoCAD 3D Modelling & Rendering
    Last Post: 17th Oct 2012, 11:30 am
  4. floor plan
    By eugene233 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 10th Apr 2009, 12:49 pm
  5. floor plan layering
    By stabiloboss in forum AutoCAD General
    Last Post: 19th May 2004, 10:10 pm
Tags for this Thread
