Get Geo-Coordinates of a Position Marker
dick69
Hi mates,
any idea to get the geo-coordinates of a Position Marker (new entity in Autocad 2016)?
I tried to extract like a block attributes, but it doesn't work.
Thanks in advance.
(vl-load-com)
(defun c:test ()
 (setq p (getPositionMarkerCoords))
 (princ (strcat "\nNorthing: " (rtos (cadr p) 2 3)
	 "\nEasting: " (rtos (car p) 2 3)))
(defun getPositionMarkerCoords (  / ad s ds ts rp le ln p)
 (setq ad (_GetAeccDocument))
 (setq s (vlax-get-property ad 'Settings))
 (setq ds (vlax-get-property s 'DrawingSettings))
 (setq ts (vlax-get-property ds 'TransformationSettings))
 (setq rp (vlax-get-property ts 'ReferencePoint))
 (setq le (vlax-get-property rp 'LocalEasting))
 (setq ln (vlax-get-property rp 'LocalNorthing))
 (setq p (list le ln))
(defun _GetAeccDocument ()
 ((lambda (vrsn)
    (if
      (setq vrsn
             (cond
	((vl-string-search "21.0" vrsn) "11.0")                 ; 2017
               ((vl-string-search "20.1" vrsn) "10.5")                 ; 2016
               ((vl-string-search "20.0" vrsn) "10.4")                 ; 2015
               ((vl-string-search "19.1" vrsn) "10.3")                 ; 2014
               ((vl-string-search "19.0" vrsn) "10.0")                 ; 2013
               ((vl-string-search "18.2" vrsn) "9.0")                  ; 2012
               ((vl-string-search "18.1" vrsn) "8.0")                  ; 2011
               ((vl-string-search "18.0" vrsn) "7.0")                  ; 2010
               ((vl-string-search "17.2" vrsn) "6.0")                  ; 2009
               ((vl-string-search "17.1" vrsn) "5.0")                  ; 2008
       (setq *AeccDoc*
              (vlax-get
                (cond (*AeccApp*)
                      ((setq *AeccApp*
                              (vla-getinterfaceobject
                                (cond (*Acad*)
                                      ((setq *Acad* (vlax-get-acad-object)))
                                (strcat "AeccXUiLand.AeccApplication." vrsn)
                'ActiveDocument
   (if vlax-user-product-key                                           ; If 2013+
     (vlax-user-product-key)                                           ; Use new function
     (vlax-product-key)                                                ; Use legacy function
Edited by Hippe013
Code Tags (My Bad) - Added / to make variables local
Hi Hippe013,
Thanks for posting the code. However in order to make it work I had to add a "/" to the local variables area of the getpositionmarkercoords function because they look like arguments as you posted it. Also, in the same function you are declaring the variable "ne" as local, but I think you mean for that to be "ln".
Thanks again,
Steve
Steve,
Thanks for the catch. I threw this together rather quickly from other code that I had. I will update my code above.
regards,
Hippe013
Thanks for the code vdub, but when I execute it on autocad, return me the next error: "; error: Automation Error. Problem in loading application".
I've check the lisp and I think that the problem is on "getPositionMarkerCoords" function that it doesn't run. (I've Autocad 2016 release)
Thanks a lot for your support,
Greetings.
The routine that I created above works only with Civil 3D with the versions stated above. As of right now I am not certain how to gain access to the geo-location data (using visual lisp) without using Aecc. I should be able to write a lisp function using vb.net to expose the geo-location data without the use of Aecc (Civil 3D). This may take a little while depending on how well exposed you need it. ie. Just retrieve data vs. setting data.
regards,
Hippe013
Re-reading the OP, it sounds like you just want the coordinates of the Position Marker Entity that's similar to a multileader, correct? If so, the following should do it (you can select as many of them as you want). I wasn't sure if you wanted the LatLongs, or Cartesian coordinates, so it displays both.
HTH
;;Get Position Marker Geo-Coordinates
;;By Steve Carson
(vl-load-com)
(defun c:PMCoords ( / ss obj)
(setq ss (ssget '((0 . "POSITIONMARKER"))))
   (setq obj (vlax-ename->vla-object (ssname ss (setq i (1- i)))))
   (princ (strcat "\n" (vla-get-TextString obj)))
   (princ (strcat "\nNorthing: " (rtos (cadr (vlax-safearray->list
                                                 (vlax-variant-value
                                                     (vla-get-Position obj)
                                  2 ))
   (princ (strcat "\nEasting: " (rtos (car (vlax-safearray->list
                                                 (vlax-variant-value
                                  2 ))
   (princ (strcat "\nLatitude: " (vla-get-Latitude obj)))
   (princ (strcat "\nLongitude: " (vla-get-Longitude obj)))
   (princ "\n")
(textscr)
Steve
I was under the understanding that the OP wanted the GEO-Location position rather than the location of a position marker. Your code works fine for this. I would be curious as to how extract the location of the GeoMarker (Red Dot) without the benefits of the Aecc document. I've attached an image showing the Geo-Location Marker that I was referring to.
  • 4 years later...
Hippe013,
Just doing some digging into this today, I know I'm a few years late, but it may benefit somebody still.
Best,
~DD
(defun GetGeoData ( / )
  (dictsearch
    (cdr (assoc 360 (entget (cdr (assoc 330 (entget (tblobjname "BLOCK" "*Model_Space")))))))
    "ACAD_GEOGRAPHICDATA"
  );dictsearch
);defun
(defun c:TEST ( / geoData ptGeo)
  (if (and (setq geoData (GetGeoData))
           (not (zerop (getvar 'TILEMODE))))
      (setq ptGeo (cdr (assoc 10 geoData)))
      (command "_.CIRCLE" "non" ptGeo (* 0.15 (getvar 'VIEWSIZE)))
      (prompt "\nA circle was created at the point: ") (princ ptGeo)
    );progn
  ;else
    (prompt "\nEither No Geo Data or not in Model space...")
  );if
);defun
  • 1 year later...
HTH
;;By Steve Carson
(vl-load-com)
                                                 (vlax-variant-value
                                  2 ))
                                                 (vlax-variant-value
                                  2 ))
   (princ "\n")
(textscr)
Steve
That code seems to be missing 2 closing ) characters, I presume at the the (princ (strcat.
