Results 1 to 1 of 1
    Full Member kpyoung333's Avatar
    kpyoung333's Computer Details
    Dell Precision T1600
    Two 22" Acer AL2216W
    kpyoung333's Discipline Details
    Research & Development Designer
    Aerospace contacts & connectors, iron fabrication, automotive transport, architecture.
    Inventor 2016
    Oct 2012
    Default Sheet Metal Die Bend Clearance
    Started doing a bunch of sheet metal bending and trying to streamline our process. We have 50+ dies all labeled and organized on a rack, but at my computer we don't have reference to these dies other than the bend radius. My thought is that if we measure them all and make models we would be able to check to see if the die will clear the bend. Is there any smarter/faster/easier way to do this in inventor through the sheet metal bending tab or punch tool? This question came up when I made a part to get bent, see example image, but the die relief clashed against the part on the double bend. Rather than make a new die to fit my dimensions I have to redesign to fit our existing die parameters, ie make the lip smaller so the die clears. The hard way would be to just make a spreadsheet of the dimensions and verify the clearance, but I want something a bit more intuitive for future use. I think solidworks had something like this but I only used it at school years ago. Any fun suggestions? Thanks!
  1. How to bend this sharp edge SS sheet metal
    By Sengna in forum Autodesk Inventor
    Last Post: 3rd Nov 2015, 12:33 am
  2. How to bend or fold sheet metal?
    Last Post: 3rd Oct 2014, 07:58 pm
  3. Sheet Metal Flat Pattenrn (Print with Bend Lines)
    By Jake8090 in forum Autodesk Inventor
    Last Post: 19th Jun 2014, 08:43 pm
  4. Inventor 2012 - Sheet Metal, how to 'bend' a plate
    By Ste1978 in forum Autodesk Inventor
    Last Post: 4th Dec 2012, 08:40 am
  5. Sheet Metal; Bend a Corner
    By Tjeerd in forum Autodesk Inventor
    Last Post: 5th Apr 2008, 09:45 am
Tags for this Thread
