Page 2 of 6 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 54
  1. #11
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Oh, I am definitively asking you.
  2. #12
    Super Member
    Ski_Me's Computer Details
    DELL (why oh lord must I suffer)
    Electrical
    Ski_Me's Discipline Details
    Fire Alarm tech
    Electrical
    AutoCAD 2018
    Apr 2012
    Edmond. OK
    642
    For the purpose of demonstration this difference in scale is a bit extreme but I wanted to show that if you select a different scale for your annotative objects than your viewport you can still see your annotative objects without having to add new scales. I maintain the same annotative scale for all my objects because all of my annotative objects are nested within blocks so I just use 1 scale for all my drawings. As you can see if you adjust the viewport scale to match the annotative scale to 1/64th then the text becomes to small to see but if the annotative scale is set to 1/8th and the viewport is set to 1/64th the text scales to 1/8th paper space instead of 1/64th. I didn't go to page set up to adjust the paper size but if you want play with that as well. For me this works really well, I don't have to mess with different annotation scales and it stream lines my work.
  3. #13
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    So basically my assumption was correct. Some companies might have a problem with that approach if they insist on standard text/dimension heights for all their drawings. We avoid the problem by placing all text and dimensions in the layout and not in model space. But...each to his own.
  4. #14
    Junior Member
    AutoCAD 2017
    Sep 2016
    18
    Thank you Ski_Me, this is a very interesting work around.
    Alternatively it is always the manual set up of parameters in the Annotative DimStyle Dialog box.
    Guys, is there an acknowledged standard of parameters or template in (mm) of common Annotative Dimensions Settings that would be relevant to A4, A3, A1 formats.
  5. #15
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    I suppose that would depend on the country you live/work in primarily. Where do you live?
  6. #16
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Quote Originally Posted by kashbg View Post
    I wouldn't even consider it a work around in a proper drafting environment. It is counterintuitive to what annotative scaling is for. In a way, the workaround breaks the functionality of it. Remember, annotative scaling is Autodesk's solution for consistent sizes in paper space. If you want different sizes in paper space, you should use different styles.
    Drafting is a breeze.
  7. #17
    Junior Member
    AutoCAD 2017
    Sep 2016
    18
    I live in UK, the former EU member.
    We use primarily Architectural units (mm) as opposed to Imperial.
  8. #18
    Super Member
    Electrical
    Fire Alarm tech
    Electrical
    AutoCAD 2018
    Apr 2012
    Edmond. OK
    642
    Quote Originally Posted by RobDraw View Post
    RobDraw is correct this is not really a workaround it's just applying a different method. I'm not sure what is meant by breaking functionality since AutoCAD allows you to use a annotative scale that's different from the viewport scale. Why would they include a sync function if you couldn't do this. I'm not sure about everybody else on what they do but I know that I have to produce my drawings from work that other people have done which means that if they are using some bizarre crazy scale I need to use the same scale. I'm not going to go through the trouble of creating a whole set of styles and blocks just for a few drawings that I will never use again. Call it bad cad if you like but I found a way that works and works well. Now if you could please direct me to where Autodesk said that annotative scaling is for consistent sizes in paper space I would like to tell them that they are wrong.
  9. #19
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    You live in a different drafting world, Ski_Me.
    Annotative scaling was introduced as an better way to make sure things appear in paper space at the same scale without having to create multiple styles and/or symbolic blocks. I know this from when it was first introduced. You can do the research if you would like to complain to Autodesk, but I'm not doing it for you. A lot of people learn to use things in a different manner than was intended. If it works for your world, I'm not going to fault you for it. I work with a different, more universal, and stringent, set of rules.
  10. #20
    Super Member
    Electrical
    Fire Alarm tech
    Electrical
    AutoCAD 2018
    Apr 2012
    Edmond. OK
    642
    Clearly you do work from a different set of standards than I do. My situation is unique in that producing drawings is a big part of what I do but it's not the only thing I do. AutoCAD is one of many tools I use in my tool box to get my job done. I do wish that all I had to do is design work but my skills as a tech out weighs the need for me to be at a workstation everyday of the week to being out in the field trouble shooting and installing systems. But I wouldn't trade my position for anything in the world right now, nobody else that works in the same field as me in this state can do what I do. And I do it well. I don't really want to complain to Autodesk about anything really I know the intent was exactly what you said they first came out with it, but I'm sure they realize that people like me would find another way to apply it so it fits their needs.
  1. SCALE routine to explode and scale dimensions...
    By lamensterms in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st May 2014, 02:17 am
  2. Dimensions at 1:2 scale
    By beeb in forum AutoCAD Beginners' Area
    Last Post: 8th Dec 2009, 05:45 am
  3. Dimensions/Scale/Help
    By shellb in forum AutoCAD Beginners' Area
    Last Post: 1st Nov 2007, 10:16 pm
  4. scale/dimensions
    By eddie57 in forum AutoCAD Beginners' Area
    Last Post: 27th Dec 2005, 08:15 pm
  5. Dimensions don't scale to Viewport scale
    By brooksn in forum AutoCAD Drawing Management & Output
    Last Post: 6th Jul 2005, 06:18 pm
Tags for this Thread
