Results 1 to 6 of 6
    Forum Newbie
    AutoCAD 2016
    Oct 2016
    1
    Default layout tab subfolders
    I have huge amount of layouts in my DWG. I would like to have a possibility to organize them. Is there a way to modify AutoCAD to make the creation of layout sub-directories possible?
    for example:
    - Model
    - Element 1:
    -- Element 1 frame (Layout 1)
    -- Element 1 sheeting (Layout 2)
    - Element 2:
    -- Element 2 frame (Layout 3)
    -- Element 2 sheeting (Layout 4)
    -- Element 3 details (Layout 5)
    etc
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Not without some programming.
    If my layouts were getting out of hand, I would consider splitting up the file so that it is more manageable.
    Drafting is a breeze.
    Super Member
    tombu's Computer Details
    Windows 7 64-bit
    Dell
    Civil
    tombu's Discipline Details
    Design Analyst
    Civil
    Small Street & Stormwater projects. Traffic Calming and other issues.
    Civil 3D 2018
    Dec 2010
    Tallahassee, FL USA
    760
    These links may help:
    While pressing CTRL, press Page Up to cycle up (or left) or press Page Down to cycle down (or right) to cycle through the Layout and Model tabs.
    https://knowledge.autodesk.com/suppo...shortcuts.html
    You can control how you change between the Model tab and one or more named layout tabs.
    https://knowledge.autodesk.com/suppo...41153-htm.html
    I've also added a macro to toggle TILEMODE so I can toggle between the current layout and the Model tab.
    Not exactly what you asked for, but workarounds many of us are using for your situation.
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2018
    Mar 2006
    Dallas, TX - USA
    9,074
    Quote Originally Posted by RobDraw View Post
    I'm with Rob on this one. Sheet Set Manager, or the old XREF Titleblock Sheet File is the way around this issue.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
  5. #5
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,588
    Sheet Set Manager would be the way to go for sure.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  6. #6
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,151
    As a bit of a simple answer I take it you know you can move a layout tab so its at least in the correct order.
  1. how to start a new layout view without destroying previous layout view?
    By MLM721 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 9th Oct 2016, 10:14 am
  2. Creating Folders and Subfolders
    By Earlzii in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Oct 2016, 12:42 pm
  3. Move layout-Rename layouts- Goto layout
    By BIGAL in forum AutoCAD Drawing Management & Output
    Last Post: 22nd Apr 2014, 01:30 am
  4. How to change 2009's layout to a "classical layout"?
    By Zzap in forum AutoCAD Beginners' Area
    Last Post: 2nd Apr 2011, 02:23 am
  5. moved from one layout to another layout
    By yadavdinesh2008 in forum AutoCAD Beginners' Area
    Last Post: 6th Jun 2010, 05:02 pm
Tags for this Thread
