Thank you Grrr :thumbsup:
An alternative could be to use mapcar with two separate argument lists, i.e.:
(setq obj (vlax-ename->vla-object (ssname sel (setq idx (1- idx))))
     ls1 (cons obj ls1)
     ls2 (cons (vla-get-color obj) ls2)
Then:
(mapcar 'vla-put-color ls1 ls2)
Thats right, now I remember! I might need revise again your mapcar & lambda tutorial, incase I forgot something.
I did a big progress from there, the only problem is that very very careful reading is required. :D
BTW the recent pause discovery inspired me to write some simple subfunction:
; Example: (PromptPause "\nPaused, press any key to continue.")
(defun PromptPause ( msg )
(and (= 'STR (type msg)) (princ msg) (vl-catch-all-apply 'grread) )
(and
(setq e (car (entsel "\nSelect object: ")))
(setq o (vlax-ename->vla-object e))
(setq c (vla-get-Color o))
(not (vla-put-Color o 1))
(not (vla-put-Color o c))
As I remember that once someone asked "How to pause a code?", but I think the answers he got were with using the get*** functions.
  • Replies 23
  • jim78b
    13
  • Grrr
    4
  • ReMark
    3
  • RobDraw
    2
Posted Images
Sorry for bumping this thread, but just found this code from LM (from theswamp) :
(defun c:test ( / col idx sel )
(if
	(and
		(setq sel (ssget "_:L"))
		(setq col (acad_truecolordlg 1))
	(repeat (setq idx (sslength sel))
		(entmod (append (entget (ssname sel (setq idx (1- idx)))) col))
So I thought if he "merged" it with his suggestion here, the end result would be more "complete":
(defun c:tempcolor ( / col idx lst obj sel )
(if
	(and
				lst (cons (list obj (vla-get-color obj)) lst)
			(vla-put-color obj (cdar col))
		(princ "\nPress any key to exit...")
		(foreach itm lst (apply 'vla-put-color itm))
(vl-load-com) (princ)
It could not change color after I initiated a command?
  • 1 year later...
Is it possible to make the color change after i start a command ...example...i make move command select a object or a block and them will color .color that i choosed in my lisp...?
