Hello,
I am having difficulty in setting the StandardScale in my template. Usually I set the scale using the bottom tool bar. When I attempt to set the scale the different options do not pop-up. Another approach I usually use is going through the properties menu of my viewport. When I change the standard scale an ERROR message pop-up stating "Invalid argument Scale in setting StandardScale property". It seems to be locked on an XREF scale.
For my projects I usually copy-paste original architectural drawings into my personal templates. I believe I may have locked something up in this process that does not allow me to change scales.
I am a 2008 AutoCAD LT user with 5+ years of experience.
Thanks
I have found the solution to my problem. Apparently I have a couple overlapping viewports. This kind of leads me into another problem I have been having with my scales lately. Under my scale settings I have about 100+ different XREF scale options. I believe they are coming from the copy-pasting I explained earlier. Is there any way to get rid of these? They are more of a nuisance than anything.
Thanks
Don't mention it. Just one of the many services we provide here at CADTutor Central. LOL
