Isometric Drawings
I'm beginning to believe that your friend may have created his own acad.mnu file and passed it along to you.
  • 2 weeks later...
  • Replies 31
  • ReMark
    9
  • oldcodger
    8
  • Sweety
    3
  • Oppie
    2
Sorry for the delay in getting back to you but I have been trying to get hold of a laptop with the exact same Auto Cad on it. This one has a quite normal tool bar and thet came from the same disc! Any ideas?
Oldcodger
Would it be possible to install ACAD with a custom acad.mnu file?
After install from the original CD(s) I would think, install your own revised or create a customized acad.mnu file.
Can we install with a customized *.mnu file while installing AutoCAD? I don't think so.
After install, I think we create our own *.mnu file.
  • 1 year later...
how to use templates for isometric 2d piping drawings
Creating a template doesn't have all that much to do with an isometric piping drawing unless you take into account your layers, dimension and text styles and maybe your title block and border.
What seems to be the problem?
Tell us what your definition of a "template" is and maybe we can provide more information. Just want to make sure we are talking about the same thing.
  • 4 weeks later...
:halloween:Drawing in iso is easy just rotate 30 degrees to the right or left and boom your drawing in iso. I hardly use the snap settings or change the cursor. Remeber in ortho or iso your only drawing in 1 view in 3d your drawing in 6 views.
Its simple. Just try the following steps buddy,
Click on the grid display in the bar
open up the settings penal from there
change your styling to SNAP style
then as per your requirement select the appropriate one.
  • SNAPSTYL = 1.
  • F5 key to toggle Top/Right/Left Isoplane.
  • Make sure Polar is set to 30 degree increments, with 45,90,135,315 additional angles enabled.
Done. 8)
  • 2 months later...
Just add 30 degrees to everything you draw screw changing the snap style hell I don't even use a grid! A I barely use the cursor
In my opinion this is poor advice to give anyone who has never done as isometric drawing using AutoCAD.
