vahnx Posted November 10, 2011 Posted November 10, 2011 (edited) The FlexLm service and Autocad are both on the same PC. The problem is having a VPN active on the PC, sudden lag spikes occur on the main PC. The VPN is used for non-autocad related tasks so I don't understand why this would be an issue. It's as if Autocad is searching for the license somewhere on the VPN. This needs to be fixed ASAP. Update: Person with the PC in question now says it still happened after the VPN was removed. Haven't ruled it out 100% as for "aiding" with the lag but it's good to know it's probably not part of the problem. Most likely has to do with licensing no doubt. Edited November 10, 2011 by vahnx Quote
