Major Lag With VPN
vahnx
The FlexLm service and Autocad are both on the same PC. The problem is having a VPN active on the PC, sudden lag spikes occur on the main PC. The VPN is used for non-autocad related tasks so I don't understand why this would be an issue. It's as if Autocad is searching for the license somewhere on the VPN. This needs to be fixed ASAP.
Update: Person with the PC in question now says it still happened after the VPN was removed. Haven't ruled it out 100% as for "aiding" with the lag but it's good to know it's probably not part of the problem. Most likely has to do with licensing no doubt.
Edited by vahnx
