MastroLube Posted June 29, 2017 Share Posted June 29, 2017 Hello, I have a question about dimension. I want to force the text to stay inside the dimension and not to get out if there isn't enough space. I can't find the option in dimstyle and I have to force it by change the voice "INTERNAL TEXT" in proprieties. I've to do that for every quote.. Do you know how to force it? Look at the gif to understand my question better Thank you! Dennis Quote Link to comment Share on other sites More sharing options...
guran Posted June 29, 2017 Share Posted June 29, 2017 Set System Variable DIMTIX to 1. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted June 29, 2017 Share Posted June 29, 2017 Guran has nailed it, you can find this setting also on the Fit or Adatta (in your case) tab, in Options. Quote Link to comment Share on other sites More sharing options...
MastroLube Posted June 29, 2017 Author Share Posted June 29, 2017 Set System Variable DIMTIX to 1. Guran has nailed it, you can find this setting also on the Fit or Adatta (in your case) tab, in Options. Thank you guys!!!! I didn't see it in the "adatta" tab ! and thanks guran for the advice, I'll use it in my lisp! Thanks!! Dennis Quote Link to comment Share on other sites More sharing options...
