How to distinguish between Ellipse and Ellipse Arc?
Ahankhah
Good one tharwat
I didint know that one :)
Thank you pBe ,
I knew these functions which are start with vlax-curve-****** when I was fighting with Polylines to know how to handle them .:lol:
So no chance to forget them anymore . :lol:
Cheers . :beer:
pBe and Tharwat,
thank you very much for your help.
Meanwhile I researched inside Ellipse and Ellipse Arc lists. I found a dxf code inside them which shows whether ellipse is closed or not.
The advantage of the following code is filtering them automatically or on the fly (when selecting objects).
(setq ellipses
 (ssget "X"
   (list
     (cons -4 "<AND")
       (cons 0 "ELLIPSE")
       (cons 41 0)
     (cons -4 "AND>")
(setq ellipsearcs
 (ssget "X"
   (list
     (cons -4 "<AND")
       (cons 0 "ELLIPSE")
       (cons -4 "<NOT")
         (cons 41 0)
       (cons -4 "NOT>")
     (cons -4 "AND>")
That is correct though
 (ssget "X" '((0 . "ELLIPSE") (41 . 0)))
would be enough for filter list
I was too engrossed with vlaobjects to think about a simple syntax with vanilla
Good stuff Ahankhah :)
(if
(= StartAngle 0)
(Closed/FullEllipse)
(Open/EllipseArc)
Not quite.
Consider:
(entmakex
   (list
       (cons 0 "ELLIPSE")
       (cons 100 "AcDbEntity")
       (cons 100 "AcDbEllipse")
       (list 10 0.0 0.0 0.0)
       (list 11 1.0 0.0 0.0)
       (cons 40 0.5)
       (cons 41 0.0)
       (cons 42 pi)
(setq ellipses
(setq ellipsearcs
This won't work for the above counter example, consider the following instead:
(defun c:ellipses nil
   (sssetfirst nil
       (ssget "_X"
           (list
               (cons 0 "ELLIPSE")
               (cons 41 0.0)
               (cons 42 (* 2 pi))
(defun c:ellipsearcs nil
   (sssetfirst nil
       (ssget "_X"
           (list
               (cons 0 "ELLIPSE")
               (cons -4 "<OR")
                   (cons -4 "<>")
                   (cons 41 0.0)
                   (cons -4 "<>")
                   (cons 42 (* 2 pi))
               (cons -4 "OR>")
Not quite.
:lol: I realize that right after i posted.
Consider:
   ......                (cons 42 (* 2 pi)) ......
Really? Guess i ddnt do a thorough test :)
Thank you for the info.
This won't work for the above counter example, consider the following instead...
Lee, I am surprised of your excellent look and observing all side effects of any code:o.
Again and again and again..., thank you very much:D.
A side effect I suppose from studying a maths degree involving countless proofs...
You're welcome Ahankhah :)
