hai, i need a small help.i have a working lisp routine which gives perpendicular line distance to main line when clicked on a place perpendicular, only thing i want to try and add is to remove the leader that adds and only add text without leader in position where i can click. pls reply if its possible... thanks:)
(defun c:Test ( / s p c a d)
 (if (and (setq s (car (entsel "\nPick a polyline :")))
        (or (= (cdr (assoc 0 (entget s))) "LWPOLYLINE")
            (alert "Invalid object! Please pick a polyline only.")
        (setq p (getpoint "\nSpecify point perpendicular to polyline :"))
        (setq c (vlax-curve-getclosestpointto s p))
        (setq a (angle p c))
        (not (grdraw p c 1 -1)) ;; rubber line in red colour.
        (setq d (angle '(0. 0. 0.) (vlax-curve-getfirstderiv s (vlax-curve-getparamatpoint s c))))
        (or (or (equal (rem (+ d (* pi 0.5)) (+ pi pi)) a 1e-4)
                (equal (rem (+ d (* pi 1.5)) (+ pi pi)) a 1e-4)
            (alert "Picked point is not a perpendicular to picked polyline. <!>")
 (command "_.leader" "_non" p "\\" "" (strcat "CHAINAGE=3+0" (rtos (vlax-curve-getdistatpoint s c) 2 4)) "")
) (vl-load-com)
Edited by SLW210
Fixed Code Tags
Try this :-
(defun c:Test (/ s p c a d)
 (if
   (and
	       s
  (alert
    (entmakex
      (list
 '(0 . "text")
 '(100 . "AcDbEntity")
 '(67 . 0)
 '(370 . 13)
 '(100 . "AcDbText")
 (cons 10 p)
 (cons 40 2.5)			[color="red"]; Change text height here[/color]
 (cons 1
       (strcat "chainage=3+0"
 (cons 71 0)
 (cons 72 0)
 (cons 11 '(0 0 0))
 '(100 . "AcDbText")
 (cons 73 0)
(vl-load-com)
Thank u, it works good
but just want to know if its possible to select the text location manually, as this code lets the text at the point where i click for distance. Like the leader starts and then text location except no leader needed, only text. If possible it would be nice.
This code really helps a lot, thank you so much..
also is it possible to continous the command after i select the polyline, like i select the polyline then after were ever i click it gives the distance to it, (like MULTIPLE command).
the current command ask for polyline after every click and length.. thanks:)
Command is continuous in this code as per your requirement:
(defun c:Test (/ s p c a d tp)
 (if
    (while
      (and
 (setq
		  s
 (or
   (alert
 (setq tp (getpoint "\nSpecify Point for Text : "))
(entmakex
  (list
    '(0 . "text")
    '(67 . 0)
    '(370 . 13)
    '(100 . "AcDbText")
    (cons 10 tp)
    (cons 40 2.5)		; Change text height here
    (cons 1
    (cons 71 0)
    (cons 72 0)
    (cons 11 '(0 0 0))
    '(100 . "AcDbText")
    (cons 73 0)
(vl-load-com)
I've updated code above for continuous operation, check it
Thank you so much. It works perfectly...:D
i didn't know how to change the code to simple text sting, thanks so much...
